Hi team
My customer use TPS26600PWPR for 48V 2A use case. They found that after added a -2kV surge then it can not give output until restart or re-enable. Also, after surge and restart, the short circuit protection is normal.
Below are the test current waveform when added a surge test and schematic of this case. Mode pin is set to connect with RTN
Can you tell me why does this happen?
Thanks and best regards,
kelly
