Please help to suggest a charger which can fulfill the condition as below, thanks~
1. Battery would be 4sXp.
2. Charging time requirement : 300 Watt hour battery in 1.5 hours.
All of our 4S chargers can be found in the link below. However, i'll need some more clarity on your required charge current
To summarize, you battery termination voltage is 4*4.2V = 16.8V and your A-hours are 300Whr/16.8V = 17.9Ahr. For 1.5 hour charge time, you need more than 17.9Ahr/1.5hr =11.9A charge current. If you have at least 19V power source for the charger, you could use the BQ24610. To get the high charge current, you will likely need to add FET gate drivers.
Jeff
