Hi :
I have a question is about bq27426 GPOUT pin, i already check the SPEC and found this pin is a digit output pin,
my question is about the description from SPEC GPOUT pin, (If the device is in SHUTDOWN mode, toggling GPOUT will make the gauge exit SHUTDOWN.
It is recommended to connect GPOUT to a GPIO of the host MCU so that in case of any inadvertent shutdown condition, the gauge can be commanded to come out of SHUTDOWN.)
so if i will setting GPOUT pin to exit SHUTDOWN function in my project, can this pin be used as input function directly?
thanks !
