TLV758P: tlv758p Vout drift issue
Part Number: TLV758P
TLV758P now use in Vin: 3.3V, Vout: 1.2V, but when Vin has voltage ripple, then Vout will drift to 1.9V, measure Vin ripple is about 70mV, my question is:
1. What is TLV758P Vin ripple tolerance? i didn't find it in the datasheet.
2. Why Vin ripple will cause Vout drift? any possible reasons?
Best regrads
Mason Liu
  • Hi Mason,
    We normally don't have a ripple tolerance speicification for LDO. However, you can use PSRR curves to estimate the voltage ripple at the output using the amplitude of ripple at the input and ripple frequencies.
    In order to identify possible causes on the shift, wil you provide a clean measurement that shows the voltage of Vin, Vout and FB pins?
    Jason Song
  • Hi Mason,
    Since it has been a week without a reply, we assume that this issue has been resolved.  If this is not the case, please feel free to reply.
    Jason Song
  • Hi Jason,
    Sorry for the late reply, the problem has been solved, thanks a lot for your help.
    Best regards
    Mason
