Part Number: LM3549
Hello!
I am working with a customer who will be using this for a projection application like the chip is designed for. A few questions we have that aren't addressed in the datasheet:
- What is the minimum on time for any particular channel?
- When a channel is enabled, what is the typical setting time for the current to reach it's programmed value?
- Related to #2, is the setting time related to the previous channels current? (Meaning does it take longer when switching from a dim channel to a bright channel vs. when switching from a bright channel to a bright channel?)
Thank you! Let me know if you need any other info.
Ryan B.
