Part Number: TPS3700
Other Parts Discussed in Thread: TLV809, TPS3840, TPS3510, TPS3710
Hello team,
I would need a voltage supervisor to verify that the input stage with 12V..250V input rail is generating an output voltage of at least 7V (generally between 7 and 10V).
I noticed that the TPS3700 is a good candidate but too expensive, TLV809 is cheap but limited in voltage range (would avoid voltage partition if possibile); do you have any alternative?
Please let me know your thoughts.
Thank you and best regards,
Adrian
