TPS2121: Current limit question
Part Number: TPS2121
Hi team,
If the customer doesn't need current limit function, how should the customer do the ILM pin?
Yoshi
  • Hi Yoshi,
    Thanks for reaching out on E2E!
    The TPS2121 should have a resistor connected to the ILM pin. If current limit is not required, you can connect an 18.7k to raise the current limit to 5.2A typical, or to a higher value.
    Arthur Huang
