Customer is using TPS61169 and asks if the efficiency would increase or decrease if they change Rset value from 10.2ohm to 5.1ohm to 3.3ohm. Will there be an obvious efficiency difference with these Rset values?
Or, it would depends on the WLED implementation in their circuit? Currently they implement 10 LED in series, and the LED spec is as attached. Please share your inputs.EAHE5630WE03.pdf
Antony
