Hello team,
Quick question, on the datasheet, section 8.3.3.1, it talks about ringing in shunt mode. Customer is not planning to use shunt mode, but LEDs will be detachable, so should we include the diode to VIN? I would think yes, but double checking.
("This protection must also be used if the LED load is ever to be connected or removed while the output is enabled")
Thanks!
