BQ40Z80: When I generate a.gg.scv file, how do I update it to another PCB board via SMbus communication。
Part Number: BQ40Z80
As the title,When I generate a.gg.csv file(by bqStudio), how do I update it to another PCB board via SMbus communication。
  • You can copy the same file to the new gauge using bqstudio. If you want to program the other gauge completely with fw to be identical to the first gauge, you should export the srec firmware file and then program that on to the other gauge.
