Hi Sir
I measure the POE Voltage about the initial power up status below figure. What is the status in blue line as the TPS23753APWR spec?
Hi Sir
Hello Chen Bogey,
Thank you for your question. If this is a type 1 PD, this might not be an issue, but if it is type 2 then this is a problem.
Additionally, I would like to know which PSE device you are using, and type 1 or type 2?
Thanks!
Michael Pahl
Hello Chen,
Thank you for your answer. Class 3 in this case will be Type 1 for your PD.
Do you know the type of the PSE?
Alternatively, do you know how much power the power sourcing equipment can send? 15.4W or 30W? Thank you!
Hello Chen,
Any update on this thread? We have not heard anything on your end in a week, i want to ensure you have everything you need for success in your project.
Michael Pahl
