Other Parts Discussed in Thread: UCC27525
Hi
I'm designing a synchronous CUK converter and I want to replace the rectifying diode with a P-channel mosfet so I will have a N-channel mosfet and a P-channel mosfet. I want to use LM5111 gate driver ic to drive the switches but based on the datasheet, this ic has been designed to independently drive two N-channel mosfets. My question is that is it possible to use this gate driver ic (LM5111) in my application? Is there any way for this gate driver ic to drive a P-channel mosfet? If so, what kind of considerations should i take into account? Furthermore, using this gate driver ic (LM5111) , is there any way to program the dead time externally? As this ic does not have a programmable dead time feature. The files attached below are the datasheet of the mosfet that i'm using and the power stage schematic.
