Other Parts Discussed in Thread: BQ78350, EV2400, , BQSTUDIO
How can I confirgure BQ78350 -R1 without using EV2400?
Hi Ghada,
The BQ78350-R1 can be configured without using the EV2400. The details for the data flash are available in the BQ78350-R1 Technical Reference Manual: http://www.ti.com/lit/ug/sluubd3d/sluubd3d.pdf
However, if you are not very familiar with the device, I highly recommend using the EV2400 and BQStudio (BQStudio requires the EV2400). This will allow you to setup and and debug your application in order to determine your settings. I also recommend reading through the Gas Gauging section of the Using the BQ78350-R1 app note as there are some important steps to setting up a battery gauge for accurate performance: http://www.ti.com/lit/an/slua924/slua924.pdf
Matt
Hi Matt,
Thank you very much for your response.
I just would like to know example of boards where l can configure the BQ. Have you any idea?
Thank you
Ghada,
Hi Ghada,
There is a board made by TI for a different family of devices. You could maybe use it as a reference example. http://www.ti.com/tool/BQMTESTER
Matt
