Dear team,
Is there a timing requirement for PIN3 IN and PIN12 DIAG_EN? Is there a problem with pulling PIN12 high and then pulling PIN3 high?
Thanks & Best Regards,
Sherry
Dear team,
Sherry
Hi Sherry,
Thanks for reaching out on E2E!
There is no timing requirement for PIN 3 (IN) and PIN 12 (DIAG_EN). They can both be pulled high at the same time. However, f you want to read the CS pin, you will have to wait the CS settling time from DIAG enabled/disabled which is 10us located in the timing requirements section (6.6) of the datasheet.
Elizabeth
