TPS25221: Asking for the recommendation on fault pin floating
Part Number: TPS25221
Hi Team,
Customer is looking for TPS25221 fault pin floating.
If customer is floating fault pin ,IC will be clamp current to current limit setting when OCP occurred ,right?
BR,
SHH
  • Hi SHH,
    Fault is just an indicator pin.
    As OCP, will current limit no matter fault floating or not.
    For TI's policy, I will first click resolved button.
    If you have any other concern, contact me any time.
    If you think resolved, please help click 'Issue is solved button'.
    Thanks.
    Ziv
  • Hi Zic,
    just to clarify here:
    do you mean, If customer float the fault pin,the IC will not be cutoff when OCP occurred ,it will still keep current limit value?
    thanks
    Patty
  • Hi Patty,
    I mean current limit function has no matter with fault floating or not.
    You can float fault or not float. Both operation will not influence current limit function.
    If you think resolved, please help click'Issue is solved button'.
    Thanks.
    Ziv
