Other Parts Discussed in Thread: TPS54620, TPS57114-Q1
Hi
TPS54620 Parallel Operation
Hi
Hi takahiko yokota,
We don't recommend you parallel two TPS62810-Q1, the performance will be worse and we also can't guarantee it can work stable for a long live time. For TPS54620, its compensation net is external, so we can connect it together to keep the Vcomp is same, but for TPS62810-Q1; the compensation net is internal, we can't keep the Vcomp is same for two device. So we don't recommend you parallel the TPS62810-Q1.
Kevin
If this answers your question, Please click "This resolved my issue" button.
____________________________________________
TPS62810-Q1 – New Automotive 6Vin, 2.25MHz buck family with 1% accuracy and SYNC-pin. 1-2-3-4A options.
Smallest 2x3QFN package with wettable-flanks for optical PCB inspection.
Hi Kevin-san
Hi Yokota-san,
TPS57114-Q1 has the external compensation net like TPS54620, so paralleling TPS57114-Q1 is better than TPS62810-Q1, but I can't guarantee its performance can meet your requirement, because we have not evaluated this design.
Kevin
