TPS7A85: Parallel LDO Reference Design
Part Number: TPS7A85
By referring http://www.ti.com/lit/ug/tiducs7/tiducs7.pdf, we can parallel TPS7A85 to obtain higher output current by inserting ballast resistor.
Can you give an example of Erfb (Maximum expected error of feedback resistor)? Is it in volt or percentage?
What if I choose to use the ANY-OUT version of TPS7A85 which do not have external feedback resistors?
Thanks.
