Hi Team,
My customer is designing a circuit with multiple TPS543B20/C20, they are using EN and PGD pin to achieve power-on sequence and start the device one by one during start up (Device A->B->C->D, PGD connect to next device's EN).
Now, they got a requriement for power off sequence that they need to shutdown the device one by one in a opposite way(Device D->C->B->A).
So we need your help to understand how PGD would work if EN is disable the device, will PGD still follow the status of output voltage? or will PGD be high-impedance when EN is disabling the device? thanks.
BTW, do you have any suggestion about how to achieve the power-off sequence? thanks.
Kevin
