Other Parts Discussed in Thread: LM5121
Hi;
I set up a boost converter as recommended by the Webench using the LM5122 out 24V @ 5A;
After testing, I noticed abnormal behavior. The source supply can start with output shorted to gnd;
Also if the converter is switching input and you close the short to gnd, the converter will not turn off both mosfets.
Does anyone know if I can turn off both mosfets? Have you had the same problem?
Tks
