Hi
I need typical drop for Vin=3.3V, Iout=100mA.
Table 6.5 electrical characteristic says 0,36V for Tj=25deg.C, but figure 3 shows about 0,23V for Ta=25deg.C
If Ta=25deg.C Tj is even higher, but drop is lower than for Tj=25deg.C, which makes no sense. What's true?
Hi Bogumil,
Please use the data in the electrical characteristics table. Ti does not spec a minimum for this value due to process variation.
For your power dissipation and thermal considerations, please use the tabulated data presented.
Thank you for choosing TI Power Switches in your designs.
