It is developing products using LP5024.
I'm making a driver by looking at the example file here, and I have a question and leave a message.
I'm looking for a way to turn off all or some LEDs after using the RGB LED. Can I use the LED_Global_Off located on DEVICE_CONFIG1 Register?
And how do you set it up when you want to express different colors out of 7 LEDs?
ex)
LP5024_Mode_Select_Normal();
LP5024_Device_Config1(0x3C);
LP5024_LED_CONFIG0(0x01);
LP5024_Bank_Brightness_Set(255);
LP5024_Bank_Color_Set(0,255,0);
LP5024_LED_CONFIG0(0x02);
LP5024_Bank_Color_Set(255,0,0);
LP5024_LED_CONFIG0(0x04);
LP5024_Bank_Color_Set(0,0,255);
If there is an effective control method, I hope you can show sample reservation.
I wish you a happy day again.
