BQ27421-G1: Code examples
Part Number: BQ27421-G1
Hi team,
My customer is struggling with programming this device. Do we have code examples to support their SW development?
This is their feedback:
"I'm still working on the BQ27421YZFR-G1A. I worked through the documents and have to note that this module is so complex that we probably will not use it for the time being. The time for the software development is not enough, especially as we can't query some commands (DEVICE_TYPE). I just don't know how the right command sequence should be. There are also no software examples where you can see how it works. The I2C works and if I e.g. query Voltage or Temperature, I get meaningful values.
But other commands don't work at all (Control() e.g.)"
Thank you,
Franz
