DCP020515D: Power management forum
Part Number: DCP020515D
Hi Team,
Please help us to check if DCP020515DU can support 500VAC based on EN 50124-1.
The test time is 60sec on EN 50124-1 500VAC, however, DCP020515DU only support 1-sec flash test.
Thanks so much for your help!
Andrew
  • Hi Andrew,
    You might have seen Section 8.3.1.4 of the datasheet that specs this part to have been tested at 1kVac for 1 second. I don't think this device will be able to handle 500Vac for 60 seconds.
    Jimmy
