TPS73201-EP: About layout guidelines
Part Number: TPS73201-EP
I have a question about layout guidelines.
Most LDO datasheets shows the layout guideline "TI recommends designing the PCB with separate ground planes for VIN and VOUT, with each ground plane connected only at the GND pin of the".
The first picture is from datasheet layout guideline. the other one is a real project. my question is:
1. do I must follow the guideline in the datasheet?
2. does the real project I showed below(input cap gnd and output cap gnd very close) will works well?
