LM53625-Q1: EN Pull Down
Part Number: LM53625-Q1
The DS says that EN should not be left floating. The bias current spec implies that the tendency will be for the pin to be justified low. My application has EN being driven from a CAN transceiver inhibit output that has a 3MEG-5MEG pull down resistance when in sleep mode.
Is this 3-5MEG enough or do we need to use a smaller dedicated pull down resistor on the EN pin?
Thanks.
