Other Parts Discussed in Thread: BQ76200
What happens if you connect power and load with all enable pins in a float state?
Hi User,
The BQ76200 enable pins have a 1M typical pull down, but the test condition is with power and the pull downs have a wide tolerance. Depending on your board layout there could be crosstalk to the signals for the enable pins and you might see a transient on the pins. Since the charge pump takes some time to start, transient output on CHG and DSG is not expected.
