Hi Sir,.
BQ25713 I2C VIH is 1.3V,
Could it went I2C to DSP 1.8v without level-shift ,right ?
thanks
Hi Sir,.
thanks
Hi There:
I2C lines voltage is determined by the outside pull up voltage, I don't understand where do you get VIH 1.3V information?
If you use 1.8V pull up voltage, it should be compatible with your DSP.
Shishuo
Hi there,
We haven’t heard back from you. We are assuming you were able to resolve your issue. If not, just post a reply below or create a new thread if the thread has locked due to time-out.
