Hi Team,
Could you tell me the calculation formula for Isc in TPS2595 datasheet 8.3.3?
Kenji
Hi Team,
Kenji
Hi Kenji,
Isc is a internal threshold to detect short circuit current. This parameter can not be calculated using a formula. As the parameter is not characterized we have not mentioned its value in the datasheet.
Is there any reason why you need this parameter ?
Hi Praveen-san,
My customer is trying to evaluate the boundary between short circuit operation and current limit.
In doing so, you need to know where the threshold is set.
Please tell me the setting Isc threshold.
Kenji
Hi Kenji,
The value of Isc is not close to the current limit. It is greater than 10A.
The reason why Isc is set much greater than Ilimit is because,
Hi Kenji,
Hope your query is solved. Please let us know if you have any other questions.
