TPS25982: Bidirectionality of TPS25982
Part Number: TPS25982
Good day,
I would like to inquire if the TPS25982 can conduct current in both directions.
The use case is to connect a LiPo battery on the IN ports and a powerpath battery charger on the OUT ports. Will the charger be able to charge the battery through the TPS25982? No protection/functionality required from the TPS25982 in the reverse direction.
Kind regards
