Part Number: LP5562SW-LINUX
Other Parts Discussed in Thread: LP5562
I have a question for LP5562 linux driver.
I read below documents.
kernel /Documentation/leds/leds-lp5562.txt
Following commands are to blink led for example.
echo 2 > /sys/bus/i2c/devices/xxxx/select_engine # 2 is for green channel
echo "RGB" > /sys/bus/i2c/devices/xxxx/engine_mux # engine mux for RGB
echo 1 > /sys/class/firmware/lp5562/loading
echo "4000600040FF6000" > /sys/class/firmware/lp5562/data
echo 0 > /sys/class/firmware/lp5562/loading
echo 1 > /sys/bus/i2c/devices/xxxx/run_engine
But it is continuing blink with permanent loop.
I'd like to set just 1 time loop from sysfs.
How should I set it on above sysfs ?
Hiromitsu
