TPS40210: Is the Equation 55 correct?
Part Number: TPS40210
Other Parts Discussed in Thread: LM5155
Hi
I have an question about TPS40210 Datasheet equation.
The equation is from FET switching power loss.
 FET current(Id) of Boost convertor is Vin +/- 1/2 x dIL.
I think, we should calculate by Iin instead of Iout.  Is it correct?
If it is correct, In case of the boost rate is high, it has big impact for customer calculation. I hope datasheet correction.
Could you please check it?.
Muk
