Hi Team,
Is there any spec of sequence about VCCX and VIN?
For reducing power consumption, I'd like to use external supply for VCCX but this maybe applied faster than VIN.
In this case, Is there any concern?
Kotaro Yamashita
Hi Team,
Kotaro Yamashita
Yamashita-san,
Most applications use VOUT for VCCX so this is not an issue. We typically recommend that the part be powered on before applying any external voltage but I will need to double check for this case. I'll reply with a confirmation in a day or two.
-Sam
Yamashita-san,
Confirmed. VIN should always be above VCCX at all times to prevent reverse conduction.
-Sam
