Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS54040A: TPS54040A
Part Number: TPS54040A
Other Parts Discussed in Thread: LMR33620
We are planning to use TPS54040ADGQR in our system to source FPGA power supply (3.3V @1A) which will undergo EMI/EMC testing (MIL-STD-461E grade with center frequency of 700kHz application). We came across the below E2E link and we found that the customer is facing noise issue at VHF frequency.
https://e2e.ti.com/support/power-management/f/196/p/302927/1057453?tisearch=e2e-sitesearch&keymatch=TPS54040A#1057453
Can you please clarify whether the issue got solved or do we need to choose any alternate part which has fixed switching frequency of >1MHz. If so suggest an alternate part with same BOM cost.
Thanks and Regards,
Hithayath Rahuman A
