Other Parts Discussed in Thread: BQSTUDIO, TIDA-00792, , BQ78350-R1
I made my own BMS using "Multi-Cell 36-48V Battery Management System Reference Design TIDA-00792" reference design and my design is nearly the same as the reference pcb. My battery management system (BMS) is not connecting the bqStudio software. When i measure the Regout (VCC) output of the BQ76940, i see that it has NOT VCC output required for supplying BQ78350-R1 and its voltage is zero. However, 15 series cells are connected to BQ76940.
Do you have any suggestion for solving this problem?
Yusuf KAYA
