Other Parts Discussed in Thread: BQSTUDIO, BQ34110, EV2400
When I try to execute commands to the board such as UNSEAL_FULL_ACCESS the log panel states Result: N/A and Read Addr: N/A. Any suggestions?
Ron
Ron
The unseal and full access commands don't return any result. The results will be seen in the resetting of the SEC1, SEC0 bits in Operation Status. Please check if bqstudio is up and reading all registers correctly. If the registers read correctly, your commands will work.
