Hello
How to calculate or setting output voltage and output current of TPS2373-4? What factor will be affected output voltage and current. Thank you.
BR
Patrick
Hello
BR
Patrick
Hi Patrick,
At a high level, the purpose of the TPS2373 is to pass through the voltage provided by the PSE to the load. So the output voltage and load of the PD controller will be dictated by the PSE voltage minus the voltage drop of the cable and bridge while the current will depend on the load.
Do you mean to ask the output voltage/current of the DCDC converter and not the TPS2373?
