I'm using the "floating buck" configuration for a 6V 2.8A output in an LED driver. Above V(in) = 7.6V the output dims rapidly and flickers a bit. I have tried a wide range of Ccomp values, some of which cause intense strobing, and also tried different Rslope values. Grounding the OV pin does not help. I would like to continue this offline, Thanks.
