There is start up waveform on datasheet P.27 Fig 50.
Why is there over 10ms delay from EN becomes high to Vout rise up?
Kohei Sasaki
Kohei Sasaki
Hello Kohei-san,
The difference you can observe, between Figure 48 and 50 is that VIN is already set and EN is then turned-on for Figure 48.
For Figure 50 VIN and EN are tied together, the system needs a longer time to set up before device start switching.
Thank you very much for your valuable feedback!
Dorian
Dorian-san,
Thank you for your reply.
From your answer, I could understood several internal setup time is needed from VIN is added until internal circuit becomes operable.
Would you tell me that setup time value? Is it about 10ms?
The start-up delay by EN control is on the datasheet EC table(200us).
Kohei Sasaki
Hello Kohei-san,
What you can see in the Datasheet are typical curves, so it is safe to say that you can expect a setup time value of 10ms.
Thank you very much!
Dorian
