Other Parts Discussed in Thread: TPS23861
Dear all:
TPS23754 no output when use PSE TPS23861 power supply, output normal use 48V power supply, the follow is the sch, please help check , thank you!
Thank you for your question. The PoE team is currently out of the office celebrating the U.S. holiday of Labor Day. Please expect a response on Tuesday, 9/3.
Thank you for your interest in Texas Instruments PoE devices.
Brett Colteaux
Thank you very much for your question, and for providing your schematic. Can you additionally take a scope shot of VDD-VSS to capture detection, classification and startup?
Thank you!
Michael Pahl
You can measure it across C6 in your schematic. Thanks!
Michael Pahl
Hello Xiaowei Chen,
We have not heard from you in almost a week. Do you have any update on this post?
I want to make sure you have everything you need to be successful on your project, but since we have not heard from you we will close this thread in a few days. Please let us know the status of your project and we can continue from there.
Thank you!
Michael Pahl
Dear Michael:
I am a hardware engineer,I have a project now using this chip,I want to know what will cause the detection to fail?And what should I do to solve this problem?Thanks!
Since this is a new question, I'd appreciate if we created a new thread to answer this question.
To answer your question, there is a large number of things that could cause detection to fail. I would need more information to give you a more accurate answer.
In general, I would first start by ensuring that the proper detection resistor is in place. Then I would capture the detection waveform and measure the detection current to get a picture of what is going on. If you could please provide these in a new post I can continue to support you in this issue. Thank you!
Michael Pahl
