BQ76200: PACK pin connection
Part Number: BQ76200
I was looking through the datasheet of the BQ76200. I am designing a circuit using separate Charge and Discharge path. In normal circuits where the Charge and Discharge paths are linked, the PACK pin is connected through a 100R resistor to the PACK+ connector.
Question: Where do I connect the PACK pin of the BQ76200 in this circuit where the Charge and Discharge path is separate? Below is a screenshot of the example given in the datasheet.
