Simple Switcher - Negative Input & Negative Output?
Other Parts Discussed in Thread: LMR16006
Can something from the simple switcher line (ex. LMR16006) be utilized to produced a regulated negative output from a negative input? If so, is there documentation addressing this? If not, is there a switching regulator that is recommendable for this function? My project starts with a negative linear power supply and I need to regulate a node with high enough current and drop that makes a linear regulator a poor option. Ultimately, I'd rather not run my rail through an inverter and then invert that again at the switch regulator. Thanks
