TPS61196: Multi-Chip Operation In Parallel
Part Number: TPS61196
Hello
When use 2pcs TPS61196 build up the circuit like Figure22:Multi-Chip Operation In Parallel, if OVP happened, it will trigger Slave's OVP first,then maybe trigger the Master's OVP,right ? So if the output only trigger the Slave's OVP not trigger Master's OVP, the all LEDs will continue operate normal ? unless trigger the Master's OVP, it will shutdown IC, so actually the Slave's OVP doesn't have significance of existence
