Part Number: TPS25940
Hi Sirs,
Sorry to bother you.
Could you help review TPS25940 schematic as below?
Any suggestion are welcome.
Hi Sirs,
Hi Lin,
Looks fine.
Few comments:
Rakesh
Hi Sirs,
Thanks for your reply.
Actually we use TPS25940 for general load switch application, other functions only use the current limit...
Could you help double check the unused features, whether the pin is connected correctly (floating, connect to GND or connect to Vcc)
Such as OVP.. (tied to GND ... directly connected to GND or through the resistance, if through the resistance how much resistance value)...
Hi Lin,
Please do the following for the unused pins
Rakesh
