Other Parts Discussed in Thread: LM5170
I am trying to simulate LM5170 reference design provided. I am assuming the LM5170 TINA-TI Reference Design provided under the design tab is same as the typical application found in LM5170 datasheet.
I am not able to understand why two extra MOSFETs are used as marked and an open voltage source.
I would like to simulate for one voltage source on one end and load (Resistor) at another end with an outer voltage loop control. The LM5170 TINA-TI Reference Design (.TSC) file seems incomplete or some other typical application design is provided.
