BQ40Z50-R1: Qa_max/Q_cell_n adjustment
Part Number: BQ40Z50-R1
Other Parts Discussed in Thread: BQ3050, , BQ40Z50, GPCCHEM, BQ40Z80, BQSTUDIO
Hello Everyone,
Our 4S4P LiFePO4 20Ah/256Wh SBS battery manufacturer from China has switched from bq3050 (NRFND) to bq40z50-R1 for the new lot we just received.
Those batteries were programmed as 128Wh batteries with a 0.5 current scaling factor. So that displayed % RSOC is OK, and the manufacturer can use the same firmware for their 512Wh batteries (40Ah > max 29Ah for bq40z50).
The problem is that we use smart chargers: reading the battery chemistry sets the charging voltage, and reading the design capacity sets the charging current.
Thus the manufacturer sent us a new .srec file along with the Unseal and Full access codes. We've been loading this new .srec file in all our new batteries, but some batteries won't display a Full Charge Capacity of 20Ah, although we discharged them to a few percent RSOC (Vbatt below 11V), let them at rest (Relax) a few hours, then recharged them to 14.6V. Of course we checked the current calibration, it's OK.
We put those under rating batteries on an electronic load after charging them to 14.6V, and indeed they displayed at least 270Wh capacity each.
What did we do wrong?
Can Qa_max be adjusted upwards by the bq40z50R1, or can it only be lowered ?
Will an export of the gg.csv from a "good Full Charge Capacity" battery, and then an upload to the under rating batteries solve the problem?
Please let us know.
Thank you.
Regards.
Matthieu
  • Hi Matthew,
    The bq3050 is very different from the bq40z50-r1. The bq0z50-r1 is based on the IT algorithm. The bq3050 is based on CEDV. For the IT algorithm you need to first calibrate, match the chem ID using GPCCHEM, then perform the learning cycle. Once this is done, the gauge will be accurate in terms of capacity. The gauge can learn Qmax up as well as down.
  • Hello Batt,
    Thank you for your answer.
    After loading the new .srec file into the bq40z50R1, I browsed through the registers and the dataflash.
    I found:
    - Design capacity = 20Ah. OK.
    -Qmax cells = 10500mAh, wrong. Changed to 21000mAh for each cell.
    -DetaQmax = 10%, Qmax Upperbound = 120%. Changed to Delta Qmax = 100% and Qmax Upperbound = 130%, to see. But it didn't, as Delta Qmax is relatred to Design Capacity, which is already correctly set to 20000mAh.
    - Chem ID = 0400. Haha... This is an A123 26650 LiFePO4 cell. But if a 36650 cell barely holds 5000mAh (Chem IDs 0418/0461, for instance) , how can a 26650 cell hold 20000mAh???
    A better alternative would be ID 0431 or ID 0462. I'll try with ID 0431, to see if that roughly solves the problem. Then I'll run the test as indicated in the GPC Guide and submit the .zip file to TI to get the most accurate ID.
    Attached in text format is the .srec file sent from China, obviously without any prior testing...
    Cannot attach the .srec file directly, as this extension is not accepted by the forum website.
    Could you be kind enough to have a look and tell me if my intuition was good?
    Here it is:
    S01C000000000000000000000000000000000000000000000000000000E3
    S328000040006B2FE2C1B8BFD4D24340BECD5E490000400000000000000000FFFFFFFFFFFFFFFFFFFF52
    S32800004023FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20616263646582
    S32800004046666768696A6B6C6D6E6F70717273747576777A7879303132333435040123456700004BD3
    S32800004069690000D24E010011546578617320496E737472756D656E74730000000A627134307A35D2
    S3280000408C302D523100000000000000000000044C69464500000000000000000000000000000000E7
    S328000040AF00000000000000000000000000000000000747000000000000000000000000000000009A
    S328000040D20000000000000000000000000000000000000000000000000000000000000000000000C5
    S328000040F5000000000000000000000055052A001F001F001D001E0022002200260028002B002D00BB
    S328000041182C0030003A00CD02FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34
    S3280000413BFFFFFFFFFF550528001E001E001C001D00210021002500270029002C002B002E003800F5
    S3280000415EB602FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF554B
    S328000041810528001E001E001C001D00210021002500270029002C002B002E003800B602FFFFFFFF4B
    S328000041A4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55052A001F001F4C
    S328000041C7001D001E0022002200260028002B002D002C0030003A00CD02FFFFFFFFFFFFFFFFFFFF4F
    S328000041EAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F00230023002100220026E6
    S3280000420D0026002B002D00300033003200360041002A0300000000000000000000000000000000D1
    S3280000423000000000000000000000000000000000FFFF2F002300230021002200260026002B002D0B
    S3280000425300300033003200360041002A03FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F
    S32800004276FFFFFFFFFFFFFFFFFFFFFFFF2F002300230021002200260026002B002D0030003300323A
    S3280000429900360041002A030000000000000000000000000000000000000000000000000000000058
    S328000042BC00000000FFFF2F002300230021002200260026002B002D00300033003200360041002A49
    S328000042DF03FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF600073
    S328000043021E00000004290429042904290429000006420E420E420E420EC800FFD86DCE05000C0062
    S32800004325010DFBD84CCD000000000000000000000000000000000000000000020000000000000073
    S3280000434800000000000000000000000000000000000000000000000000000000000000000000004C
    S3280000436B000000000000000000000000000000000000000000480F8E0EB00FB5179F01050292066C
    S3280000438E0000F2153427DDD8E5D849CD29130829112B020006001400020000000000000000000055
    S328000043B10000000000000000000000000000000000000000000000000000000000000000000000E3
    S328000043D4000000001A0000001200010002079F01000000005B010000000004000300520100000034
    S328000043F700040100000000000000000000FF01000000FF030000000401000000040300000000008A
    S3280000441A000000000000000000000000000000000000000000000000000000000000000000000079
    S3280000443D000000000000000000000000000000000000000000877D0000100800D51908F901050243
    S32800004460B607B517A72605000000FD0BE40BE80B96089608B23FD63FFF3FB53F0000002010001238
    S328000044830010071780001DEF00000271FA8566870000000000000000000000000000000000000077
    S328000044A600000000000000000000000000000000000000000000000000000000FC08001F00E1FFEA
    S328000044C90000000000000000000000000000000000000000000000000000000000000000000000CA
    S328000044EC0000000000000000000000000000000000000044FFFFFFFF444444FFFFFF4444FFFFFF19
    S3280000450F4444FF4444FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92
    S32800004532FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83
    S32800004555FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60
    S32800004578FFFFFFFFFFFFFFFFF803FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40
    S3280000459BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A
    S328000045BEFFFF91D058180000581886D4C64AC2B42B6E7C034801A3FD75F65812B72DB72D00000017
    S328000045E10086D4C64AC2B42B6E7C034801A3FD75F65812B72DB72D00000000EF404040400A0A40F0
    S32800004604404005960400015802000000000000000000000000000000000000000000000000000013
    S32800004627000000000000000000000000000000000000000000000000000004710D330D200D180D56
    S3280000464A140D110D0F0D0D0D0C0D0B0D0A0D080D020DF80CF00CEB0CE70CE40CE10CDE0CDC0CDAF3
    S3280000466D0CD90CD80CD70CD30CCD0CC30CBC0CB40CAC0CA40C990C890C810C6C0C370CDF0B450B39
    S32800004690A1091A0DD70CDBFDE90193026102400230022002110200021E02100277024403C403939C
    S328000046B30378037F03B403D603E803210461047B04850437049002B200A2009200C800C8009200FC
    S328000046D683002801420174FF5DFC5FF8AAF0AB004C006C006E0077006B0054004A00320028001A4A
    S328000046F9000D000C00FAFFEFFFCBFFB2FEDAFED5FEC6FEBDFEBEFEA7FE8DFE7CFE68FE3FFEF1FDFD
    S3280000471CCCFDF7FD70FF000000000000000000000000000000000000000000000000000000000048
    S3280000473F00F4011E580250460A0032021E030F2003020F040476FE54E76400504650460A90016466
    S3280000476200000019C0555A3700010014000500140023030807255A0A3C600A828025012C01C409BB
    S3280000478528F401C800201C32201CE803E8030A00504684038043900114C8008813960032000000EC
    S328000047A832FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F000830AC0D1E5507000003
    S328000047CB02009600AF0016EAC409D0073CD0070A34080000C40914000A3200C2010514000A14A0CA
    S328000047EE051E003C1000E80300046400280A0019324B640A0019324B64DE03A6040A008100312049
    S32800004811204E00640032500ACC0C9CF00AB80B0005AC0D480D645F540B1C0C0608420EAC0D645FB8
    S32800004834FE16FF0101010000000000000000E803646401030C0500FF3F010C600903280A60090328
    S32800004857280A3C0F3C0F3C0F3C0F02100E100E100E100EA86105307503000005589E05D08A03004D
    S3280000487A000500010101050A0578050A0578580203F4018A0203F4012003038A0200000332009C9C
    S3280000489DFF03CEFF0AD007080708070200C409D007F0D202002C0102005AF4011E0CFEF4010264B9
    S328000048C000023200020A00025F100330DC0505041005A86105D08A05BC0205E80305B80805C8003F
    S328000048E3C80096000278001402B80B0A00F401056400B80B64002003052C01900102000002C800BA
    S328000049060538FF05C8000A64020564050588130500000C1419373C01420E840060010801420EBC05
    S3280000492907A40FB00B420EF403BC07D805420ECC098811C00D58002C0000000000800C420E0032EC
    S3280000494C4B01E8034000F401280101C00D420E0704070371FA856687649808FA64006400140001C2
    S3280000496F010A07AE00AE0032080700003CFFFFFFFF1400A049C848A6010400684AC848A601020015
    S32800004992904AC848A6012C00A44A4B489E0100129503CC48CE48AE0101139303CF48D148AF01848E
    S328000049B513FD01D848DA48B0018C13AB3FF948FB48B1018B13AB3FF048F248B20111128103074972
    S328000049D80949B3011013810304490649B401167D1C0080001249B50199139B4213491549B601146A
    S328000049FB0EA70000000D49A700150EA60000001049A60002138103D248D448B70103128103D548DC
    S32800004A1ED748B8011C12C903DE48E048B9011D12CB03DE48E048BA011E12CD03DE48E048BB011F66
    S32800004A4112CF03DE48E048BC01176D1C0040000000000086130802DB48DD48BD01931391420A4908
    S32800004A640C49BE010A120E4301490349BF0188138942EA48EB48C00188038142E8480000000087C1
    S32800004A87136442E548E748C101C91351423C420049C201C9035142274200000000001295034F482D
    S32800004AAA5148C301008395035248000000008D13FD018D488F48C4018D82FD019048000000008C51
    S32800004ACD13FD0188488A48C5018C82FD018B480000000041139303503F6148C601418293035C3F8B
    S32800004AF000000000021381036A486C48C7010292810370487248C8010412810373487548C90104A3
    S32800004B1393810379487B48CA01066E1C00080000009B01086E1C00040000009C010A6E1C00030015
    S32800004B3600009D01070E9B0100007C489B01090E9C01000080489C010B0E9D01000084489D010667
    S32800004B5991000000007E48CB010891000000008248CC010A91000000008648CD0107FD5D490400FB
    S32800004B7C7F48CE0109FD5D4904008348CF010BFD5D4904008748D0010E12980054485648D1010E0B
    S32800004B9F839800574800000000031381036D486F48D2010392810370487248D301051281037648A2
    S32800004BC27848D4010593810379487B48D5019013080292489448D60190820802954800000000117B
    S32800004BE50BA800A14800000000118FA8000000000000009713683FBC48BE48D70117928103BF485C
    S32800004C08C148D80158138F03E443B948D90158828F03FA43000000009913683FC248C448DA01199C
    S32800004C2B928103C548C748DB019A12FD0197489948DC019A83FD019A48000000009B12FD019C487F
    S32800004C4E9E48DD019B83FD019F4800000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B
    S32800004C71FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D
    S32800004C94FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A
    S32800004CB7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7
    S32800004CDAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4
    S32800004CFDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1
    S32800004D20FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D
    S32800004D43FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A
    S32800004D66FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47
    S32800004D89FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24
    S32800004DACFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01
    S32800004DCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE
    S32800004DF2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB
    S32800004E15FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97
    S32800004E38FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74
    S32800004E5BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51
    S32800004E7EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E
    S32800004EA1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B
    S32800004EC4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8
    S32800004EE7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5
    S32800004F0AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1
    S32800004F2DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E
    S32800004F50FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B
    S32800004F73FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38
    S32800004F96FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15
    S32800004FB9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2
    S32800004FDCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
    S32800004FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC
    S32800005022FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88
    S32800005045FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65
    S32800005068FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42
    S3280000508BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F
    S328000050AEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC
    S328000050D1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9
    S328000050F4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6
    S32800005117FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92
    S3280000513AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F
    S3280000515DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C
    S32800005180FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29
    S328000051A3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06
    S328000051C6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3
    S328000051E9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
    S3280000520CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C
    S3280000522FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79
    S32800005252FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56
    S32800005275FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33
    S32800005298FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10
    S328000052BBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED
    S328000052DEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA
    S32800005301FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6
    S32800005324FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83
    S32800005347FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60
    S3280000536AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D
    S3280000538DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A
    S328000053B0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7
    S328000053D3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4
    S328000053F6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1
    S32800005419FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D
    S3280000543CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A
    S3280000545FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47
    S32800005482FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24
    S328000054A5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01
    S328000054C8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE
    S328000054EBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB
    S3280000550EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97
    S32800005531FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74
    S32800005554FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51
    S32800005577FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E
    S3280000559AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B
    S328000055BDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8
    S328000055E0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5
    S32800005603FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1
    S32800005626FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E
    S32800005649FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B
    S3280000566CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38
    S3280000568FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15
    S328000056B2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2
    S328000056D5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
    S328000056F8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC
    S3280000571BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88
    S3280000573EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65
    S32800005761FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42
    S32800005784FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F
    S328000057A7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC
    S328000057CAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9
    S328000057EDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6
    S32800005810FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92
    S32800005833FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F
    S32800005856FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C
    S32800005879FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29
    S3280000589CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06
    S328000058BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3
    S328000058E2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
    S32800005905FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C
    S32800005928FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79
    S3280000594BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56
    S3280000596EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33
    S32800005991FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10
    S328000059B4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED
    S328000059D7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA
    S328000059FAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7
    S32800005A1DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83
    S32800005A40FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60
    S32800005A63FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D
    S32800005A86FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A
    S32800005AA9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7
    S32800005ACCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4
    S32800005AEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1
    S32800005B12FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D
    S32800005B35FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A
    S32800005B58FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47
    S32800005B7BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24
    S32800005B9EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01
    S32800005BC1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE
    S32800005BE4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB
    S32800005C07FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97
    S32800005C2AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74
    S32800005C4DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51
    S32800005C70FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E
    S32800005C93FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B
    S32800005CB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8
    S32800005CD9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5
    S32800005CFCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2
    S32800005D1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E
    S32800005D42FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B
    S32800005D65FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38
    S32800005D88FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15
    S32800005DABFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2
    S32800005DCEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
    S32800005DF1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC
    S32800005E14FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88
    S32800005E37FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65
    S32800005E5AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42
    S32800005E7DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F
    S32800005EA0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC
    S32800005EC3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9
    S32800005EE6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6
    S32800005F09FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92
    S32800005F2CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F
    S32800005F4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C
    S32800005F72FFFFFFFFFFFFFFFFFFFFFFFFFFFF6B2FE2C1B8BFD4D24340BECD5E4900004000000000C5
    S32800005F9500000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02
    S32800005FB8FFFFFFFFFFFFFFFFFFFFFFFF33050000CBFAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0
    S32800005FDBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
    S30700005FFEFFFF9D
    S3280010000019000D001000130016009B459F9B569E9BBF9E9B6B9E9B099FFC6020000AF6089F3833ED
    S328001000239F8D9FA620901C34257C039F530024DE0025DE00265C4C9F6200247C03257C039F620081
    S328001000469F1E949FA03299CB705000EC94F640ED4087F59A40805000EE96EC94EC5587F49A980898
    S32800100069980F9815981C982322F52924000A6304FD22400F248A0973FD22AC002415096304FD229B
    S3280010008C5E302404096304FD22551A24E40873FD3F24938060FEF0002102009FD8912F9A32210EEE
    S328001000AF009FC8912690806001F1832102009F0192729F278CA62AA623C37F729F2E8BE6EA0088FF
    S328001000D20C21007F9F7C8D2108009FD891E6AA2E90062104009FD891E6AA1093C79F472E99C2E4A2
    S328001000F59407A30740A100088413A40800A642240F4943009C47D3008403A40801A642240E49432A
    S32800100118009C47D300840AA102A79005B282A3A720A64224114943009C47D300840AA102A6900522
    S3280010013BB282A3A6209A3FA102A6241049E052008808B292A3A6209F668A2F9A3F9FD189A623D2B5
    S3280010015E008410A102A7240D49E052008805B292A3A720A6322F9A3FA1000890069F5701A40800E1
    S328001001812F9A3FA4A600215E499FA08A2F9A24D3470200A100D0C002900332981E247D030102EA1A
    S328001001A4E188120112EAE1880CA10295E909B37032B4749803220100A6429A3D3F9F7194F6159F84
    S328001001C74694D2008404F95090129FD28FEDC1900B249E016001F10F6002F3D02F2D9A9BE3889AB8
    S328001001EA9B9E8E9A245B494302C23FE73840A603B3129A247D0301002054F5E8219A247D03012E82
    S3280010020D2054F5E8219A3D3E3FA704240040060EA104C8CC04840524C0400601CC02900431329881
    S328001002303CA630A614A6159C5211C012C2250040F42652F661A630A614A6159C52F616F6270150A0
    S32800100253A630A614A6159C523A39F661F6729C4CAC3A3901C402C69C41ACAC2F2E2D9AC2F124C083
    S32800100276474007C0019004E612029AE612049AA2A03FA10A94E6AA0190039F7202E6AA029003E640
    S328001002991202E6AA049003E612012FA00A9A245B494202C203B2929A3F2400400008380006389C19
    S328001002BC46AC9F0698200080E9C084032101802F9A3D3E3FA702A62A7BED66F664203701E82401DF
    S328001002DF0E9F13029FB10211C0F612F66120B903E8219FDB93ED61E96120FC45E82546417702C0EA
    S32800100302201301E8219C3BAA2F2E2D9A3FF614F801840133F6419C3B2F9A3D3F257D0333026C212C
    S32800100325FB009C3B33024621F7009C3B33025421FF009C3B2F2D9A3FA41D00322181039FDB9332D7
    S328001003482183039FDB933221A9039FDB939F1C032F9A3DA2C03F247D030204A1061B245B49F4E24D
    S3280010036B0F800731190B6C01984AF4B10DE9E28C0731190B6CFF983CD6FF841BEAB1F4E1118C4DAD
    S3280010038EF5910B190BB3B3B2E2B3B3B2E2E0521388479839D6018435F4E2118C30F5910B190BB30D
    S328001003B1B3B2E2B3B3B2E2E05214882A981CBC569018257D03026A21A9039FDB9302442183039FF5
    S328001003D4DB939F1C03A6C6A31B60D6018408A4750098037C99D92FA00C2D9A3F240E044000840456
    S328001003F763049801739F341366089C4F24DB03F4C9012F9A3D3E3FA701A62AA1001E90046204980F
    S3280010041A017252C0247501E0600180064003C008900742C0E6120852C043C0A6A2E622E89F3413EC
    S3280010043DA6AC7DEE65203901E82524DB03F4C900F4D2026608208000E82130E8329C4E114040C0DA
    S32800100460C00890109FDB88EE65203701E82566089C4E114EEE64203901E8240100B360800131A963
    S328001004832F2E2D9AA2B03E3FA70B240040000010C084082148019F319011C09FA70252C67B313202
    S328001004A611C212C4984AA6B29F0B0411C702C09C43F421C2F43AC411C212C402C701C09FCA971106
    S328001004C9C9A6BC7DEE6102C920B103E8219FDB93EE61E96120FC45E82646817702C9200301E82110
    S328001004EC9F0E03A6B29FCD02BB9BE05BC683B19807A6B29F0B04BB9BE65B0397F401C202C49F3AAA
    S3280010050F98F61221C1039FDB9324FC4546077724B1030210212B019F0E03A50B2F2EA00B9A3D3F43
    S32800100532A70424DB030100020211C012C2240E0440008403359806245B494A0C7B21EF009F3413DA
    S328001005553A39F652F681E62204B3D39C3C6604F682E62404B5D521DB039FB393ACAC2F2D9A3FB333
    S32800100578608001319F85982F9A3D3FA1020984059F3005986E240040D201843301028406215E012D
    S3280010059B9F3190F61562EC9FEF03243701110AF6529F7605F61221C5039FDB9324FC4546057724BB
    S328001005BEB1030214212701983101048406215C019F3190F61562ED9FEF03243701110CF6529F76FA
    S328001005E105F61221C3039FDB9324FC4546067724B10302122123019F0E03A10309B392A30920D346
    S32800100604028403A409002F2D9A3FE4920AA30A20D2049403A40A00A1020A840462E5981AD2018465
    S328001006270462109812D20284046231980AD2039004627398026252240E04400084046304980263FB
    S3280010064A029F341366089C4EF613A1040AF6319F4E122F9A3F729FB88C240E044000840F9F8105CE
    S3280010066D9F81059F0D069F0D069F0D069F87049F8105A1021E9FB88C9F0D069F0D069F6B892F9A66
    S328001006903DA2C03FA10AC87B24C0404C00E6AC029026E6AA028424A1021D73E96420D103E82401F0
    S328001006B3009C3A245B49F4E10D940AE460958805E6AC0484037498026401BBB3BAE2B3B3B2E2E610
    S328001006D64201C201B254900FD400900521000498032104049F80892FA00C2D9A3D3E3F24D10305ED
    S328001006F902A6B0A61CA61D0100A630A614A615E925EA360104A630A614A615E925EA360106A63016
    S3280010071CA614A615E925EA36E6ED008808200300E82530E8366602F651F6629C4EF6169C3A240623
    S3280010073F464A007BEDE1880136F6622181039FDB93A1001D841D24FC45460077247D03020421F79C
    S32800100762009C3B21F7009C3DF6122183039FDB932F2E2D9A3D3E3FA707245B49420052C64F01429A
    S3280010078502A62EE60E80A629E6094025B10315C03226FF7F16C46801337D5DC3317A5AC240C6B8D7
    S328001007A8009049A6F0B800901FE65E00900EF61605C0F42656E09BC25BC2980805C00656E9E694A1
    S328001007CB28F635982806C0059606C4EDE6940215C4EDE28802F652E659009009EB25E09DC35DC38C
    S328001007EE9806EBE58C02F635F616F491C0E99111C020BB03E9C09008B868F653F661999721AD032F
    S328001008119FDB9302C421AF039FDB93245B494002C040900F43C3D3009009F65144C3759C48F6152E
    S3280010083424FC45460877F652212F019F0E03212F019C3DF612217D039FDB93245B49E06002800F9F
    S3280010085746C2D6009009F661A664759C48F61624FC45460977F6622133019F0E032133019C3DF67F
    S3280010087A1221AB039FDB93AF2F2E2D9AA2A03FFC6024D1034A097421DA039FD193FC50A6A22FA084
    S3280010089D0A9AA2A03F73E961A62AE60A1F64202106209F858D64222108229F858D62029F738DCA96
    S328001008C0208403E61A0164202106009F858D64222108009F858DA6A22FA00A9A3F245B494002C0D7
    S328001008E304900CA41A1F2475016001F1009822A1021A9F9F08A31A20D20F84112475016001F10077
    S3280010090660F7F27960DFF0039811D210900372980C24750160FEF0009F524162012F9A3F245B4943
    S328001009294202CA24D0249005A416009809A102169F9F08A316202475014403A10379CC209030C33A
    S3280010094CF7A379300A179017E49219A31920D2EF940DA41900EA811917FB8403A4160FA10016D070
    S3280010096F0F844224750160DFF0039839CB089012A102199004B282980EA642E61220520398082425
    S32800100992D347421EA31920311917A10016D00F841124D347011C1917A419002475016020F1032FC5
    S328001009B59A3D3E3FA70B9FA70252C63111C424FF7F14C2986FE089C659C659C97252CAF466C9EE0F
    S328001009D866F661200301E8219C3DF615F464C914C7F612F641208503E8219FDB93247D03F80484FB
    S328001009FB0336980BF661201301E8219C3DF61601C2EDE1940215C204C4EDE4880215C4F66201C754
    S32800100A1E209703E8219FDB93F652F6619F1A95F61201C7209F03E8219FDB9349C6E65900878A02D9
    S32800100A41C22195039FDB9302C42193039FDB932127019C3DF612218F039FDB932123019C3DF6125A
    S32800100A64218D039FDB93212B019C3DF616F612217F039FDB93F662247D0301049F1A9511C0F61289
    S32800100A8721A7039FDB93A1001D843724FC454A007BA6A6A6B7F66221FF009F0E0321FF009C3DF6FB
    S32800100AAA122191039FDB93A6A6A6B702C021FB009C3B21FB009C3DF61221A9039FDB93A50B2F2EFD
    S32800100ACD2D9A3D3F24C047400BC002902C25D347247D030118F4E148881F24B2020100F4E14A8879
    S32800100AF01524DF03F814840EA100B2C00190072475016040F1032475014002C00184064003C040D1
    S32800100B13901BA1061F24D347441975A66273E9E288046401980BB692A31F209803A41F00742475B9
    S32800100B36014001C010900525D847980325D547247D030118247501F4E1408C1A6004F101A102159F
    S32800100B59E052428807B292A31520980EE46095800D980760FBF001A41500D4009026257D03015212
    S32800100B7C24D347F4E10C8819014430E8E18C12729F378E9FD1369F57939F898C62FF9F6D982F2D8A
    S32800100B9F9A3F9FB6099F760724D10342089FEB3FA1001D84729F6D8CA31C20247501DA0088066032
    S32800100BC220F100980460DFF0009FD6429F50449F3341249E014001840C40038408400584044007AA
    S32800100BE590092475016008F101980724750160F7F0019F5F90247501D20090066002F102980460E8
    S32800100C08FDF002247501A1001E90066010F103980460EFF0039FCF0A9F75019F4B332F9A3D3FA103
    S32800100C2B0094C010901B2475014000C00190124003C020840C3224D347A1001FE05018940322015F
    S32800100C4E00A645245B494403D2009029D500840FD201900BD2038408247C03440098017473A64262
    S32800100C719FB38DA624217C039FD193247C034B0098B2D500841525D347247D030118F4E1428C0EAB
    S32800100C94A10015E050448006C4FED500843B24C0474207CA109007A10092C010842BCA089007A180
    S32800100CB70092C0208420CA209007A100B1C0088415245B494002C0049010CA40840C247501E060D8
    S32800100CDA018004C4F1980EA10092C0019007A6429F7202A624CC029010247D030102245B49F4E1FF
    S32800100CFD0A8803E61408A6429FEE019F850224C0474007E70840A61AE60A01A6A39F7341A62BA626
    S32800100D20A39FFB41A62AA624217C039FD19363CFA6A29FE88C247501E6AB0184066020F10198048E
    S32800100D4360DFF001247501E6AB0684066040F101980460BFF001A1001C90069F4B8AA41C002F2D6B
    S32800100D669A3F62039F280C9F1C032F9A3D3E3FA7089F8C8E24370111009F130211C012C2A1021D14
    S32800100D89A62A7B200200E8E59403729802B292A31D2001C002C29FB102A10A1D7BED65F612F65175
    S32800100DAC20D103E8219FDB939F900601C002C29D4BA29C3A2406464A027B0A0F0B11EDE18C5E3B8B
    S32800100DCF3A01C402C69C40ACF623F612190F1B11F5910D190D2406460703EFC188043132984DF779
    S32800100DF20042F70000F621F6329C46ACF615F626F671329C533A39F651F6629C4CAC9D4BA29C3A0D
    S32800100E152406464A017BEDE18C0431329804090F0A11331B0D980C3B3A01C402C69C40AC341C0DF8
    S32800100E3833341B0F1C11240040000C38000A389C46AC11C412C62557014D443A39F6519FA79F44AD
    S32800100E5B44E5C4D421D9039FD1937601C802CA9FD94BFC6024D1034408E0240921DA039FD193FC25
    S32800100E7E50ACA82F2E2D9A3FE49214A31420FC60245D015200A102135201231600223701215F0186
    S32800100EA19C3FFC50A102132475014002C020900CD2029015A413029FD28E980AD2019009A41301EC
    S32800100EC49FC28E9F90062F9A3F9FEB8D9F5E069F720D9F850E9FF2069FDC089F25099FA00B21000D
    S32800100EE7049FD8912F9AA2A03FA62A322101049FC891210C0C9F8089E65A0090039FC28E21EF0E9B
    S32800100F0A9F34132FA00A9A3F62019F280C9FBF01A41D039FCC0E2F9A3F249E014009840C400B84D1
    S32800100F2D08400D8404400F900864012131119F45322F9A3D3F62019FED0E9FDC08250E04E080404D
    S32800100F5090162148449FEF444040D00290059F110F98089F670D98039F5701A41B006402210E0400
    S32800100F739FD1939F220F729F280C9FCC0E9F843C9F5A0399EE3F9F708A2F9A3F9F7F8A2F9A3D3F05
    S32800100F962440440310257D0324C047E060078004025298020242A10095C001904924C047259E01DB
    S32800100FB94200E0024984154201E0024B840E4202E0024D84074203E0024F902724C047F4E2048C3B
    S32800100FDC09249E01400DC0039016A1002184119F8E0FA4210124C0474206A32020237236F6312F8A
    S32800100FFF2D9A3FA7122440444009840C400B8408400D8404400F90229F880F6410219E019C38642A
    S3280010102212F6819C38A4210060FDF2D0231200F6822140449F578FA5122F9A3D3E3FA716247501EC
    S328001010450100020211C012C2269100230300F662F681E62204B3D39C3FA103B153C70AB212C82585
    S328001010687D03230800228503F681E6220AB3D39C3F015011D2025212D4231600F6822152449F5744
    S3280010108B8F6403F6619C38A5162F2E2D9A3D3E3FA712214044F686259E01980FF6144040E01000B3
    S328001010AE5080EE96E991ED9520B001EDC087EA9F940F11D060FDF2D0231200F6822140449F578FB1
    S328001010D16002F3D0A5122F2E2D9A3FA716230A0022C703F684EC91E9919C3F9F014D230800F61265
    S328001010F4F681E6220CB3D39C3F247D03010411C0246002010011D4231600F6822168449F578FA549
    S32800101117162F9A3FA715F6819F458C231500F682217E449F578FA5152F9A3D3E3F62019F280C242F
    S3280010113A75016010F101A4210062829F378E62019FED0E2440444009841E400B841A400D841640F7
    S3280010115D0F84129F28369F4F359F3D109FDB109F1A119F98106002F3D09F3C03259E0126C0479881
    S328001011802F729F280C9F98109FCC0EA1001D841D9F4434408690169F678AD200900FA102209007C5
    S328001011A3B282A3202098039F880F9F5A03404987CD404B87C9404D87C5404F87C160FDF2D024750F
    S328001011C60160EFF001640121400F9F45322F2E2D9A3F729F280C62029F8B919F5E0662029F9491D2
    S328001011E99FA00B9F843C2F9AA2A03E3F729FED0E9F3C037A2675012101009F019260FBF083E65A3A
    S3280010120C009007A100B2C02090116004F1839FD711A4220124D3474A159002BA8A2100049FD89178
    S3280010122F99CF63019804B363A642B284D20087F6245B49A632E00201D200900262019A3D3E3FA756
    S328001012520B54CA24DB03F4C90111C254C87252C9F464C8203701E82402C2121645CAD500841C26E4
    S32800101275C04504C2F4E484880403869890028001C29FCA97F613F423829882216A019F319011C618
    S32800101298216C019F3190F61542CA9F3112D200900526E245980326C8450296840202C601988402AF
    S328001012BBF651250080F613F651F4C9C29C3702C2E9C212C00194049214C4F653E9C3F642E9C2F65A
    S328001012DE51F4C9C09C3703C4E9C3029201C09C37F6156605F612F6619FD997F613F6522100409C69
    S32800101301376604F612F661E6220AB3D39FD997F61301C8200040E821F6144414EA0A42CA73E961B2
    S32800101324EB2220C703E8219FDB93A50B2F2E2D9A3F9F47899F33892F9A3DB360800131F615EAE105
    S328001013479402F62524C0474008C0019029E460928824A100B1C002841DF70000F770FDF621A63050
    S3280010136AA614A6159C45AC66109C4EF612E9E59402F625F6512D9AD4009004E991E9919A3FA62355
    S3280010138D2475014200C27FE73880C080B012520024C047420CCA01901ACA02840972D300840262A3
    S328001013B001A623D30090026344644462089F858D2F9A3F247501E060008822247D03010424DF0330
    S328001013D330E8E194090118F4E12C800E98070118F4E12A8C0562019F8A132F9A3D3FE49225A32514
    S328001013F62024C047400BC0019014257501E06041800C24D347021A9005A100788405311923981174
    S32800101419D23B9410F591231923EA5180046001F142A4250009279004E9811927A10278D2FF9005F9
    S3280010143CB292A378209F3C469FF4009F64379FBE2B9F4D452F2D9A3FE460B180046480980174654D
    S3280010145F8021E5039FA0932F9A3D3FF61524C0474008C002901D2434484001C010841424750140A4
    S3280010148203C001840BE4A01B84060040EA509405F6519FDB932F2D9A3D3E3F25A804024421FB0368
    S328001014A59FDB93024621FD039FDB9344487521F1039FDB9324DF03021C01409F3D13F61624DF0302
    S328001014C8021E01429F3D13F615F66221F7039F6814F65221F9039F68149FC35724C0474008C00490
    S328001014EB901FA100B1C001901824DF03E060078806F8189009980A24DF03F81A8403A475012F2E22
    S3280010150E2D9A3D3E3FA70424DF034007E70802A61959C2A69421F7039F8113F614010011C044C2F6
    S3280010153121FB039F8113F61544C22111489F8113F61406006601024001C09FDB94A6247521F30393
    S328001015549F681476F66201C09FDB94F61221F5039F681424DF03431642149FBB5C42C29FCA5D2411
    S32800101577A804440B752107049FDB9324DF030126C28FC335A62DA63CA105B1CD409003E61D4044E9
    S3280010159AC221DF0355C39F8113F614010045C3E6AD409008F4E1C09403E61C02CD089005E4801B71
    S328001015BD903A259E014240CA0E84314042C010842B4244CA8184254046C003841F4248CA068419FA
    S328001015E02475014000C00190104049840C404B8408404D8404404F9003E61C40CD029003E61D2069
    S32800101603CD049005E4A01B9034259E014240CA31842B4242CA6084254044C001841F4248CA0984D5
    S32800101626192475014000C00190104049840C404B8408404D8404404F9003E61C08CD018415249E9D
    S32800101649014001C001840C4003C04084064009C0019003E61D10249E014005C0409008E4801B84B5
    S3280010166C03E61C80A6D4A6C52105049FDB93AC2F2E2D9A3D3FF61530E8E18C0521FFFF985924602F
    S3280010168F020700F4272830E8E78C033198492416490238F620E950940334980AF614EAC4EF54942E
    S328001016B202F674F6519C49200200E8518C04E9619810200800E8519405210A009804E991E991F6DF
    S328001016D5429C4466039C4EF653223C00EF219F94982F2D9A3D3E3FF615F626A664B360880521FF44
    S328001016F8FF981121F7039F8113F614EDB30200F6619F94982F2E2D9A3DA2D03F25DF034047E70866
    S3280010171B02A61D247D0301069F7F16F6122103049FDB93A6D362029FF350A6D6223C009FE916F687
    S3280010173E1221FF039FDB93A6D362039FF350A6D6223C009FE916F6122101049FDB930044F45062D3
    S32800101761940522010198032200012106049FA0932FA00D2D9A3DA2C03F24DF034007E70802A61C56
    S32800101784E65C009011247D03030222102724E90301009C37980524E70301009F7F16F61221EB036C
    S328001017A79FDB93A6C362029FF350F615A6C362059FF350A6C622100EED219FE91632200A00E851A3
    S328001017CA940322010021EF039FDB93A6C362059FF350A6C6223C009FE916F61221ED039FDB932F9D
    S328001017EDA00C2D9A3F24F2474000C0049010247D030104245B49F4E10F94039F2D2E2F9A3F249E60
    S32800101810014203CA30840C4005C00184064209CA50900522101098032200102106049FA0939F9A00
    S32800101833149F10159F10179F76179F53149FF1179FC2132F9A3FA102779005B282A37720A1027653
    S328001018569005B282A37620A10077841922002021E6039FA09324DF034227CADB90076003F37FA460
    S32800101879770AA10076841024DF034007C0408407600CF37FA4763224C0474009C0019008A1007F1B
    S3280010189C90039F01912F9A3D3E3FA7039FD28E9F90062100049F01923111C124004005102675017F
    S328001018BF98259F7C912100049F019224370100C1F4200010C12101019F571BD20084064082C00814
    S328001018E29006ED85F95087D79FC28E9F9006F950843201C19C3A240646F4E105882624C040420005
    S32800101905E6120452C0230300F682F6419F578F2475016002F10360F7F00221A08C19279807247543
    S32800101928016002F1039F7C91AB2F2E2D9A3D3E3FA7019FF51A52C063019F571B257501D200902DF3
    S3280010194B4043C002843C24C0404000C0019033FA27842F9FFD0126D347F4E1938C249FFD01F4E13B
    S3280010196E91801CE06042881798064042C00890059FA318980A42C0D200840460FDF0437342C09F79
    S32800101991571BA92F2E2D9A3FA1002684039F0D182100049F01929F7C919F8608E9099F7F479FDD8A
    S328001019B437A1021D90026201A32620D20090037298099FEF139F48189F35192F9A3D3F6606220746
    S328001019D74821DF039FB393660422114821FB039FB393240748020621E5039FDB9324114802042189
    S328001019FA7F039FDB932240002105049FDB9322720B217D039FDB9324344844117521F1039FDB93B3
    S32800101A1D25C047024D2109049FDB93024F210B049FDB93729F8A132100049F01929F7C912F2D9AA5
    S32800101A403F2475016080F101660122201D21F1119F63322F9A3D3F9F7C91240D044200D2019034A6
    S32800101A63D20290039FD11972240D044000D002840262019F3B3A72240D044000D002840262019F63
    S32800101A864D499F0D1824F2474000C00190039F2D2E6402210D049FD1936580A6542105049FA0936C
    S32800101AA925750160FEF0439F7C91A1001D840C9F6893D200840562019F6D984041E70804A612E6D0
    S32800101ACC4201C2019FCF3ED20090039FF54521E7039F4F4E729F48489F9819D20093C8A1001B8749
    S32800101AEFC39F401A99BEA2A03F24C0474009E70810A61AE60A039FDC90D2009029A1062973E52224
    S32800101B126AB3D324D347441075EAE1800F65E3240748440721E6039FA0939822B692A329209803DE
    S32800101B35A42900245B494002C008840331980F3124D347A10078E0501080032101002FA00A9A3D5C
    S32800101B583E3FA70253C1245B49430253C0CB10840B247501E06002880335980F7324D347401584C3
    S32800101B7B026301E64301A63AD2008408247501E0600280782675014082C001846F247D0301049C38
    S32800101B9E3A24D347F4E10E8C604080C001900642C0CA0C905443C1D3008405E65A009049249E01B8
    S32800101BC140098442400B843E400D843A400F84364008C07F8430420ACAF8842A400C8426400E84FC
    S32800101BE4224201CAC0841C4003C00F8416400084124002840E4204CA838408400684046201980DEE
    S32800101C0772247501E060018004607FF002AA2F2E2D9AA2A03FA62A9FDC08D20090026A019F2509C4
    S32800101C2AE65A00840B9FF51A739F571BD2008416247501607FF00160F3F003660122551A21400FFC
    S32800101C4D9F63322FA00A9A3D3E3FA701729F378E21000C9F2E8B9FC28E2475016008F1036204525D
    S32800101C70C032E088C058C0A642C2049F191C9F8C8E24370111009F13029FB1024CC07DEE6520D18E
    S32800101C9303E825F612F6519FDB93210C009FE391F61224D347F4610EE961F4E1408803E614044992
    S32800101CB6C0E6590087B624750160F7F0039FE28E9FF206A92F2E2D9A3DA2C03F24C047E0A20BE7E5
    S32800101CD92802A612E6F202A3DA20630C24D34742179F548B62409F378E210E0E9F2E8B6C0435A60F
    S32800101CFCA2C2049F191C210C009F0192F615CA089005BC8C9FEB8DE65C0087E3A4DA002FA00C2D11
    S32800101D1F9AA2A03E3F62019F48487A26D3472101009FD891E65A0084099F541C4A96900798039F2F
    S32800101D42CE1CBA8A2100049F01929F7C919FDD379FEF13A1002293D3A42200729FCF3E62019F488C
    S32800101D65489F0D1899C2F612F614E6297020FF0FE8549416E6238020FF00E851940CF621E623C0D8
    S32800101D8820FF1FE8518C19F62320FF8FE8529407F64324FF0F982CB560802524FF809823F621E626
    S32800101DAB23FF200001E8519402729A21FF00EA01E963EB63EB63EB63EB63E6274024FF5F1B03A1C4
    S32800101DCE026F84026220A37220EC92EBC273E9E2800362019AB892E5C262A3722062019A0B6D2028
    S32800101DF1FF3FE8539411A104727521FF5FEAC1E9538C04EB221A6D9AF6140100C37F1100C57FF653
    S32800101E1420E9C09005E6138011009A3F66100A702180009C232F9A3F6608F6122190009C232F9ACD
    S32800101E373F2180009FE68F6618222C002180009FFE8F2F9A3F6608223C002190009C239F371E2F7E
    S32800101E5A9A3D3F252C00230800F652213C009C3F6610F6522180009C239F371E2F2D9A3F0A2A09B9
    S32800101E7D6DF610EAC084BB200002EAC08414E4806C840FA1022CA36F20D240946DA46F4098689F03
    S32800101EA06B1DD20090270903A1066CE456728C57E4606E800877222C009C3F984A208049E95094D8
    S32800101EC34377222C009F578F983A096D203700E9C08420A1006CD010842A6410212C009C359F4B56
    S32800101EE61E31196DA46C146440212C009C389811203500E9C0840AA1006CD00884039F5B1EFA6DE5
    S32800101F09842DA1006CD0148426203700F5C02A900924C047400AC004840A21400019709F1F1E985F
    S32800101F2C0521FEFF19706004F37998076440212C009C382F9A3D3E3FA702A62C7D210400EE0111FC
    S32800101F4FC0FB8404096D192A0D2AA46C02200002EDC0840CA1036FA32C30A42D409B1B22F6519FD4
    S32800101F726B1DD200900CA10672A36C60770A039BA321F651207F0FE821200100E8518C0CA46C18BD
    S32800101F95231800225D019BA32120FF00E8558DBCE65A549149E65A548C4FE65A098C28E65A0780B3
    S32800101FB8039B1B22E65A039098E65A038C0CE65A019085E65A0285919893E65A058C039B1B2298B2
    S32800101FDB92E65A5190C3E65A518C0CE65A359094E65A5085719899E65A5290C6E65A53856598D809
    S32800101FFEE65A648C29E65A60894CE65A579126E65A578C0DE65A5590FDE65A5685459B1F21E65AC1
    S3280010202158911AE65A5A85389B4921E65A7291BAE65A728C0DE65A70914AE65A7185219BA821E6B3
    S328001020445A7895C5E65A7A85149B9521A42C00A42D459B1B229F2494A32C20A42D009B1B22212C99
    S32800102067009FC92B9B1822212C009F8D60A62A7BED65A36CA09B1B22A46C08212C009F2B1E9B1BD8
    S3280010208A22A46C04249E014200A32C204302A32D304204A32E2043069849A46C04249E014201A390
    S328001020AD2C204303A32D304205A32E2043079830A46C04249E014208A32C20430AA32D30420CA3D0
    S328001020D02E20430E9817A46C04249E014209A32C20430BA32D30420DA32E20430FA32F309B1B22BE
    S328001020F39FB38B247501A62A7BED65A6A3C30E4200C2F1B2135300A46C04230400F642988FA46CCF
    S32800102116032303002291009884A46C03A102B1A32C2023020022B200212D0098B4A46C0223020078
    S328001021392294009865A46C15212C009F458C98D2A46C0223020022B202984F222C00A6A2E622A03C
    S3280010215C9F6B3598B731192AF8C090037298B2E6AC088415A46C142475014002C004849F64402162
    S3280010217F2C009C3898962440404300A36C30232000224140980E2440404221A36C20230400226266
    S328001021A240212C00983FA46C206440212C009C38230800228503212C009C3F230400228D03213480
    S328001021C5009C3F2308002297032138009C3F230800229F032140009C3F23040022A7032148009CC8
    S328001021E83F9830A46C0E6440212C009C38230A0022C703212C009C3F247D0301001936012E19381F
    S3280010220B980E222C00A6A2E6228D9FF45DA36C206201AA2F2E2D9A3D3FA704F615210C2711C02101
    S3280010222E3D0411C26604F682F6519F5F45D20090046008F37921100011C011C26603F682F6519F21
    S328001022515F45D20090072475016001F102AC2F2D9AA2A03E3FA708F6162475014A01E60A03F681EE
    S328001022749F2B1EE65A0384196601F682F6619F5F45D200902F2475014201C2FCE612029821E65AD1
    S3280010229702841E6602F682E62404B5D5F6619F5F45D200900C2475014201C2FCE612015201F661AC
    S328001022BA9F8E45D200900C2475014201C2FCE612015201A82F2EA00A9AA2A03FA62A9F1E3FA100ED
    S328001022DD94C0108424E6AA07901F729F850224C0474007E70840A613C3019FFB41A62A9F4B8A633E
    S328001023000FA6A29FE88C2FA00A9A3DA2C03FF6157C2475014201CA03D00184026C0124750160CF2B
    S32800102323F002E65C009023203300EDC0900720000FEDC084079F47989C05980E203500EDC0904BFA
    S32800102346203700EDC090442080F0EDC091B4F651207F0FE821200100E8518C1DE4609580352475DC
    S32800102369014202E6121052022082F0EDC08419E6122052029812F6519F6B1DD200900DE65C008405
    S3280010238C04BB60880B1D6D98D320FF00E8558D71E65A259100E65A258C4EE65A1E90D3E65A1E8C37
    S328001023AF22E65A1290B7E65A128C0CE65A109088E65A118549989BE65A1390AAE65A1D853D98F260
    S328001023D2E65A2190B6E65A218C0CE65A1F90A2E65A20852798A0E65A2390AAE65A238CAA989EE60B
    S328001023F55A2C90F0E65A2C8C22E65A2890B2E65A288C0CE65A269099E65A2784FB9897E65A2A9047
    S32800102418A6E65A2A8CB7989AE65A2F90D2E65A2F8C0CE65A2D9081E65A2E84D998BCE65A4190314F
    S3280010243BE65A42902FE65A3084C898B82475014002C001900824D3474319A31F302475016001F16E
    S3280010245E0298072475016080F102620198A29F4798729F6D9899F32475016008F10299EA210100E0
    S3280010248198772102009872210400986D21080098682110009863212000985E21400098592180003D
    S328001024A49854210001984F210002984A21008098459FDE3999AE9F011099A99F1C3499A49F678ADC
    S328001024C7D20090059F880F99989F8E0F999324F2474000E70804A6129F5290623F9F6890997F602D
    S328001024EA80F3869F2D2E99769F283699712100409FD32299699F063F9F55949FF02731196D995BEC
    S3280010250D722FA00C2D9A3D3FF6159FD28F11402F2D9A3D3FF6156620225C4C21C0459C3411402471
    S3280010253066400200F6519F091E2F2D9A3D3FF6156620226A402119409C3466A0225C4C216C409C6B
    S328001025533411402466400204F6519F091E2F2D9A3D3FF6159F806011402466400202F6519F091EC5
    S328001025762F2D9A3F20A723E9C0840D60F7F27924750160DFF003985CCBFF8458A623D2099409E684
    S3280010259922B0D22A940A9849D20784040A6D1A2CA63273196D200400E9C08408212C009F132598B8
    S328001025BC30200500E9C08408212C009F1F259821200800E9C08408212C009F63259812200900E9E6
    S328001025DFC0840B212C009F3C2598039FB4452F9A3D3F0D2AF6519F6222F6519F2222247501420107
    S32800102602CA03D0039009F6519F0A23D2008405F6519F79252F2D9A3FA623742475014201CA03D088
    S328001026250384026401D3708411D400840464209801742140409F082C9884D3448403729862D34A12
    S328001026488407220904624A983DD34B8407220B04624B9832D34F8407220704624F9827D3598407CC
    S3280010266B22AE026259981CA632E622A6D2038C0A9FF46464019F592C983ED35E840A22B002625E5B
    S3280010268E9FA22C9830D4008426A632E622B0D22A8C0DA32A30A42B0062059F31279816A632E62283
    S328001026B1C0D2038C07A6329FD12B98069C11A40103722F9A3D3F0A6DF621E623FF200001E8518C2F
    S328001026D407A46F206A01980B203700EAC0900331196D7A729F411F9FAC2BD2009009212C009FC9B9
    S328001026F72BA36C209C10232C006420216C009C0DA62BD202841FA1026CD214840531196D980CE694
    S3280010271A5A009007D2209003A46C00096D192A9F791EA6B22F2D9AA2A03FA701A62A9F411FD200F9
    S3280010273D84089C11A401037A985A9C10E6AA019011A1026C52C0222C009C0AA62A222C009816A1B6
    S32800102760026CE6220252C0232A006442F6819C0DA62A222A00E65A02841A40C0D00194219FEF256E
    S3280010278342C0D2029418E622FEA36C209F791E980D42C09F652BE65A0184039FEE1DA6A2A92FA028
    S328001027A60A9AA2A03FA702247501010011C0A100739008A4730021A5FF11C09C10F6819C0CA62ACC
    S328001027C9D202841302C0EA81200100E8518C03A473011A2A9FEF2501C09F5E2BA6A2AA2FA00A9AF9
    S328001027EC9BAC909A3F9F4694247501D20090066003F10198094201C2FCE6120152012F9A3F24DF3B
    S3280010280F034007E70802A614D2199028D2198C0AD2179010D21884119812D21A901BD21C8C079815
    S328001028321A214043981D31981A2111489F81139812211548980D210F48980873E961203640E82129
    S328001028552F9A3FA62524DF034007E70802A614D20E8C1DD20C885CD204903ED2048C0AD201902899
    S32800102878D2009021982673D5079433983AD2138C0773D511884F9842D2159452D216840521050414
    S3280010289B985131984EF641980D73E96120DF03E821984021E7039F81139838E96120E103E821988B
    S328001028BE2FE961206D03E821982673E96120D903E821981CE961E96120BB03E82199D4E96120DD6C
    S328001028E103E821980873E961207904E8212F9A3D3F24C0474411E5B240E052128408D4009004D407
    S32800102904FF840264166302A6429FBC9025C0474049E70810A613C303B363729FE7904049E70820FA
    S32800102927A61AE60A01A6A29F09912475014202C2BFE7A840C040B01252022F2D9A3D3F24C0474A1A
    S3280010294A09E6AA01907A9FDC90D200846F24DF030126220F00E912A10B00A1067FCE019016A4009C
    S3280010296D01E6AA049003A400032110169C0660FEF27F9840A40001E6AA029003A40003CE02900BF6
    S328001029902112169C0660FDF27F9826CE04901024A10402002112149C0660FBF27F9812CE08900E87
    S328001029B324A10402022112159C0660F7F27FA300B0980460F0F27F9F8D902F2D9A3FD2219011D265
    S328001029D6229013D220900372981374217040980A74218540980474219A409F082C2F9A3D3E3FA718
    S328001029F9019FF0289FF02724C0474B09E60B80650FA104742105049FA0939F442962019F9491F695
    S32800102A1C819C16A62A62019F8B91A10200E65B009005E612409802C2BFA30020A40100E65A028466
    S32800102A3FEB247501607FF00243C0D3228C14D3208844D3168C06D3008426981FD31C8C629829D391
    S32800102A622F9041D32F8C06D3238454982DA632E622C4D2038C4998319FA8279847A6329F5728F6C4
    S32800102A851242C09832A6329F0C28749F592C9831A6329FD029982AA46F2062099F312798209FC54B
    S32800102AA826981BA63C7D223F00EEC2EA62208503E822A6329FA22C9805A6329F1926A623D20090EB
    S32800102ACB0CA4740024750160FBF002980DA10201A37420D2008403A4740742C09F6F2BA10279CAAE
    S32800102AEE049055C2FBA379202475016004F10231196D6414212C009C35222C0009709C2F222C00AF
    S32800102B1109709C2F6414212C009C350970200040E950942164109C38981B9F9590D200901AA1000E
    S32800102B3479C00290090A7CA1027E9C0F9804097C9C0E9F763FA47800A10279CA0192B5C2FEA379FD
    S32800102B57209F7A8F9B082A60FDF279197C9A6002F3791A7CA37E209AA1007B8403A47A00D3008462
    S32800102B7A2DA10301D3069004D3048422D2208407E4807A8419980DD2228413A1027A9004D2028435
    S32800102B9D0AA47B04E4927AA37A209AA47A009AA1007B8402729A72A1007AD003840262019AA1021F
    S32800102BC07B9005B282A37B209A3F9F8294620B2F9AA2A03FA62A9C10E65A42901DE65A428C0CE66A
    S32800102BE35A40901BE65A4184079808E65A43900B72980E9C2B980A9C2C98069C2D98029C2A2FA0CB
    S32800102C060A9A3DA2C03FF615A64C9C10E65C00840AED9242409C0AA62C982A464077EB93F652217B
    S32800102C292C009C3F232D00A6C4212C009C0DA62CD202840EA1062C77EB93222C00F6519F578FEDB4
    S32800102C4C9242409F652BA6C22FA00C2D9AA2A03E3FA702F616A64A9C10E65A00841324750142013E
    S32800102C6FCA03D003840801809C09A62A9818018011C0F6819C0CA62AD202840A230200F682F661C3
    S32800102C929F578F01809F5E2BA6A2AA2F2EA00A9A3D3E3FA702A62AF6269C10018011C0E65A038434
    S32800102CB50E24C0474009C0018405E6136011C0A10075900CA6A2E622F3D2028C033111C0247501FC
    S32800102CD84201CA03D0038417E65A4A9012E65A4B900DE65A04940801C09C09A62B985BF6819C0CC8
    S32800102CFBA62BD2028451E65A039010E65A038040A6A2E622B6D2018C3798312475014201CA03D061
    S32800102D1E03840C44807501C072C3E3E91212C042C1CA209007A4773C60FCF27FCA40900DA476326F
    S32800102D4160F3F27F9804729F8A1302C0F6619FDB9301809F5E2BA6B2AA2F2E2D9A3D259E014041D4
    S32800102D64C001901E24F2474001C001901140498411404B840D404D840972404F840562019801727B
    S32800102D872D9A3DE4608680046264981225DF0324F2474000C0088404425498024256A4850024DF69
    S32800102DAA034326C340D300840524FB479803240148E0E2058005A4851F9826E0E2048005A4850FE2
    S32800102DCD981CE0E2038005A485079812E0E2028005A485039808E0E2018003A48501E0E2008C041E
    S32800102DF06080F38524DF034027C002900D24F2474000C00290046080F385D30084046040F3852D9B
    S32800102E139AE4B295E64201C2019A3F24928060F7F0002180009FD8912F9A3FFC60A10286CA4084BB
    S32800102E360CE61210A386202100019FD891FC502F9A3FA10286E61220A38620CA4084062100019FA9
    S32800102E59D8912F9AA2A03FA62A24F2474000E70804A6129F5290A6A2C23F9F63902FA00A9A3FA6C1
    S32800102E7C2475A10384C003B2508409A10285E64201A38520E73840A616A6627373C203F610EAC0F3
    S32800102E9F8409A10285E64202A38520E76840A6127373C203E9C28409A10285E64204A38520A1026A
    S32800102EC2859F5D2E2F9A3F322180019FC891729F5D2E64102106109F858D64112108119F858D6498
    S32800102EE5102109109F858D607FF2862F9A3D3E3F201000E8518C05250100980BE72810A61A7BE7DB
    S32800102F083810E815269080ED85FC6062F752806008F1822180009F0192F95087EA2F2E2D9A3F64ED
    S32800102F2B01A62362099F858D2110109F2E8B2F9AA2A03FA62A6275E7A220E5C25AB2B2B522E72809
    S32800102F4E20A615620BE75120E5F2A264ABE72140B3B6E7A140B3B4B462B422E5C42AD500840CA678
    S32800102F714273E961E961E61230980CD501840FE74810A602E6120CB612A384209814A66273E9613E
    S32800102F94E961E74810A604B214E61403A38440A4850062019F7A2E24F2474208E72804A602A4804E
    S32800102FB700A38120985B62039F7A2E21E0019FF22E62029F7A2E21E0019FF22E62029F7A2E21A065
    S32800102FDA059FF22E62029F7A2E21E0019FF22E62029F7A2E21E0019FF22EA10286E6EA008806CAD1
    S32800102FFD20900E981AC2DFA38620729F292FE61A8022200D09809F7D981980FA8087A12FA00A9A1E
    S328001030203F60BFF2869F292F2100019F01926040F3862100109F2E8B2F9A3D3F62029F738DA62A9C
    S328001030437BBBBBBAEABBBBBAEABBBBBAEABBBBBAEAE64A01A6A2C2012F2D9A3D3E3FA7049FC82E45
    S328001030669F3A30D200900562019F20302120009FF22E9F3A30D20087E79F2030A10086C0108414A8
    S328001030892120009FF22E9F3A30D20093D09F142ED20087C99F5E2DD20087C260DFF28662019F29A6
    S328001030AC2F24F2474208B262A48000A381209F892DA484019825E502BA9F5D2E24F247F46506F6E1
    S328001030CF5209809F7D981980F6519FF22EA10284B262E61201A38420A10B84A10A85A6A2C23FE591
    S328001030F2E0B280079F5E2DD20093C5311982A4840024F2474D00A6DCE60C04986CA10385DB008892
    S328001031151024F2470502902EA100849029C3C0982553C07959C1CB40901A24F24705049015A1002A
    S3280010313884901001C073C23FE57330B2E2A62398020D80A10284E64201A38420A6329F5D2EF65119
    S3280010315B9FF22EF65209809F7D981980F651F52182198220E803E85194069F892D311982E65C00A3
    S3280010317E9007A10085C0408404FA8090079F5E2DD200937DA6D2C230D230900BD2108450A10086D2
    S328001031A1C0208449249E0140098412400B840E400D840A400F8406729F3B2F98307C2501015CC211
    S328001031C47959C3F464C2209E01E8244009BA009005A6B29F3B2FE65A808406BC9C6A019802BA6A94
    S328001031E7BB9BE65B2187D4606FF286729F5D2E9B66303D3FF615FC60210D049FD193A4DA00620888
    S3280010320A9F9491F65262049FCB922F2D9A3F62809F378E9F83019FB58E729F0E892110109F2E8B5C
    S3280010322D319F578D24958062FE5200249180520073B2929F1D912F9A3D3FF615FC60210E049FD1EF
    S32800103250939F173262029F9491F65262019FCB922F2D9A3DA2D03FA702F61512C0A66DFC60A66418
    S32800103273210E049FD193A6D4210D049FD1939F1732A4DA00620A9F9491F65262019FCB9202C062DC
    S32800103296049FCB92AA2FA00D2D9A3F2475016001F10324000C4000D0AA841724080C4000D05584DE
    S328001032B90E9F5D91D20084079F098ED20090039F579324000C62AA520024080C625552009F82933D
    S328001032DC9F3F909FA191A10295E61280A395203332319F578F9F063F9F880F9F17322106009F7C13
    S328001032FF8D2107079F7C8D2108079F7C8D647F2109009F858D240E04400090076402F6419FD193EF
    S32800103322240D04400090076402F6419FD1939FB1922101002F9A3F2126019F2390D2079006D2FCE3
    S3280010334590029C052F9A3D3EE4609480A7A1088779F6412205009C42F616207901E826259E01E09C
    S32800103368A280E002419063EC912203009C48A647A38740A642732205009C42F614207901E82425E2
    S3280010338B9E0142415200A672739C42F614207901E82442435201A672739C42F614207901E8244249
    S328001033AE455202A672739C42F614207901E82442475203A672739C42F614207901E82472520498DD
    S328001033D10DEE96ED95ED9520A601EDC08788A10287732205009C42F614207901E8244204D2FF90B2
    S328001033F404B29252042E2D9A24004472400F840C40108408401184044012900BB292200500E8243D
    S32800103417D20387E59A3FA48700A48800640F2179019C38230F002279012100449F578F230F00221D
    S3280010343A7901210F449F578F2F9A3D3E3FA702E4B2D0C20152C1E4609480BF9FFC3352C0D2028C27
    S3280010345DB6D200902E73E9812205009C42F614200044E824259E01400FE0504984154010E0504BA4
    S32800103480840E4011E0504D84074012E0504F907860FDF2D04CC07DF6612205009C42F6152301001C
    S328001034A322A701200F44E8219F578F23010022A901F651201044E8219F578F23010022AB01F651B3
    S328001034C6201144E8219F578F23010022AD01F651201244E8219F578F42C0D2009015EE812205007C
    S328001034E99C42230100228800201344E8219F578F42C1D20090046002F3D0A48800980CA10288D29E
    S3280010350CFF9005B292A38820AA2F2E2D9A3D3E3FF61736A10A877BED91EE212203009C486205E707
    S3280010352F4220230500207901E822F6719C3FEE96200500E827200300EEC087D42F2E2D9A3FA70FF6
    S32800103552E460948010F6819F1935230F00F6822100449F578FA50F2F9AA626F621D60084082320DB
    S32800103575002227049828D601840B2308002287049C3F62089AD602840B231000228F049C3F621057
    S328001035989AD603840B2320002247049C3F62209AD6049002729A2320002267049C3F62209A3D3F96
    S328001035BBF614F6250140A10095C0408409E992201E1CE851940E0200EAA09007EA92F6419FDB931B
    S328001035DE32F6519FDB932F2D9A3FF624CE209007F4E100940E9805F4E1008807F612F6419FDB9396
    S328001036012F9A3D3FA62A7BED65ED65204704E825F49240F6519FDB932440430200ED91E9919FDBAF
    S32800103624932F2D9A3FA10094C020902B667A2280432127049FA997FB901DA48B00311989249F0474
    S32800103647F49200F6419FDB93237A002227042180439F578F2F9A3D3F9FA702B282248B044E007FEC
    S3280010366AF673258C049813444075EAE38802F623EAE79402F627ED95A632B283D20087E7F631F685
    S3280010368D722F2D9A3DA2D03FA62D9F5D36F614A6D677220200F6419C372FA00D2D9AA2A03FA62A8A
    S328001036B09F5D36EAC1A6A6772202009C372FA00A9A3FF6144400D4FF9005B4949FD1932F9A3FA1EE
    S328001036D30094C02090092187049FC1369F28362F9A3D3F73E965201F04E8250340A10095C040841F
    S328001036F609EB92201E1CE8539415F614208B04E8244400D4FF9007B494F6419FD19332F6519FDBEF
    S32800103719932F2D9A3D3FF625A668E62205B3D3220A009C48F612E6A8209015207E00E8E1940464E8
    S3280010373C7F981D4240E909E9E2941A98132081FFE8E18804648098084240E909E9E28805F6519F5D
    S3280010375FD1932F2D9A3DA2C03FA10094C0209069220F04218F049FB935A102919FB094D2068C12E8
    S3280010378273E961F612201104E822209104E8219FB935A1001E901E9FA702A62C2500019810A100C9
    S328001037A51EBB009005A6A29FE436BB6BBA9ABC5A83EC0A89EA911989200F0EE8529414311989E4F7
    S328001037C8928BA38B20247049E0520080039F28362FA00C2D9A3D3E3FA703A10094C02091F09FA7EC
    S328001037EB0252C09830E082C052C0A62C7DEE65F654207D03E82414C16620F652202704E8220108FC
    S3280010380E9FE73576F652202F04E82204C101089FE735257D0349C0E6590087C666202237040156AE
    S32800103831F4C9589FE735662022390401449FE73576223B0401449FE73576223D0401469FE7357681
    S32800103854223F04016C9FE7359FFD0166202241049F1D379FFD01762242049F1D37662022430401D3
    S3280010387770F4C9729F1D3725B103015666202244042054F5E8219F1D370156762245042054F5E878
    S3280010389A219F1D379F080266202246049F1D37A1048C249E014501A38C50A1028D4303A38D30B212
    S328001038BDA2E50B32A1028E4305A38E30B2A2E50C32B4A4B504A64ACC018405E6AB40900562019FFE
    S328001038E00336E6AA029004729F0336E6AA04900562049F0336E6AA08900562059F0336E6AA109003
    S328001039030562029F0336E6AA20900562039F0336E6AAC0900562069F0336A6BAE6AB0390056208B0
    S328001039269F0336E6AA0C900562079F0336E6AA10900562099F0336E6AA209005620A9F0336E6AC8B
    S32800103949019005620B9F0336A1028FE46092800FCA088405620C9F03366008F38F9805C2F7A38FC0
    S3280010396C20A1028FA100B2C0048407C2FBA38F20980FCA04840BE61204A38F20620F9F0336E4B3ED
    S3280010398F8FC301A100B3E70840A612C201B2539016E64301A1028FC2FDB360C002B012A38F20629D
    S328001039B20E9F0336A1048FA643C301E4B2B3C201B2539013E64301A642C2FEC301B312A38F206252
    S328001039D50D9F0336AB2F2E2D9AA2A03F9F6893A62A227A002127049C396410210F049C3864082154
    S328001039F81F049C3824270421FF7F1108110A110C110E6380531A531D627F521B521EE65A00900CE7
    S32800103A1BFC609F409324B4041100FC509F2836A10095C04090062100409F1E3F2FA00A9AA2A03F51
    S32800103A3EA62A249F04F800840B667A2280432127049FB3936403218C009C38A48F00A10094C0200B
    S32800103A6190269F5D91D20084079F098ED2009005218A04980DE65A00900521880498032189049F31
    S32800103A84C1369F28362FA00A9A3D3E3FF617F626A667A66A7BF6512205009C42F614208801E8241C
    S32800103AA7205549E8254A400000EEC0900F16001702F9709003729802A6A252044204BA528818B2CB
    S32800103ACA925204D7008408A10293E612019818A10293E612029810D7008407A10293C2FE9805A12B
    S32800103AED0293C2FDA3932007020300EFC3420473323A39F631A630A614A6159C45ACA6A879359C43
    S32800103B104AEF212F2E2D9AA1029073E964EC64EC64201E49E82401009A3D3E3FA70526920140835B
    S32800103B3384A6A10292C27FA39220245701010311C3028412C1251649457E55C09F173B027C247D4B
    S32800103B5603F42216E9E28073077824A104010030E8E19406E9E79402F61706C3F4CEC121100E442B
    S32800103B79C0759C48F612F6619C4366089C4E259201E9E79437F49240124042C073E961E961E9C245
    S32800103B9C843D241649F4E63A940FE092425242D20284096201524398047353427224920132120043
    S32800103BBF02C31204981775554231114002C31244980A75558231118002C3128472AD2F2E2D9A3D0F
    S32800103BE23FF6159FA702A624F651759C422F2D9A3D3E3FA70411C22416494000C0029051267D037A
    S32800103C05058224A104F4E5028844019211C0E9E5883C0184245749F4E100943224594901009FE16E
    S32800103C283B02C0EDC2E9E2940F24594901009FE13BF421C211C2980B0192F4C98202C2E92212C205
    S32800103C4BA10293E612049805A10293C2FBA3932001C2AC2F2E2D9A3D3FA102929FB094B282A10A22
    S32800103C6E907BED65ED65B22ABBDBED64201849E82401082F2D9A3D3E3FA702A100918403A49108C6
    S32800103C91A1029152C0A10092C00F8409A10292E61201A39220A10D92E60D8042C09FB094A62C9F99
    S32800103CB4FD01220A009C48207E00E8E19402627FE65C00840924164945016480981DE65C068409E5
    S32800103CD72416494406657F981CA6CA7B201649E8250240E65C028C08241649E02507980BE65C0347
    S32800103CFA9006241649E0C407E5E0428807E0B4C054C0980AE5E0529405E068C058C0A1091B59C17E
    S32800103D1DE659018407A10092C010901842C0CA619005E61D10981744C1D4019007A10092C020905F
    S32800103D400A48C0E6A8419003E61D2042C0CA039005A490009815CA149005A49001980CCA089005BB
    S32800103D63A490039803A49002247D030718A10292A62CE60C0FCA018408251649F4E76C8C096C0130
    S32800103D86241649022E9845A623C3024040C004903E24A8044E097FD300900644757533981B4476F7
    S32800103DA975CA04900B467577A642A653F6129809A642A653F61322FF7F241649423773F634E9C477
    S32800103DCCF641B960802A3198270716D3009006036E0270980FCA049006037002729805037222FF46
    S32800103DEF7F241649423473F634E9C4F641EAE79404BC6C980D49C1E659019006E9E78802BCBCBCFE
    S32800103E121DE6AD31840AA100B1C0089003E61D40FC60A392D042C0A39120FC50AA2F2E2D9A3D3ECC
    S32800103E353FD200906DA10292CA308466CA01900724164906289833251649CA409004066A98289F5E
    S32800103E58623CF6164040C001901D6601241148020024A80401049FDB94F662739FFE940668EEE197
    S32800103E7B8002F61625A10476F66201409F8D3AF612F6519FDB939F173B9FE13B9FF23B6601F612FE
    S32800103E9E01429F8D3AF61298083221A1049FDB933221A3049FDB932F2E2D9A3D3F64062192019C34
    S32800103EC138255701249201014311042F2D9A3FA1001D84039F333EE4801B90129FB93EE4A01B849F
    S32800103EE41EA10292C27FA3922098149F293BD200900DA10292E61280A3922062019801722F9A2441
    S32800103F0780450100C2F8C3031994FB8409A10295E61280A395209A3FA702F613F5439421FFC3EBD9
    S32800103F2A0111C0CA10900721F8C3EB0111C001C01994C2F8C30311C0230200F6822180459F578FBB
    S32800103F4DAA2F9AA1029073E961205948E8219AA1029073E961206248E8219A3D25A104247D03016B
    S32800103F7004F4C9402D9AA4A8009A3DA62677F634209B01E82442009020F635209801E825E0954060
    S32800103F935540D40090057252009809B3558007B28252007252402D9A247D030116F4C9189A3D2526
    S32800103FB65B494040B200840374982624C848031BE002419002031974A63273E96420C703E824F628
    S32800103FD931F4210024B103F4E11688026401A6422D9A3DA625259E014445CC409038245B494002D5
    S32800103FFCC0049076E4A01B8407E909F5219C980131199CF5B19C25A248F4E152880A24A804400952
    S3280010401FE050548852A642C2BF249E0152059844244B484002C040903E24A8040100F4E104802D8D
    S32800104042A652E909F5219C199C30E8E194046040F14424A248F4E110941A249E01A642E6124052B8
    S328001040650560BFF00431199C980760BFF044331B9CE4A01B900731199E19A09848FAA49020A6524B
    S32800104088E9090B9EE9C31B9E24A248F4E306800E249E0160F3F00460F3F0053119A4FAA29020A654
    S328001040AB52E9090AA0E9C21AA024A248F4E20E800E249E0160CFF00460CFF005331BA22D9A3D3ECD
    S328001040CE3FA62EF625F636244B484002B2009051249E014005B2008448247D030104F4E1828812B3
    S328001040F1F840900EA6E273E961249E01A620F104982CF4E1808C04F8409023F491401140F451848A
    S32800104114800A249E01A6E2E012055205249E01A6E273E961B2A2E0020452042F2E2D9A3FA1009221
    S32800104137C001900A23A24822A4006204980823AA4822A20062109FCC402F9A249E016043F00060A6
    S3280010415AF5F0026083F0046043F00160F5F0036083F0053119A419A29AA2A0A626249E01400984D9
    S3280010417D20400B841C400D8418400F8414244A484000C001840332980B3224A70440008403220130
    S328001041A000A647D300900A646C6A13630165D79807644C6A037365D6D7008419249E014201CAF100
    S328001041C38410E00403840BE0030584064007C0089006C6FED7008419249E014201CA0E8410E00A0E
    S328001041E603840BE0050584064007C0079002C6F1A662A00A9A3F9F7341A624CA0F901E247D03036D
    S3280010420904EBB1245B49F4E10D8007C4F1E614029808F4E30F8003E61401A6422F9A3F240043029D
    S3280010422C0024C84801369FFE9419962196002F9A3F240043020024C84801349FFE941996219600E6
    S3280010424F2F9A3D3F9F9E4CF6159F694CF652E9C2F6212F2D9A3F9FA702A6242106439F819724066D
    S32800104272430408F64322E803ECC19F94982F9A3F62029F91362F9A3F62029FAB362F9A3F247D039C
    S3280010429501049C3A2F9A3F247D030102F4C9109C3A2F9A3D3F247D0325C8480116F4E164801801BC
    S328001042B8049C3AF4E166880F099AF4516B800462019808E991980131199A722F2D9A3DA2C03FA763
    S328001042DB039F968AA62CA100D0C0019007249E016004F10F9F0C45A10094C04090E56403F6819C12
    S328001042FE3824A7044000900742C0E6120152C0247D0325C8480116F4E16D80070104F4E16F88070B
    S3280010432142C0E6120852C09FA842D200840742C0E6121052C0A6C3E6AC01900742C0E6122052C08E
    S32800104344CB06900742C0E6124052C09F678AD200900742C0E6128052C02102019FB43FD2008407F4
    S3280010436742C1E6122052C12104029FB43FD200840742C1E6124052C12108039FB43FD2008407422E
    S3280010438AC1E6128052C12110049FB43FD200840742C2E6120152C2E4601C880742C2E6120852C272
    S328001043ADF6822180499FEB99240643020A24A504F620F4C800900CF6419FDB93322188499FEB9913
    S328001043D09F464CD2009007322190499FEB99AB2FA00C2D9A3F24A24801159FE13B24A104F4210280
    S328001043F319962196002F9A3D3F24A24801189FE13BF61519969F173B9FE13BE9251D962196002FF7
    S328001044162D9A3D3F9FA702247D0305189813A66475EA64207D03E824F650F4C8089008A662B2861B
    S32800104439D20087E7247D03020001049F8D5CF652E9C21A982F2D9A3D3E3FA7066406F6819C3843DD
    S3280010445CC044C5E4801B8413E6130453C0E6140454C524A104F80290239828A632E6121052C0E613
    S3280010447F140154C5244A484000C002900CE6131253C042C3E6120252C342C4E6121452C4A10092F5
    S328001044A2C001840742C4E6124052C4259E014441264B48C48043B2729F7A3F4443C40243B6620193
    S328001044C59F7A3F4443C40843BA62029F7A3F9F1844F6822198499FEB99A102A8D2FF9005B292A32A
    S328001044E8A820AE2F2E2D9A3F230800F61221A6019C3F24C848E0600280059F8F8B98039F9E8B2FA6
    S3280010450B9A3D3E3FA702F686244A484000C001902C25A704404084257252816213A2206201A220F1
    S3280010452E3EF7DE01247D03031822CE4821CC489FC0984481F6519FD193AEAA2F2E2D9AA102AA90B5
    S328001045510CB282A3AA20D2008403A4A9009AF624A104A9B654840EA4A900F4C9028417A4AA0062E9
    S32800104574019AA100AA8411D400840DF4C9008408A3A960A4AA04729A729A3FA70424A804020024EF
    S328001045974043F4420023F2A6EA4313C020CE35E84212C266FEF6829F5F45AC2F9AA100A98406A44A
    S328001045BAA9FFA4AA049AFC6024570121FF7F110421FFFF22FF7F11001202313219B61AB8FC509ADA
    S328001045DD24344840058407A102B3C2F79806A102B3E61208A3B3209A3F9FAC68246002311132A492
    S32800104600BB039F8B5B6080F3B52434484000C00290136604228C022184029FB393228C02F6219F65
    S32800104623AB4B2411484209CA0490046002F3B1CA0890046008F3B12F9A3D3F246002F490361036FB
    S3280010464630F438381038F49006100630F438081008E0923C523CE4A0B49006219A029FA79525601C
    S3280010466902427CD2E0942EE6221F527C2171029FA7952164029FA79501449F5169F61524114802F6
    S3280010468C00244047420A739FFE94E95580046004F3B22F2D9A3D3E3FA702F61609B60AB82410274E
    S328001046AF359C4A11C09F004EF6629C43F521B6F532B819B61AB8241027359C4AF4C9C0AA2F2E2D4F
    S328001046D29A3FA701240643440CA10094E70820A613C301E74840A612C201B352840372981AA6422E
    S328001046F5C2FBE73804C004B01252C0230100F6822112439F578F6201A92F9A3F6040F3B19FD3466D
    S328001047189FDD452F9A3D3E3FA7022434484000C001900724A8040204980524114802002511484291
    S3280010473B46739FFE94F61602404247739FFE94F612EEE18802F6622460020130EAE1801BEAC1114E
    S3280010475E302440430100E9A0900EE99111C0230200F682F6419F578F729FA05BAA2F2E2D9A3D3F29
    S32800104781F6159FA146F612246002010FEDC1110F0100EDC111000102EAC111020132EDC11132BBA2
    S328001047A46080060130EDC11130246002F651F421241124F621F421261126F6519F054B9F1D472FAA
    S328001047C72D9A3FA623A104B484152435024200B352900CD3009003A41E002435025300E4541B9001
    S328001047EA5BD4019006D4FF841F98099FCF686040F3B1980621DF019F9880640121DF019F816E2134
    S3280010480D36029FC486A1021BD2019004D2FF84239FDD4521DF019F0972A41E00E4801B840960BFEB
    S32800104830F2B19F9E68980621DF019F9986A4BB03A1021BA3B4202F9AA2A03FA62A9FD346D20090DF
    S328001048531F6002F3B524600221FFFF113AA10094E70820A614C40121DF019FF272A4BB03A6A29F03
    S32800104876C947A102B48420A1001D842E243502440021DF019FDA73E65A00841E22DF012136029F26
    S3280010489967889813D20184059FEC68980AD2FF840621DF019FDD85247D030100246002F4E1348842
    S328001048BC0211342431034008D002840BE4A0B484066080F3B29804607FF2B29FD659D2009003A43E
    S328001048DFBB032434484002C0409011E480B4840C7AA100BBD00384056A0198017A9F8B5BE65A0042
    S3280010490290212460020726012EE9E788160224032CEBE2880EEAC3221027EFC19C3724B40211004F
    S32800104925A102B5CA0CD00884039FB558A1001D840760FBF2B59FA866A1001D84039F294C60FDF280
    S32800104948B52FA00A9A3FA4BB0324600221FFFF113A9F10477421DF019FF272729FA05B9F3E799F0E
    S3280010496B8B5B9FDC50A102B5C2F2E61209A3B5202F9AF614FC60B560800132120421FFFF22FF7F11
    S3280010498E11001202FC509A3D3E3FA702F61712C030E8E18C043132982DA100AB9008A630A614A6D8
    S328001049B115980809ACA630A614A6159C52F615F626F4CFC0F671A630A614A6159C523E3D9C4CACD1
    S328001049D43A393122803F9C41ACAA2F2E2D9A3D3E3FF615F626024CF4CA4A9F7D490244F6619F9561
    S328001049F749E64580114612482F2E2D9A3D3E3FF616F625028A9F7D490284F6519F9549A100AB84D2
    S32800104A1A093A393122803F9C41AC118612882F2E2D9A3D3E3FF615264402028A9FDB93028CF65158
    S32800104A3DE62204B3D39FDB93265202028AED91E9919FDB93028CF651E62206B3D39FDB932F2E2D96
    S32800104A609A3D3FF61503C404C6D4019005A100AB9011004838004638F631F6429C46ACF613F62406
    S32800104A83FC603C3BF6519FA79FFC50AC2F2D9A3D3E3FA702F61512C0F636A102ABD201840CF632C8
    S32800104AA6F4CAC0F6519FE2499828D200841D024C014A9F9B60164CF6629FB460114A243448400139
    S32800104AC9C008900401C0114A02C0F6519F034AAA2F2E2D9A3FF61430E8E29404EBE2800B120A1317
    S32800104AEC0CF6419F924A980F0104E480AB8406020CE9C2F621110A2F9A3D3F256002036C026421E1
    S32800104B0F44029FDD4A036E02662152029FDD4A2434484001C010900821A8049F2C4A9816660422E8
    S32800104B32840221A8049FB3936604228C0221AC049FB3932F2D9A3D3FA624A1001B8415D201900549
    S32800104B55A100AB840C2434484201CA489003729818A1021D73E96420D103E824010030E8E18C0497
    S32800104B7862FF98026201D4008405E452AB9021A3AB20243448010E19AC256002036C026421440212
    S32800104B9B9F924A036E02662152029F924A2F2D9A3D3E3FF615F6262444020140110A0180110C243E
    S32800104BBE52020142110A0182110CA4ABFF62029F484B32319F054B2F2E2D9A3D3E3FA701F615F6AF
    S32800104BE12656C0729F484B3E3D44C42144029F614A9F004EAC44C0D4018403211027A630A614A600
    S32800104C04159C523A39F651F6629C46ACF71C46F700409C4CAC3A3944C42152029F614AACA92F2EC4
    S32800104C272D9A3FA100AB841509AC30E8E1940E66013122804F9FD94BF581AC19AC2F9A3F9FA70296
    S32800104C4AA104BA6301980DB282A640B300840372980BB363D20087EFA4BA0062012F9A3DA2C03F9A
    S32800104C6D9FA702A62C25FF7F981BBC8CA6C29FE8602440474E137FEF92EA64E9240100E9E594023B
    S32800104C90F615E65C0087E0F6512FA00C2D9A3DA2C03F9FA702A62C250080981BBC8CA6C29FE86067
    S32800104CB32440474E137FEF92EA64E9240100E9E58802F615E65C0087E0F6512FA00C2D9AF613EA78
    S32800104CD6C1B3608002E9B120FF07E8E18C0D74E961E961E961E961EBE194026401A6429A243448A8
    S32800104CF94204D2038C01729A21D6029A2434484000E70808A612C2012440464301CBF09005E7388C
    S32800104D1C10A613D3049001729A249E470200EAE18802F62124A0470200EAE19402F6219A3F2460C8
    S32800104D3F02012430E8E18C03319805022C9FC6942F9A3D3E3FA701F6169FA70252C0311182982A80
    S32800104D62E083C053C0A63E7FEF65EE25014CA630A614A6159C5203C704C93C3B9C46AC9D4BA2115B
    S32800104D854C0282E922128247C0D70087D0A92F2E2D9A3D3FF6159FA702A624247E470100759C48A8
    S32800104DA8248147F42100E9E5800C9F3C4D73249D47E052008C026301A6322F2D9A3FEAB322100EC6
    S32800104DCB9C372F9A3D3F77EB64E9240504230004010C9C37ED21B3608001312F2D9A3D3FF6140560
    S32800104DEE0023000401029C37ED21B3608001312F2D9A3F246002E060278007247E470100982AE483
    S32800104E11801B84202434484002C040900A24B402010030E8E18C12240643021721F6029FE94D982F
    S32800104E340524B10301102F9A3D3FF6252300049C37231027F6529C372F2D9A3F6604F61221A60218
    S32800104E579FB3932F9A3DA2C03FA70611C212C4240643420CCA03D00284A96203E7652020C202E81C
    S32800104E7A254242B2935342D20084072110271140980B244047E0530D8003735342044014C003C47E
    S32800104E9D04C2020001C09C37114004C2E06001800A640C21C2029C387A986422E8039C48F61224E2
    S32800104EC04047460BA66273E9528C08420CF610EA5094472434484000C00484037A98322440474CC8
    S32800104EE30CA6C273E9528002A66C01C022E8039C48F61302C4A6C2739C3704C21100A6C27322E8F5
    S32800104F06039C4211406004F3B26A01640C21C2029C3898026A01A6A2AE2FA00C2D9A3D3E3FA702A3
    S32800104F29F615F637F62124FA02021A9C4366089C4E246002F4213411C0F671329C53F616F627E656
    S32800104F4C4F8024FA02011CA630A614A6159C523A39F661F6729C4CAC9F4BA0F616F627F4CDC0F6F7
    S32800104F6F51A630A614A6159C523F3E9C46AC9D4BA2F421C0AA2F2E2D9A3DA2C03FA70611C212C413
    S32800104F929FA702A62C21008011C0982ABC8CA6C6246002020021D6029F5B60F615A6C602C401C209
    S32800104FB59F5B60F652E9C2F4E2C0940719AEA3B0C012C0E65C0087D1AE2FA00C2D9A3D3E3FA70B43
    S32800104FD811C312C513C79FA70252C0640401D19C389870E082C052C0A62602C501C39F5B60F615BB
    S32800104FFB43C053C17454C2A63602C7F6519F8F5FF466C104D1EE2414C9110404D10200E92212007B
    S3280010501E7746C002C7F6519FA262F61504C9110C49D3E659009017203103E82601809F254D23E833
    S3280010504103F612F6519C3705C9114CF464C1F424D105D10042F4200C10424BC0E65B008789A50B4E
    S328001050642F2E2D9AA2B03E3FA70E11C612C813CA9FA702A62B3111C2369840BB8BA6B602C801C67F
    S328001050879F5B6011C0A6B602CA9F8F5FF421C211C25BCC7353CDF464CC203103E82401009F254D16
    S328001050AA11C477A6B602CA01C09FA26223E80302C49C37E926E65B0087BB240043F42604F426021B
    S328001050CD01C204D311001602A50E2F2EA00B9A3FF7F602247D030300246002020021D6029F6850E5
    S328001050F0AA2F9A3DA2C03FA704A63CD2008409240643011702199870D201840874F6819FBF7998E9
    S3280010511370D2028412257D03024201449F1A9511C2024412C0985AD2038410257D03024201469FF8
    S328001051361A9511C20146982BD2048417241148010022FBFF9C4811C0010222FBFF9C4811C2982B5B
    S32800105159D205841024A802020012C224A602010011C09817D206840D2434480106020811C012C202
    S3280010517C980674F6819F9079E65C00900401C2980201C0AC2FA00C2D9A3D3FF615247E4701001105
    S3280010519F4624834703001348D400900F241803F4211011462434484204980B240643F4211B11469A
    S328001051C29FF64CA100B3E70820A613C3019FF35011442F2D9A3D3E3FA70AF615F6240204B5608893
    S328001051E5033198D1A100B3C00890C3014211C830E8E194B10340A670A618A61913C414C69C439C29
    S3280010520852F615F62601C402C63A3901C802CA9C45AC9C523A39F651F6629C4CACF71C42F70040B2
    S3280010522B9C46ACF615F626F780BFF700009C54ACDA009478F7803FF70000F651F6629C40AC9C3E38
    S3280010524E11C012C2660901C402C69C4D9C52F615F62601C8A630A614A6159C523A39F651F6629CD8
    S328001052714CACF615F62602C003C23B3A3122803F9C41AC3A39F651F6629C46ACF615F626F7FF464B
    S32800105294F700FE9C54ACDA008819F651F662E645809D4BA2981003402110279C379807F62198039A
    S328001052B7210180A50A2F2E2D9A3D3E3FA74411FC243E00F680E8241200264000F680E826568024BD
    S328001052DA4100F680E82457006409F6819C3824064302082485474200739F119511E906FC068016D0
    S328001052FDEB244100F680E8244900A290F681E6220AB3D339264100F680E826038002EE243F00F62C
    S3280010532080E8240400010A9FD34F256002264300F680E8264480017A9FD361F617AB244000F680E0
    S32800105343E8244900E659008434E4A0B4842FE96111C5497647774878467932B6558C18B655841A54
    S32800105366B8548C10B8548412B7538C08B753840AB9529406A692A67311C502C5EF61F610EA5094D7
    S3280010538933F621329C53F615F626E64D80F671329C533A39F651F6629C4CAC9F4BA03A39312280A8
    S328001053AC3F9C41AC3A39F681E6220DB3D39F514DAC2400430602F426CBF4260416E516CB02FCF650
    S328001053CF81E62209B3D39FD75111F5200180E9C084039B6C5704FC0100F4E10280039B6C579FA792
    S328001053F202A62A3616F121FF7F11EFF686200900E8269819BA8AA6A602F5F6619FCF4D02EFE9E21B
    S32800105415940211EF04F1E92414F1E65A0087E22434484001C020903702F501F19F1A95247E47056B
    S328001054380006FC158624C044F4E100801F243E00F680E82401009F1665F70000F61302F701F39F77
    S3280010545B6165F652E9C21286AA06F104FCF4E6068C039B6C572434484001C002900C06EF04FCF431
    S3280010547EE6088C039B6C57243E00F680E824040014E37959F74CF7E65C008480248147040014DF06
    S328001054A19FA702267E470780248C47440043C0B3548C0468019803E5C83406FC0582F4CDEB7302B4
    S328001054C4DF9C42F672E92201F1EAE18025F65102E99C48264200F680E826588074264300F680E808
    S328001054E7265480264200F680E826F45180802458FA7D5DFBED81F421FA02FA9C4811E930E8E18C3A
    S3280010550A0B620152F722010012E99804650155F704E9F424EB14E706FC0182E9E4940211E701E792
    S3280010552DF4C9EB11E9E092C052C002F501E99FC54D11E102F501E59F3C4E03E1F61201E39F244FF3
    S3280010555011DD244100F680E8244900A290260A00F680E8263E03E002EA243F00F680E82404000127
    S328001055730A9FD34F264300F680E8264480246002013A9FD361F61702C8E961ABF610EA509436F425
    S3280010559622E1F621329C53F615F626E64D80F671329C533A39F651F6629C4CAC9F4BA03A39312249
    S328001055B9803F9C41AC3A39F681E6220DB3D39F514DAC2600430182F421CBF4218411CB02FCF6814D
    S328001055DCE62209B3D39FD75111F39FA702A62C3521FF7F11ED981ABC8CA6C602F3F681E62209B3B2
    S328001055FFD39FCF4D02EDE9E2940211EDE925E65C0087E1F654F4CCF114F814C7200180F4C8F3901D
    S328001056220BF65201F19FD34CD200901A49F7E65900841306E9200100E8E6940AE57DD0BCEC16E965
    S328001056459B9A5401C5F421E111C5200180F4C8F3840B06EB04FCF4CE00160298AD2434484001C081
    S3280010566820903902F501F19F1A95247E47060004FC160624C044F4E100802101DD9F1665F7000051
    S3280010568BF61302F701F39F6165F662E9C2263E00F680E82606801286AA04FC0106E9E58C1F03F85D
    S328001056AE02E9F4C9F19C37F61206EBE92604FCF4CE00160206F1F42606F66198312434484001C09D
    S328001056D102903E06FC018802EDE9E28C34F623F4CBEF02E9F4C9EF9C37F61204EBE924F4CC801442
    S328001056F48201EFF4218811EFE57330B2E29C4303C104C3E923EA3413C114C37C984AE573B0BAE211
    S3280010571702F1E57550B4E4EA2102E99C4303C104C3E923EA3413C114C304FC010206E7E9E68009A7
    S3280010573AF4C90011026C01981901CB11E502F312F515F104ED14EF06E716EB01DD11E39B9354014D
    S3280010575DC102C3241027359C4A04FC110498093106FC118411826C01A6C2A5442F2E2D9A3FEBC238
    S328001057809FB4602F9A3D3E3FA70311C1F6269FA70225FF7F981E0380EE96EE9604C10100EC92EAC8
    S328001057A39212C12200409F7D57E9E59402F61542C0B28555C0D20087DAF651AB2F2E2D9A3F22D656
    S328001057C6022106439F8557246002F612F4CA0021B2029FDB932F9A3D3E3FA70511C312C19FA70277
    S328001057E926B60225FF7F982204C30100EC92EA9212C304C10300029E9F7D57E9E59402F615F491E6
    S3280010580CC1E99111C142C0B28353C0EE96EE96D20087D2F651AD2F2E2D9A3D3E3FA7073111C4242F
    S3280010582F7D03010011C23111C09FA70252C626EE02980F0180EE96EE9602C29F8F5FE92515C042CE
    S32800105852C6B28656C605C0D20087E59FA702A624F651759C4811C07353C6F6819F2160AF2F2E2D21
    S328001058759A3D3E3FA70911C712C2240643011511C49FA70252C6981EB282A62C7DEE65F654200696
    S3280010589843E824020D12C052C6F6819F2160F425C7114042C687DEA5092F2E2D9A3D3E3FA71822ED
    S328001058BBA60BF681E62204B3D39F7658F682E62404B5D512D63111CC2106439F855711CE74F681D8
    S328001058DEE6220CB3D39F955124A847261148A100B3C008900A460077220A0001829808460077223F
    S328001059010A0001809C37E9B111D0256002067421A60B1174230100F612F681E6220CB3D39FC0524E
    S32800105924167401CE11C001D011C26604F68221AA029FB39360F7F2B5A5182F2E2D9AA2A03FA70CD5
    S32800105947E4801B8405E460B58007A100B5C001840B247D03020021EE029F765874F6819F95512144
    S3280010596AEE0211CA3212C0F6122106439FDD5711C2B36088037A980B22D60212CAE9B111C26A01B4
    S3280010598D230101247D030200F6819FC052D20084092434484002C002840660BFF2B5980B6040F365
    S328001059B0B502C201CA9F884F01C4246002112A02C21228E65A009008E9B1112AEAB11128A50C2F1F
    S328001059D3A00A9A3F247D030100F5C1BC9C3A7424A447F4E10094026401A6422F9A3D3E3FA704F6CC
    S328001059F613FB840F243448010A246002F42124B360887F263448F4CB8A13C0F4CA8C12C26604F617
    S32800105A19822184029FB393256002A100B5C04084140168F421C0F4214011C0016AF421C2F42142D4
    S32800105A3C98299FA702A62421EE029F8197F6130AAE24064301089F7D5711C00368026A9C3702C0AF
    S32800105A5FF4CA8A12C0F4C98C11C2E060C180033111C0E060C380033111C26604F682218C029FB3E5
    S32800105A829362019F484BA102B5CA03D0019009228C022184029FAB4BAC2F2E2D9A3D3FA704257DAF
    S32800105AA5030142247E47F4E10094132434484001C002902F0158248347F4E1008C25251803425814
    S32800105AC8248047E052008807B29252587298176404F6819C3801C002C29FF059620198062418038A
    S32800105AEB725218AC2F2D9A3D3FA70C6004F3B5247D03010019BC74E4A0B484026401F6819F9551BC
    S32800105B0E21D60211CAF6122106439F855711C2256002014011C02300010ABCF6819FC05202C2302B
    S32800105B31E8E29408F4224001CA9F884FA106B0246002020021D6029F5B600AAE900DEAE19409242B
    S32800105B5434484002C002840605C203C49816F61324064301089F7D57F615247E4702009F1A95F6A6
    S32800105B7713F632F6519FF0592460026301530EA50C2F2D9A3FA102BB900DD20384039F42599FF238
    S32800105B9A5AA4BB002F9A3D3E3FA702A6237252C0240643420CCA03D0029004620152C0D3009015C5
    S32800105BBD9FA761253448D200900744527252C0989D44539899253448425552C12460020111323A98
    S32800105BE03942C5739C45ACF616F627F70000F7800C425473329C45ACF613F624F661F672F645F6CE
    S32800105C03349C4BD500840CD4008408D3008404D26494046C649802A62C23640044C1752506432490
    S32800105C2640430100F4C94A9F9498A6CA7BED51940D206400E85194046C649802A62C42C0D200843C
    S32800105C490A243448A6C4E024129817253448240643420CCA03D0018407A6C4E0245398024451A133
    S32800105C6C02B1243448E054108005E612809802C27FA3B12021B0049FD19342C0AA2F2E2D9A3DA295
    S32800105C8FD03FA70211C0F625A66D246002020021D6029F5B6077A6D6F6529FA262230004F612013C
    S32800105CB2C09C37AA2FA00D2D9A3D3FA62BA63AA62421B1049FD193A6A421B2049FD193247D030140
    S32800105CD5162411484508DD008805E05B22940CCD20900E241148F4E11F8C0660F7F2B1981CCD4006
    S32800105CF89008241148E05B21880CCD10900C241148F4E11D80046008F3B1241148440ADC008805C2
    S32800105D1BE05B16940CCC20900E241148F4E1138C0660FDF2B1981CCC409008241148E05B15880C24
    S32800105D3ECC10900C241148F4E11180046002F3B1247D030118CD089008241148E05B1C880CCD0266
    S32800105D61900E241148F4E119800660FBF2B1981CCD049008241148E05B1B940CCD01900C24114805
    S32800105D84F4E1178C046004F3B1CC089008241148E05B10880CCC02900E241148F4E10D800660FEEB
    S32800105DA7F2B1981CCC049008241148E05B0F940CCC01900C241148F4E10B8C046001F3B12F2D9A4C
    S32800105DCA3D3F251148D200900924AC0201000242980724AA0201000240FB900B9FC694A62421B345
    S32800105DED049FD1932F2D9A3D3E3FA702F626D200843F230C00228402F6619C3F23020022BC00F66A
    S32800105E1061E6220CB3D39C3F230200229402F661E6220EB3D39C3F230800223103F661E62210B335
    S32800105E33D39C3F23080022E60298B4D201846D246002493D5980EA9111C024124343005381F495F9
    S32800105E56C024B602420006C05281ED9743035341EF954206F676528143095341230400229602ED85
    S32800105E7991E9919C3F23080022D602F671E62207B3D39C3F230600226002F671E6220FB3D39C3F82
    S32800105E9C23080022EE02F671E62215B3D39C3F62209877D2028448230800220643F6619C3FF66557
    S32800105EBF200800E82523080022DE02F6519C3F230400226F02F651E62208B3D39C3F230400221457
    S32800105EE203F661E62214B3D39C3F23080022CE02F661E62218B3D399AED2038407F6219FD4869847
    S32800105F0520D204840E23040022AA02F6619C3F6204980ED2059003729807F6219F2C4A6208AA2FBE
    S32800105F282E2D9A3D3EA70211C0F6140100840374980920FF3FE8E19405642735980D2227009C4362
    S32800105F4BF615660E9C4EA62421FF3FED0104C01100A642AA2E2D9A73E961204246E8219AA64273DE
    S32800105F6EE961209646E8219A742440470123249246F42100247D03F4E1188C026401A6429A3D3E3C
    S32800105F913FA704F626A66B11C0F6819F2B5FA62AA6B39F625F02C09FC36011C2A6B5A6A4F6619FD4
    S32800105FB46B5F02C09FC360F6622054F5E8229C43660F200040E82130E8329C4EF421C2AC2F2E2D9D
    S32800105FD79A3D3E3FA704F616F625464602429F8F5F11C0670146460242F6619FA26211C20244F6FC
    S32800105FFA819FE94DF612014430E8E1941303C0249B470400F621EBC1ECE19404F642EB22F621AC2E
    S3280010601D2F2E2D9A3D3E3FF6160580F612319FD85FE9E580033198220580F6622100409FD85FE993
    S32800106040E58C05210040980F3E0080382300403221D85F9FB495AC2F2E2D9A3D3FF627A66475EA0C
    S3280010606364F615EC250540200643E8240200F6719F9B60ED21B3608001312F2D9A3F6620222247AE
    S328001060862140469C342F9A3DF6152440460100114062012D9A3DF625660EA630A614A6159C4DF63D
    S328001060A954A690A61AA61B9C4A2D9A9C43660E200020E82130E8329C4E9A3D3FF61405000102ED21
    S328001060CCC19FB460ED212F2D9A73E961E961E961E961E961E961200041E8219A3F9FD560F6144093
    S328001060EF00D0559003E62901F6412F9A3D3E3FA70211C0F6140100840374980920FF3FE8E1940515
    S32800106112640E35983720C631E8E18C0C2209009C43F615F6267E9819223F009C4366012007C0E890
    S328001061352120F3FFE8329C4EF615F6266E07660EF651F6629C4EE5242E21FF3FED0104C01100A662
    S3280010615842AA2F2E2D9A7520A60BE8E19408EA6120E646E8219AEA61200447E8219A3D3FD2078CDF
    S3280010617B09220900739F9B60981F73E622F9B3C3660EA630A614A6159C4D66019C4D243F00359CDD
    S3280010619E4A20C731E8212F2D9AA2A03F9FA702A62A9817BA8AA6A29FD560F6144000D0558408E0E4
    S328001061C1A0018403729807E65A0087E462012FA00A9A3D3E3FA70D11C454C62486470300243448FA
    S328001061E44202CA208403339887DA00888313CB9FA702B283A634EA0AEA66EE66203A03E8263435F5
    S3280010620714C015C2A62A7BED65ED65F667EDC720FCFFE82703CB98210184028611C712C93A3901CE
    S3280010622AC402C613CF9C54AC03CBDA00880804C705C914C015C220FCFFE826F670EEC087D4F631F6
    S3280010624D329C5303C004C23C3B9C46AC9D4EA2248A470300EB518C0F2488470200F613F620E950C0
    S328001062709402F62348C6E658008407F453C4940203C4F631A50D2F2E2D9A3F205AF4E8219C439CD9
    S3280010629352F78037F700009C46AC9F4BA02F9A3D3E3FA70711C012C456C6A67AF6819FFB60A62C6C
    S328001062B6D200840AE65A0084053111C06C0142C69FE860A6CA7BED95ED6502C0ED219FC36011C204
    S328001062D945C6A6C401C49F5E6102C09FC360F61201C49F8A62F616F6274AC67BED64EC64203A0366
    S328001062FCE8241100120201C2A630A614A6159C523F3E9C46AC9D4BA2AF2F2E2D9A3FF62322000456
    S3280010631F9C372F9A3D3E3FA70711C012C213C4F930840521010011C4E098CD9818A68C7DEE65F431
    S3280010634225C003C402C2014058C69C37114048C6B898E6580E97E3AF2F2E2D9A3D3E3FA70711C0FF
    S3280010636512C249CD13C4F930840521010011C4254047E05952941A981DB989A69C7DEE65F425C0CE
    S3280010638803C402C2014059C69C37114049C6E6590087E3AF2F2E2D9A3D3E3FA703F61654C2A642D4
    S328001063AB9FD560F6154040D05584204041901562555281528042C29FD560232000F6629F578F987F
    S328001063CE3A11C0E62B019805E6230111C0F6519FFE8E661EEE92EA92ED91E9919F168F735381622A
    S328001063F15552806602F662F6519F168F7353806602F66201C09F168FA100B3E70840A613C301E610
    S328001064144301A102B3C2FBE73804C004B012A3B320AB2F2E2D9A3D3FA702A62B9FA702A62A625545
    S3280010643752C05BC19826BA8AA6A29FD560F6144201BB5290174000D0558411D2559004D2058409C6
    S3280010645A6602F682F6419F168FE65A0087D5AA2F2D9A9C43660A200002E82130E8329C4E9A3D9C51
    S3280010647D4320F401E82130E83224E803359C4A2D9A3DA62BA63AA649A658DDFF804FD5FF8414D484
    S328001064A0FF8047D4FF840CD380803FD3808404D2009037F631A630A614A615E5E0858C18B8558423
    S328001064C31FB9548C10B9548417BA538C08BA53840FBB52940B24AE02A6B2A6A31100980F24AE0242
    S328001064E61300980824AE0221008011002D9AD200840421C0449AD20184042102439AD2028404218C
    S3280010650904439AD2039002319A217E479A3D3E3FA70224C044020312C0020720A60BE8E194020229
    S3280010652C059F8A62F615F62601C0A630A614A6159C523E3D9C46AC9D4BA2F6169FA702A6242400B0
    S3280010654F430504F42502F661759C42ED21AA2F2E2D9A3D3E3FA71211CA12CC13CE00D810D09009C8
    S3280010657224AE02010011C4980724C044020012C402CEF6219F6C64F61502CCF6219F6C64F6529F0B
    S328001065956C64F615F462CE01CC9F6C6402CA9F6C64E9C5F653A670A618A61913C014C202CE01C48F
    S328001065B89F6C64F61502CAF6219F7B64F616F627F6512228009C43F421C0F43AC2EE21EF32DD0064
    S328001065DB802D9C52F77A44F700009C4CAC9C3EF77A44F700009C46AC9F0698F61501CEA630A614F1
    S328001065FEA61511C612C8F8C4840C98063521FF7F988A3536983602CE01CC9F6C6402CAE9C2EDC2AD
    S3280010662112CA6609F621A630A614A6159C4D03CEE57770B6E6A670A618A619EBC1ECD204C605C8DD
    S328001066449C4AE9B5EAF601CCA630A614A61503C604C83C3BF653F664E9C3EAD4F631F6429C45AC9C
    S32800106667660A2000FEE821B4C4B5C59C4EE6EDFF801EE65DFF841CE65CFF8014E65CFF8412E65B48
    S3280010668A80800AE65B808408E65A008403250080F8D0900404D01500A5122F2E2D9A3D3E3FA7355E
    S328001066ADF686257D0301409F1665119601401194246002020012B3054224A804020624C0444209CC
    S328001066D0E9099FFE94F6532210279C373E039402B3E92221D6029F6850A100B3E70820A613C30134
    S328001066F324344842049FF3501188F662E62404B5D5F6619FD751119AF612F6619FE94D11AD1180D1
    S32800106716247E47010011AB029AA650A616A61712A713A90396A670A618A61913A314A5241148010B
    S328001067390011A124C044490259A0AAA100B3C008840902AB01889F1A9598020188119844A0EA0A8E
    S3280010675C01A19F7B64119C129E02ADA650A616A61712AF13B101A1A630A614A6153A3942A0E909B0
    S3280010677FA634A6359C45AC03A304A53C3BF4C9A7F4D2A99C45AC660A2000FEE821B4C4B5C59C4E06
    S328001067A2039C049E3C3BF421AFF43AB19C45AC240A00359C4A1190129202AD01AB9F7B6411AF129D
    S328001067C5B102ABF6219F7B64F4C9AFF4D2B111AF12B101A702A93A3901A302A59C45AC660A200014
    S328001067E8FEE821B4C4B5C59C4E03ABE627FEA670A618A6193C3B9C45AC660A9C4E660AF421AFF4C3
    S3280010680B3AB19C4D04A305A59C4A240A00359C4AF613F624E6E9008C11E65900840ED4008408D769
    S3280010682E008404D2009002333401900292DD008C10D500840ED4008408D3008404D2009002313257
    S32800106851A66EA67BA68AA698E5E0958C18B955841CBA548C10BA548414B7538C08B753840CB6522F
    S328001068749408A62EA63BA64AA6580398A6E2A6B3A6A4A6859F8E64F7B0020396029A01809F616566
    S32800106897AAA5352F2E2D9A2460023132113612386010F3B19A3FA70A230800228503F6819C3F24BD
    S328001068BA7D03010411C8230A00F6822113439F578FA50A2F9A3FA41E009F765FD20090079F054D5F
    S328001068DDD2009009A102B3E61210A3B3202F9A3D3FA1001D84069FC7879FDC50247D0305149FA7FB
    S32800106900027324814702009C42247E47F42100E9E5940E9F3C4D249D47E0520094039FCF772F2D75
    S328001069239A3DA2C0F6157C2411480100A630A614A6153A39244047423B73329C45AC66089C4EE9A4
    S32800106946E580026C01A6C2A00C2D9A3D3E240646440175333B3A329C45AC9C52240040000C3800C7
    S328001069690A389C46ACF7E031F76BF89C46ACF615F626F7FF46F700FE9C54ACDA00800521FF7F98AB
    S3280010698C07F651F6629D4BA22E2D9AD5008408D4008404D307940421FFFF9A3A399C45AC66069CBD
    S328001069AF4FF61184032101009A3DA2D03FA70411C2A642A65AA66D220040739FFE9411C07BED640C
    S328001069D220B602E82401C2F4C928E65D0084029C3A74F4E1C094026401A642AC2FA00D2D9A3D3EAB
    S328001069F53FA70211C0A64D9FA702A62C9818BC8CA6CA7BED64F424C076A6C5A6D401009FB869D2A9
    S32800106A18009007E65C0087E36201AA2F2E2D9A3D3E3FA715F61621FF7F11889FA702988E2406433C
    S32800106A3B400CC003906E49C259CC7252CDF464CCF645200643E825024012C8EE24050024114802CD
    S32800106A5E00244047423C739FFE9411CA2411480200244047423D739FFE94F61230E8E5945201CA54
    S32800106A81F421C8E9E58C0B01C8F4C9CAEDE18802F651EAE19402F621F464CCEE24110030E8E1945F
    S32800106AA42CF4C9C89C3AF4E1CA8C2249C259CE7252CFF464CEEE240100F4E1888802118842C2B2B1
    S32800106AC78353C2D200876A7498166401981242C273E964EE2403401300E097C257C2980325114873
    S32800106AEA48C2E6580397E4D40084D2018830E8E194CB729F2A642440430100118A62019FA05B4380
    S32800106B0D8CD200900BA632C2FCE61201528C987DC3FCE61302538C240643420CCA03D0028407A6B0
    S32800106B3032E61208528C240643400CC008845B9FA70252C376313211C412C69831A66256D09FE85B
    S32800106B53602440474A137BED92EA64E9240100A630A614A61511D112D301C402C6F421D1F43AD3C5
    S32800106B7611C412C646D0B696E056C383CA01C402C648C379359C4A11C0230200F6822100439F579D
    S32800106B998F60FBF2B2230D00F6622106439F578FE4B3B3C301E64301A102B3C2FDB360C002B012DA
    S32800106BBCA3B3206008F3B56201980172A5152F2E2D9A3D3E3FA706F616A64AD5009060246002011F
    S32800106BDF0F9C3A11C4313211C012C27BED64200643E824010011C1F662E9C2F6219C3AF61502C1E9
    S32800106C02244047423A739FFE94E9558C2B01C49F2469D200902203C42411480200244047423B7343
    S32800106C259C3720FF00E8518C0CF613F662F6819C3B06C1980136F661AE2F2E2D9A3D3FF6154075C9
    S32800106C4890166415216F029C38230800F652E6243CB5D521DE029C3F2F2D9A3D3E3FA71711D1F629
    S32800106C6B14403590F1A100B2C00890EA26600201919F5169F61524114802002440474239739F110B
    S32800106C8E95E9C588CE018F9C3A11CD240643400CC003901C244047443701D1E6223CB3D39FF3690B
    S32800106CB1D20090A501CD9F2469D200909C60F7F2B2240643400CC0038413244047443801D1E6229C
    S32800106CD43CB3D39FF369D200908324600201119F5169F61502CD2440474239739F1195E9C5886A9C
    S32800106CF7230D00220643F6819C3F9FA702A62C9840BC8C2406434D0CE60D035CCF7959D0F465CF8C
    S32800106D1A01D1ED2111D3F65420B602E82414D5F614013C04D5F4C9289C3AF61201CD9F9B60A6D59F
    S32800106D3DA6C49FCE6BF680E8251140E65C0087BBF6819F276AD2009004620198087204D15235980D
    S32800106D600172A5172F2E2D9A3D3E3FA704F626E62245B3D311C2018204C2110002C2E624BBB5C523
    S32800106D8312C24A867BF6619F2160ED64F424C2113C4A86ED6405C2EC2520B602E824017C11184600
    S32800106DA686A66A7BED64F424C2023C12C0A100B5C001901D2434484003C0019014246002020021B3
    S32800106DC9D6029F5B6011C0F6629FD85F1180F4918011804A867BF6619F216004C0E9C4F6419C3AF9
    S32800106DECED64F424C2204E00E8241100F48180E9811180F6619F216002C0E9C2F6219C3A4A86ED3A
    S32800106E0F64F424C2204E00E824F4E10094021100AC2F2E2D9AA2A03E3F9FA702A100B2E70810A647
    S32800106E321AE60A01E65A00903F249446070024924606009819B282A62475EA64207D03E8240308DD
    S32800106E55EFE39407EEE388037A9806D20087E36A019FFD01264047F4E19F8C089FFD01F4E1A1888F
    S32800106E78017AA6A22F2EA00A9A3D3E3FA70811C4A64A26600201B602B811C012C2645601C49C385E
    S32800106E9BE65A00901F313211B612B8A100B2E70810A612C20104C4523960DFF2B29F246E04C4528D
    S32800106EBE35A102B4D2FF8407245B494213980DD20190043536980F245B494214733205C006C2E93F
    S32800106EE1C5EAD601C4E62247B3D311C6244047013532A6A8A6B7B55D8C18B55D8418B45C8C10B400
    S32800106F045C8410B35B8C08B35B8408B25A9404A628A637A682A67304C611006010F3B1A82F2E2D77
    S32800106F279A3D3E3FA715F61654CC204B00E826428073E964204047E824012BA630A614A61511C0FF
    S32800106F4A12C220FAFFE826018020BBFFE82623E8032440470231205AF4E8219C379C3AF612A650A0
    S32800106F6DA616A617F422C0F43BC212C813CAF664204D00E82440009082245B49451355CD7656CEF3
    S32800106F903414CF204700E82601803220B9FFE826F421CDF43ACF256002F42176F43A789C539C3E43
    S32800106FB311C412C601CD02CFF42176F43A789C539C3E3A3901C802CA9C41AC11D112D3244047015B
    S32800106FD633A630A614A6159C523A3901D502D79C46ACF7803AF700009C46AC9D4BA29C3AA630A654
    S32800106FF914A61503C804CAE923EA3413C814CA42CC73E964EE24204E00E8240100900E323A390175
    S3280010701CCC02CE9C45AC11C812CA01C802CA9F9769A5152F2E2D9A3D3E3FA70CA62E246002010A79
    S3280010703F020C11C012C2000838000638240646420173329C45AC9C532400400008380006389C464F
    S32800107062ACF7E140F73B279C4CAC9C5111C412C62434484002C00190242571490641660E01C002F6
    S32800107085C29C4D0343EE539402F663F634359C4BF421C4F43AC611C412C67FEF67F674200643E861
    S328001070A82401C402C60400359C4B11C812CAF675209E02E82566060140329C4D9C539C3E9C51F47F
    S328001070CB21C8F43ACA9F97691140A50C2F2E2D9A3D3E3FA71B11C99FA70252C02434484000C01086
    S328001070EE84CC98D9E082C052C0A62401C99F286FF61543C053D77454D804D94000900CF464D720CA
    S328001071119E02E824150098AC42C09F337046C0246002020021D6029F5B60F613F462D7F621209E10
    S3280010713402E82111CBF614040014C53111C715C111C306C107C3F426C5F43FC7A6C2BD12BE12BF71
    S3280010715712D200906904C9EA2414CD01C102C33A39F631A630A614A6159C45AC11CF12D101C502E2
    S3280010717AC73A3904D1013CA630A614A6159C45ACF421CFF43AD1F664F6759C4B04CD113C04CB0438
    S3280010719D0014D33111D501D302D53A3901C502C79C45ACF664F6759C4B04CB1100980901C9E62282
    S328001071C04CB3D311D943C0D300872723080002C9E6243CB5D521D6029C3F640F2160029C38640C82
    S328001071E321B6029C382431034008D0028404640154089FFD0124A247F4E10094039FCF77A51B2F21
    S328001072062E2D9A3D3E3FA709F6169F054DA62B40BB849EE460B58099D20084092434484002C008EA
    S32800107229908C247D03010011C2240643011511C49FA70252C6983053C77353C8F464C7200643E800
    S3280010724C24010D11C0F682F6619F686D4AC6A6A6246002023221EE029F5B60A6A475EA64EE241112
    S3280010726F3C42C6B28353C6D20087C6230800F662E6243CB5D521CE029C3FE65B0084092434484068
    S3280010729202C0109007F6619F636C98037959B5620152BB60FBF2B2204B00E8266302538020B5FF7F
    S328001072B5E826607FF2B540BB9029F6619FDB7040B590046008F3B2F6619F426C9FC045247149401B
    S328001072D800C008900521D602980321CE029FDF8660FEF2B2A5092F2E2D9A3D3E3FA708F61654C733
    S328001072FB257D032460020140113425064324FA02015D025F111A121C404CC0049010A102B2E612C6
    S3280010731E1043C7D3009009C2FB9808A102B2C2EFE61204A3B22074F6619F816E44C754B524064302
    S32800107341420CCA0BD00A8413D400900C9F246ED200900521010098013152B5247D03010011C29F6D
    S32800107364A70252C69819A63A7BED64207D03E824020812C0011A11C4F682F6619F686D42C6B283DA
    S3280010738753C6D20087DD630153BB2460025323F6619F426C204C00E8266401548020B4FFE826A137
    S328001073AA00B5C001840C204B00E826548020B5FFE826F6619F09729FCF772431037555086401F69A
    S328001073CD619F816E6008F3B5A82F2E2D9A3D3E3FA71D11D254D42460020136023811CD12CF244019
    S328001073F047010332E055D08419E054CF8C94E054CF840FE053CE8C8AE053CE8405E052CD8C809F41
    S32800107413054DA62A9F765FD20090046010F3B5A100B3C010904DD2009007E65A009044980CE65ACA
    S32800107436009007A100B5C01084362434484000C008902D2499470100220A009C44E055D08C3AE085
    S3280010745955D08419E054CF8C30E054CF840FE053CE8C26E053CE8405E052CD8C1CA102B3C2EFA355
    S3280010747CB32060EFF2B504D2403B90039B247760EFF2B19B2477769BC3769FA7029837A6C677EB9D
    S3280010749F65ED65F425D2EB64207D03E8240108A630A614A615F42154F43A5611541256011AA63018
    S328001074C2A614A615F42164F43A6611641266A6C2B28CD20087C35CC604D2F491371137254047F4C4
    S328001074E5C95885759FA70252C669019847A63677EB65ED65F425D2EB91E964EC64F424D201540270
    S3280010750856F4C900F4D20213DB9F95942440474A1E7B36E5E0D58C18BD558417BC548C10BC5484CA
    S3280010752B0FBB538C08BB538407BA5294037959D142C6B28353C6D20087AD42D1D200900604D240AA
    S3280010754E34840F01CD04D2F4C902244047F4511A80C0247D03010011C27204D252399F246E04D23E
    S32800107571523501CD11029FA70252C622FF7F12CB24008014C9985153C77959C8F461C7E96102D244
    S32800107594E92212D5244047041814D73111D9F6240114021604D705D99C4AF61611C004D50124023C
    S328001075B72604D705D99C4A11C4F66102CBEEE2940216CB04C9E9E4880211C9F68201D29F686D4297
    S328001075DAC6B28353C6D20087A501D2E62249B3D311D202C9F4CACBF614120001D2E62204B3D311F3
    S328001075FDD2620104D2520002D2E624F7B5C512D2F624520002D2E624BCB5C512D242CDF624523AAC
    S3280010762042D104D25234F645201400E825231000F65201D2E62204B3D39C3F6420F651981604D23C
    S32800107643403B901701CD1102735334642001D2E62214B3D39C383104D2113705D2204400E825406D
    S3280010766640904342CD04D2E0C23A244047E052258034795940620104D2523B01D29F636CD20084F2
    S328001076890604D24036900D7204D25236A4BB0301D29FDB70A102B2C2FBE61201A3B2206010F3B156
    S328001076AC01CD04D2F4C902244047F4511C800460EFF2B104D2463901CD04D2F4C900244047F4511A
    S328001076CF05800E01CD04D211006301533660EFF2B1248D47010032E055D08419E054CF8C1EE054AD
    S328001076F2CF840FE053CE8C14E053CE8405E052CD8C0A257D032460020240123445D4D500900AD62C
    S328001077150090066020F3B2980E60DFF2B29808A1001E87189B9674A51D2F2E2D9A3DA1001D8444AB
    S32800107738251803247D030104A630A614A615F42140F43A4211401242012AA630A614A615F42144AB
    S3280010775BF43A461144124602060154EAE194021254247D03022C2418030116EAE1940212162D9A38
    S3280010777E3D3E3FA702F615F62613C0F6340700F671A630A614A6159C523A39F651F6629C54ACDA1C
    S328001077A1008C2404C00702F671A630A614A6159C523A39F651F6629C54ACDA008009F651F6629D45
    S328001077C44BA2F617F671AA2F2E2D9A3F9FA7029811B282A62475EA64203103E82423E803130024C7
    S328001077E73103D20087E8E0800884037757082F9A3F9FA70224B6026401980C40018401742003009D
    S3280010780AE824A632B283D20087EEA6422F9A3D3F9FA702A62E247D030114A6E4759C48F61598213C
    S3280010782DBE8EA6E475EA61F61420B103E824F653F4CB00F614201803E824F4E30894021308E65E75
    S328001078500087DA2F2D9A3D3F9FA702A6276E7F9819B787A672732203009C42F61420B602E824427D
    S3280010787300B25E9402A62ED70087E3256002E05E7D94362440470200334279B752802AB752841A20
    S328001078964278B6528020B65284104277B5528016B55284064276B452800C2460025E3D24180360CA
    S328001078B904F1132418034213CA0CD0049003729806C2FB521362012F2D9A3D3F9FA702A6263198D9
    S328001078DC0FB686A66475EA64201803E824F42108D60087EDB3608001312518034E52900D0450EC2B
    S328001078FFC1A6E4759C48E9241450251803BE92525224A6470200B56088080150EAE1880212509FA8
    S32800107922A7029811B282A62475EA64201803E8242301801308D20087EB2F2D9A3DA2C03FA7209F95
    S32800107945A702A62C9839BC8CA6C29FD560F61543414040D0558428B382D2FD8C22D305901E2320DE
    S3280010796800F652E62501F6819C3F62FF52C1625552C0232000F682F6519F578FE65C0087C2A5202C
    S3280010798B2FA00C2D9A3DF6152460024236E01237E01238E01239D2009009D400840AE4A01B90055C
    S328001079AE2227439803222C03230400F6519C3F2D9A3D3E3FA702F6162460024E364F37423852C08D
    S328001079D1423952C1E512FEE012C0E012C1D200902DD4008405E4A01B842424180301040206A6E888
    S328001079F4A6F905C09C4A118224180301000202A6E8A6F905C09C4A1180980A230400221D43F6612E
    S32800107A179C3FAA2F2E2D9A3D3E3FA70825FA02005038004E38014602489C41AC3A399C46ACF616CE
    S32800107A3AF627F78040F70000014A024C9C46AC034A044C3C3B9C46AC3A39F661F6729C40AC9C3EEB
    S32800107A5D11C012C2005038004E38014602489C40ACF615F6267E01C002C23A39F651F6629C40AC60
    S32800107A8011C412C602C003C23B3AF651F6629C41ACF615F626248F470100A630A614A6159C523A67
    S32800107AA339F651F6629C46AC3A3901C802CA9C54ACDA0088026E01A6E2A82F2E2D9A3D3E3FA71CFC
    S32800107AC69F1E7AD200912724FA020106020811D812DA010E021011CC12CE010A020C11C812CA0113
    S32800107AE9CC02CE3A3901DC02DE9C46ACF615F62602C803CA3B3A01CC02CE9C46AC3A39F651F6629A
    S32800107B0C9C41AC11D012D224FA020312041413C414C624FA020116021811C012C23A3901DC02DECE
    S32800107B2F9C46ACF615F62601C402C63A3901CC02CE9C46AC3A39F651F6629C41AC03D004D23C3B82
    S32800107B529C4CAC11D412D6F70000F7000001D802DA9C54ACDA00948AF7803FF7000001D802DA9C64
    S32800107B7554ACDA00887901C402C63A3901D002D29C46ACF615F62602C003C23B3A01CC02CE9C4627
    S32800107B98AC3A39F651F6629C41AC03D004D23C3B9C4CACF615F62601D402D63A393122803F9C4183
    S32800107BBBAC3A39F651F6629C4CACF78043F700009C46AC2391479F7E7724FA02111A01D402D69FDA
    S32800107BDE1CA13A39312261C39C4CAC2395479F7E7724FA02111CA51C2F2E2D9A3FA70E9FF777D29B
    S32800107C010090336401F6819FBF79241803011011C49FC17A24FA02011A021C11C612C86401F681EF
    S32800107C24E6220AB3D39F9079230E00F682211D439F578FA50E2F9A3DA2C03FA62CD20E9403749889
    S32800107C471BA636246002020021D6029F5B60F615A6C29F766174E9E580026401A6422FA00C2D9A96
    S32800107C6A3D3E3FA703F61612C056C26203E7256020B602E825D70090142434484002C004841624F2
    S32800107C8D0643420CCA03D002840B43C242409F3B7CD200905DA102B2CA14D0108454240643400CB9
    S32800107CB0C003904B4440D40E8C45244047421073F4E1808C1FA6429F7661F612F6619F129704C08D
    S32800107CD3110030E8E194046A0198196004F3B2981242C273E96420B602E824311130E092405240A9
    S32800107CF67A640EF6619C3898017AA6A2AB2F2E2D9A3D3F24600231321136123860EFF2B1A100B2D9
    S32800107D19E70840A613E64301C301A102B3C2FEC301B312A3B32064192118039C382518032406430C
    S32800107D3C021B125001170219115412562F2D9A3D3E3FA70211C064249C389FA7029822B282A62409
    S32800107D5F75EA64EA65ED65F425C0F64620B103E8260380134220B903E82403001352D20087DA2411
    S32800107D827D03010005C01162AA2F2E2D9A3D3E3FA70A11C4F625264047038E34A630A614A6151118
    S32800107DA5C012C23C3B01C402C613CA14CC9C45ACF616F62703C604C821E80332EBC1ECD23A39F6F4
    S32800107DC851A630A614A6159C45ACEE21EF3224E803359C4AF61624004302002440474211739FFE7C
    S32800107DEB94F614A690A61AA61BF424C0F43DC2F662A650A616A617E5E0B78C18BB578418BA568C0E
    S32800107E0E10BA568410B9558C08B9558408B8549404F641980C02C4E9C2F621EEE28802F661A50AE4
    S32800107E312F2E2D9A3D3E3FA72511E054E4A6429FD560F6144001D0058407F616E62D01980742E4F9
    S32800107E549FE860F616232000F662F6819C3FA100B2C00484E1620340E4E7250020B602E82542409D
    S32800107E7773E991E964EE24010011E22406434C0CE6AC03D002840702E09F8F7D11E046E402E2F659
    S32800107E9A81E62220B3D39F5C4ED200909F02E0424073E991E964F680E82412004040A20003E3F606
    S32800107EBD81E62203B3D39F2363A9404184134040A20003E302E1F681E62203B3D39F5E63A9E6AC06
    S32800107EE004906740429007E6AC0BD002905C44E4F6819FA063E0924052406301534153424CE47D3B
    S32800107F0303E0EE61F61420B602E8241330243103E08008840CF615EC2502E201409C371140772492
    S32800107F2640474A137BF6612203009C42F61420B602E824420073E981E9C58409670198056004F3C5
    S32800107F49B277A672A5252F2E2D9A3D3E3FA704F61554C39FA70252C224180360F7F0132600019895
    S32800107F6C313111C047C3A6C6F682F6519F6A7CD2009016A6C401C09F357ED2009004A6D0F3BA244D
    S32800107F8F18036008F113201000E825BD6DBC9CE05CC283CAAC2F2E2D9A3D3E3FA711243448E06006
    S32800107FB2008009240643400CC00890092434484001C00190CB240643420CCA07D00684C0A100B2FD
    S32800107FD5C00890B926600240A384B201919F516911CF018F9C3AF6122440474239739F1195F610A4
    S32800107FF8F450CF9495018F9C3A9F2469D200908A230D00220643F6819C3F9FA702A62B984DBB8B65
    S3280010801BA6B6246002020F21DE029F5B6011CD2200402440474228739FFE9402CDE952942A2406F3
    S3280010803E43400CE70820A61AE60A01A6BC7DEE61E961207302E8219C3DA6A5A6B49FCE6BEE64F606
    S3280010806180E8241100E65B0087AE660D220643F6819FA997FB901A256002014F30E8E19410F6810F
    S328001080849F276AD200900769015963A4BB03A5112F2E2D9A3D3E3FF6159FFA7BA100B1E70808A600
    S328001080A714C401F651E62224B3D39F537F9FA87F62059F2A6460DFF2B19FA702A62A981ABA8AA66D
    S328001080CAA6246002020021D6029F5B6077A6A6247D0302009FA262266002E65A0087DE7401BA9FF5
    S328001080EDD361245B494E137FE92701B602B8F67536B55D8C18B55D841DB45C8C10B45C8415B35B90
    S328001081108C08B35B840DB25E9409E9C7246002173A980624600231113A2F2E2D9A3D3E3FA70B118E
    S32800108133C3264047019411C02434484001C0049010247D0301189F974DD2009004049614C09FA79E
    S328001081560252C29841E089C259C2A69C7DEE65F65120B103E82111C5EE64EC6414C903C0F6140261
    S328001081790001C3F421C99F229520B903E82501C9E62210B3D311C903C0024001C3F421C99F2295AD
    S3280010819C43C2D30087B903C0247D03020001C3E62220B3D39F2295A50B2F2E2D9A3D3FA702F6155D
    S328001081BFA646246002020021D6029F5B6011C0F6819FFB60B2925240735341AA2F2D9A3D3E3FF651
    S328001081E2159FA702A62C6D7F9822BC8C640EF6519C386403E7C140A6C420B602E8219FB981B25D38
    S328001082059402A62D201000E825E65C0087D92460025D3D2F2E2D9A3D3E3FA719F61512D656D8A178
    S3280010822800B2E70840A613E64301C301A102B3C2FEC301B312A3B32056C856D47252D5F466D4EE83
    S3280010824B66F661E62210B3D3ED219F949511C6F651E62220B3D39F949511C4F651EE219F94951131
    S3280010826EC2F682EA91E9919F216011CE30E8E18C057555CD989EE0A2C7E72802A612E6420152CDF8
    S32800108291D200908D05C6264047241148020001A99FFE94E9B1E9E5947846D8246002020F21DE02C9
    S328001082B49F5B60F61522004042A7739FFE94E955945C246002050F241148020042B7739FFE94E970
    S328001082D7E58048660145C844B701CE9FB869D20090394AD87BED6420B602E82402CEF4CA2824601C
    S328001082FA02010F9F9B60F612ED64EC64206002E824F81484041114980FF461D4E96146A67720739F
    S3280010831D02E8219C3B01C69C3AF614251148014025404702479C48E9E4951B46D8246002020021C2
    S32800108340D6029F5B6004D6110E05C606C246D802C49F8F5FF652F663E9C3F6319F196311D09C3A8F
    S3280010836320FF7FE9C084046004F3B22434484000C040904901C29F974DD20090407746D802C40409
    S32800108386D6010E9FA262F61322E80301D09C37F612243103B360800A6004F3B262025208981840C8
    S328001083A90884046301530842D873E964203103E82412006001F3BB04D6040E14CB49D859C972521F
    S328001083CCCA01C92203009C42F61520B602E825E082409F766111D242409F7661F616E082409F763B
    S328001083EF61F662E9C22440474209739FFE9402CBF4CAD2E9E2804D04D6040E14C0F6819FFB60052C
    S32800108412C045D8A62401C49F5E61F6529FC360E9B201C49F8A62F615F62601D0A630A614A6159C93
    S32800108435523E3D9C46AC9D4BA2F464C920B602E8241130F61304D6020EF6419F7A9624310340086A
    S32800108458D002844501C29F974DD200903C49CDE6590090354CD87DEE65F654200643E82402002479
    S3280010847B6002F4B1009F9B6020B602E825F421CEB3608001311160A4BB03EE64203103E82421E80C
    S3280010849E031100A5192F2E2D9A3D3E3FA708D200901C641A21FA029C38246002257D030140F4C930
    S328001084C13424FA0211009FDC50982524FA0205020604247D03020424F60201029F3C4EA630A614E2
    S328001084E4A615ED21EE3225FA0211421244256002407C84E0A1001D84DB247D030700F4CF74F6719F
    S32800108507A630A614A61511C412C624FA020102020424E100359C4AF612A650A616A61712C013C2DC
    S3280010852A03C404C63C3B01C402C69C45AC9C523A3924FA02011202149C40AC25FA021152125405D5
    S3280010854D40A6B0A61CA61D3E3D01C802CA9C45AC9C523A3924FA02011602189C40AC24FA021116BC
    S32800108570121801C002C23A3901C402C69C45AC9C523A3924FA02010602089C40AC24FA0211061233
    S32800108593083E3D01C402C69C45AC9C523A3924FA02010A020C9C40AC24FA02110A120C3E3DF651D5
    S328001085B6F6629C45AC9C523A3925FA02014E02509C40AC114E125031321142124417409FDC50A865
    S328001085D92F2E2D9A3DA2C03FA70211C09F327701C09F2D81A1001D84A1244047020033246002420C
    S328001085FC39B752805EB752841A4238B6528054B65284104237B552804AB55284064236B452804074
    S3280010861F05C0206400E825E092405240244047E05202802C9FA702A62C725240981DBC8CA6CA7BF7
    S32800108642ED61E961E961E961E62224B3D3A6C602C0E92201C09F1C82E65C0087DE7401C0E62224E2
    S32800108665B3D39F537F9F18789F5678D20090106001F3BB6008F3B59FD3789FC17A980B9F9F5AD2E7
    S328001086880090046020F3B1729FA784AA2FA00C2D9A3D3FF615206400E825725240209CFFE8259FF6
    S328001086AB077D62019FA784F6519F4B7DF651E62224B3D39FDE812F2D9A3DF6152471490106020813
    S328001086CE114012422D9A231200224A039C3F62129A3D3E3FA71511CF2471494000C00190CB2406C0
    S328001086F143420CCA0490C2CA03D0028407A100B1C0028404CA0890B123080002CF2152039C3F9FDA
    S32800108714A70252CD9F2658244A03E6234011107252CE98334CCE7DEE6504CFED2414D3F6512006ED
    S3280010873743E82111D1244A03031004D3F4CB00220040F61401009F7D57F680E8251140E099CE596D
    S3280010875ACE42CEE052CD83C644CDF6819F819711CB2471490701010311C87353CA98384CCA7DEE01
    S3280010877D65F684ED2401CBF4C900F61421FFFFF6729C49204A03E825F610EC50940AF641F6729C3F
    S328001087A0421140980524FFFF1440E099CA59CA07C842CAE052CD83C198076412214A039C38A51565
    S328001087C32F2E2D9A3D3E3FA701A100B1C010908CE480B4900B9F3C4D247149E0520A947C9FA7026C
    S328001087E652C02471494F00E60F02A10D1D77254A0366017C7E983101409025E65F009015A6C47587
    S32800108809EA64204A03E824F451008011A67CA66E980BB61EE65D008404E9811140B666ED95ED9546
    S3280010882CB797E057C083CAE65F009014E65E00900FA6C273E964204A03E824F48100110024600208
    S3280010884FF4900A100A30F4380C100CA31EE09803A41E00A92F2E2D9A3D3E3FF615F6242671494EEC
    S3280010887280E6AE04905F02400342A642B512B612B712D200901DEA81F63230E8D211401242A62692
    S32800108895B316B416B516D600843560EFF2B1982FA100B1C0109028204900E824428573F4E100881E
    S328001088B810E6AE10900521D602980321CE029FDF8624714901060208114012429FC7872F2E2D9A10
    S328001088DB243080010502079A3D3F2430800101020319BF1AC160FEF00025928060DFF040A102BE88
    S328001088FE90055200A4BE002100109FD8912F2D9AA2A03FA62A9F6B896320A6A29F808924908060DE
    S32800108921DFF00262DF5200322100109FC8912FA00A9A3F2492806020F1002100109F019209BF0AD0
    S32800108944C12F9A3D3FA62BA63AA3C3202110109F8089A6B3620C9F7C8D243080725200E61A015A72
    S32800108967002F2D9A3F2100109F8089210CE09F7C8D2430807252002F9A3D3FA62AA63B2100809F46
    S3280010898A0192BBA3E403C8BB0ABA13A3C830620B9F7C8D2100809FD8912F2D9A3D3E3FA701A62A01
    S328001089ADF626428052C0A6A29FCF8B7B43C0B25384046B0198074380A6A29F1A8DA6B2A92F2E2D6E
    S328001089D09A3D3E3FA703F591CB11C02100809F019222C60062059FA68952C222C50062049FA6892F
    S328001089F3A62A22C700620A9FA689A62C22C800620B9FA689A62D22C900620E9FA689A62B22CA00A8
    S32800108A16620F9FA689E00AC2BC0ABD0ABB0AE50C2A6D10F495C002C0A6D29FA689B20CBD9D15C014
    S32800108A39E65D1587EB2100809FD891A6C2AB2F2E2D9A3F2100809F01922103009F1A8D2100FD9F21
    S32800108A5C1A8D2100809FD8912F9A9AA100C9E70802A6129A3F2100809F928C2100809F548B2F9AFC
    S32800108A7F3F6380A6329F548B6380A6329F928C2100809F548B2F9AA102C4A103C6A3C4309A3D3E69
    S32800108AA23FF615220080F6219FC8912100809F019262039FCF8B620B9FCF8BA3C820620F9FCF8B14
    S32800108AC5A3CA20F9509055ED961DCBA103C6C33F4240C2C0B213A3C63062059FCF8BC20F4340C30D
    S32800108AE8C0B21362059F1A8DA4C502A4C900A4C7002104029F1A8DA103C9620E9F1A8DA103C76283
    S32800108B0B0A9F1A8D6A104380EE96A6A29F1A8DBA9AE65A1587F02100809FD8919F4B8A2F2E2D9A31
    S32800108B2E3D3FA62AA63B2100809F0192BBA3E403C5BB0ABA13A3C53062049F1A8D2100809FD89185
    S32800108B512F2D9A3D3FA62AA63B2100809F0192BBA3E403CABB0ABA13A3CA30620F9F7C8D210080FD
    S32800108B749FD8912F2D9AA102C973E72804A612A23073A9E70804E811C2019A3F2100409F928C216B
    S32800108B9700409F548B2F9A3F2140409F548B2140409F928C2100409F548B2F9AA2A03F2100809FF9
    S32800108BBA019262019FCF8BA62A2100809FD891A6A22FA00A9A3D3E3FA70152C0D2248C4236983722
    S32800108BDD42C09F738DA62AD3008427E65B00901C42C0D2009004D2038409E512ACBA5284069820C8
    S32800108C00BC5A901CBD9D9F4101A6AC6B019806BD9D9F41017B0CCBE05D0697C162FF9802A6A2A9CE
    S32800108C232F2E2D9AA2A03FA62A2100809F0192A6A29FCF8BA62A2100809FD891A6A22FA00A9A3D1E
    S32800108C46A2C03FF6152100809F01927CA6C29FCF8B5240ED95BC9CE65C1587F02100809FD8912F87
    S32800108C69A00C2D9AA2A03F2100809F019262039FCF8BA62A2100809FD891A6A22FA00A9A3F210217
    S32800108C8C029F928C2F9A3D3FA62AA63B2100809F0192BBA3E403C9BB0ABA13A3C930620E9F1A8D35
    S32800108CAF2100809FD8912F2D9AA2A03FA62AE60A0F600FE400C7BA50901B2100809F0192A103C790
    S32800108CD2C3F0BA13A3C730620A9F1A8D2100809FD8912FA00A9A3D3FA63AE50B32A632E402C6B2CD
    S32800108CF55B901F2100809F0192BAA3E403C6BB13A3C630A630F3C462059F1A8D2100809FD8912FE6
    S32800108D182D9A3DA2C03FA62AA63CD2248C2C7B9822A6C3A6A29F7C8DD3008412E65A039419A6A2EE
    S32800108D3B9F738DD3008404BC52900CBB9B9F41010CCBE05B0697D72FA00C2D9A3D3FA62BA63A21AE
    S32800108D5E00809F0192A6A3A6B29F1A8D2100809FD8912F2D9A3FFC609C31FC502F9A3FFC609C32BE
    S32800108D81FC502F9A3DA2C03FA62CA63BA64AFC609F738DA624D3008410E502ABBAA3B403B213A6E6
    S32800108DA4C29F7C8DA624FC50A6422FA00C2D9A3D3FA62BA63A2100809F0192E65A008411A103C64D
    S32800108DC7C3C0A6B2C20FB312A3C620A3C4B0A103C662059F1A8D2100809FD891A102C6C20F2F2D0C
    S32800108DEA9A3F6480A103CD62099F858DA103C9E61310620E9F7C8D21007F9F7C8D2F9A3D3FA1004A
    S32800108E0DCDC0109005210100981D62039FCF8BA62A7BBBBBBAEABBBBBAEABBBBBAEABBBBBAEA21F1
    S32800108E300100ED012F2D9A3D3FA62BA10ACD62039FCF8BBA12C210A6B3C3C0B312A3CD206480212D
    S32800108E5309009F858D2100809F2E8B2103EF9F7C8D21007F9F7C8D6303A6B29F548BA100CDC04086
    S32800108E7690076380A6329F2E8B6480A103CD62099F858D2F2D9A3F2492806010F1002100089F0113
    S32800108E999209CE2F9A3F244080010119CE24928060EFF0002100089FD8912F9A3F9FE28E32210052
    S32800108EBC089FC8912F9A3F2101039F8089244080620152002F9A3F2103039F80892440806201529F
    S32800108EDF002F9A3D3F25908060EFF0422100039F808924408072520062EF52402F2D9A3D3FF6158B
    S32800108F029F8F01D200900A9FB88FF6519C289F8B8F2F2D9A3D3E3FA701F616F62556C09F8F01D25B
    S32800108F250090249FB88F46C0F652F6619F119B46C0F652F6619FA997FB900946C0F652F6619FE34A
    S32800108F488F9F8B8FA92F2E2D9A3D3F05C498053D3F25805F393A3B9F8F01D200900D9FB88F2B2AF2
    S32800108F6B291DDC2F2D9BBF9C210000AE2F2D9A3FA100D19009A4D1002100409FD8912F9A3FA100C3
    S32800108F8ED184062100409FD8912F9A3FA100D184162100409FE391FB900D9F2B93E61280A3D1205D
    S32800108FB162019801722F9A3FA100D1900C9F2B93607FE400D1B25090062100409F01922F9A3D3FA2
    S32800108FD49FB88F9C20F6159F8B8FF6512F2D9A9BDC9D3D3FF6159F8F01D200900A9FB88FF6519CC2
    S32800108FF7259F8B8F2F2D9A3D3E3FA701F616F62556C09F8F01D200900E9FB88F46C0F652F6619C08
    S3280010901A249F8B8FA92F2E2D9A3FA7016601F6829C2342C0A92F9A3FA7026602F6829C2301C0AA88
    S3280010903D2F9AFC60249080725200520152025203520452059A3FE72810A60263309F548B2F9AA119
    S3280010906002D29A63FF98119AFC60C23FE442D2A3D220FC503198019A3FA635A62421D2009F9E9482
    S32800109083A103D2620D9F7C8D2F9A24148060F7F0009A241080420373E72804A612A23073A9E708B1
    S328001090A604E811C2019A3F249280607FF0002100209FD8912F9A3F24108064045404745404E61369
    S328001090C901A30030520662045207322100209FC8912F9A2410804203E72802A6129A3FA624C4180E
    S328001090ECC307B31424108054076580A6242114809F9E942F9A2414806008F1009AD2009008245024
    S3280010910F806008F1009A24508060F7F0009AA624A635A100D390052101009815246080420073B3F6
    S32800109132B3B2E2B3B3B2E2B3B3B2E273C201A3D320246080620152005401D400900C62045200D5F2
    S328001091550090046002F1009AA100D390042101009A246080420073B3B3B2E2B3B3B2E2B3B3B2E2F5
    S3280010917873C2019A2460806001F10024908062FB52009AFC60A620F3DBFC509AFC60B2A2E402DBD4
    S3280010919BA3DB20FC509A3F211900A62421DE009C3824DE00628452021CD421FFFF19D6A4DA00A4A5
    S328001091BEDB00A4D800A4D9002F9AFC60E9A3F503D6EA01E9131BD6FC509AFC600AD6E9121AD6FC44
    S328001091E1509AFC600BD6EB01E9A2EB021AD6FC509A2FFC002F2E2D2C2B2A29A9F60928FE39FC6032
    S328001092040BD6EB01E9A0EB0018D6FC50FB9002AA9A299DE192607FF002110398039DE1929DED9200
    S32800109227F690A614C420E6148024DE00750BD6010384084002B400840C982DEB019029E9A0EB0024
    S3280010924A18D60000F6081CD46080F102C04093982E2D301003609FF002C0048402FC40289E000036
    S3280010926D98394002E64040C04484040000F608200500E824B595E455D997AEA104DA9017A100DB51
    S3280010929084126502D4018401752450804000C008B5105000FC80997C0CD430500210039973FC605A
    S328001092B33018D462049DFD929D0393B2828BF6A100D8A3D900995A329DE1929DED92F6259DFD925F
    S328001092D6F9509002F6529D039399433F3D3E0CD4FC606040F102FDFC600CD4F9409007F680100015
    S328001092F93018D4FDE728029E6700F920901220FAFFE8241204E613D0E452D89403A3D820F64224B2
    S3280010931CDE00E72805E82412005302301003FD0AD48402729A21DE00F623E9C3F63122CDCC9C427F
    S3280010933F9A31247C0322B4049807F42100EC94EC94EA5483F5E9A19A3FFC609F4093E9A124B404AC
    S328001093621100FC502F9A3D3FFC6024B40405009F4093FC5074E9C584026401A6422F2D9A3FFC60AF
    S328001093859F6893D2008410223A01217C039C399F409324B4041100FC502F9A9D559FB504B5A5E0E5
    S328001093A80500B0149D5B9F9D829F9A3FF657F625A6659D559F98074440ED959D5B9FB5858BF59DFE
    S328001093CB829FF6752F9A9D559F9D5B9F9D829F9A9D559F9D5B9FA6549D5B9F9D829F9A3D3F9C303B
    S328001093EE2115399F7C8DA63B6480A64362199F858DD30090037A98087AE65B0084026A01211500F3
    S328001094119F7C8DD30090017AA6A22F2D9A3F9FEA932F9A3FA7016601F6822100019C2342C0A92FB9
    S328001094349A3FA7026602F6822104009C2301C0AA2F9A3F9F359474E9A090026401A6422F9A3FA753
    S32800109457029F4694D200840F21004511C06602F6822104009FFE8FAA2F9A3FA7026602F682210236
    S3280010947A009C2301C0AA2F9A3D3FF615660AF6122109009C2372524A2F2D9ADD008804E9B1EAF2FB
    S3280010949D9AF614FC60B5A2E00200B504B4125200FC509AA624210001A640B300840AB292D20890E5
    S328001094C004B36399F09A3FF6232264009F9498206400E85194032164002F9A3DF625D6009009EA3A
    S328001094E351800521640098112264009C44ED8334EB21EC32F654359C4B2D9A3D9C44203200E82173
    S3280010950630E832246400359C4A2D9A3F23E8039F94982F9A3F2310279C372F9A3D3E3FA70AF615EC
    S3280010952912C413C03111C24D404E414F424C43A6D2A6E3323A3901C402C69C45AC66109C4F11C628
    S3280010954C12C86610A6D2A6E3A6F4A6C59C4E3A3901C402C69C45ACF421C6F43AC811C612C801C4D2
    S3280010956FA630A614A6153A3931220100F4C9C4F4D2C69C45ACF421C6F43AC811401242A50A2F2E95
    S328001095922D9AF614010002026610200080E82130E8329C4E9AF6140100E9A09004E99111009A3D53
    S328001095B53E3FA70C11C612C813CAEB52940412CA13C802D401C800C69E0000F615F4CDD2F95090B9
    S328001095D89902D401CA00C69E0000F4C9D2FB840401CA9884ED41B3608077BB60801006CAF4CEC886
    S328001095FB02C812C221010011C4980906C8F4CECA02CA99EEBD608804EE919802EE81B3608002E9A5
    S3280010961E91E57D30B2EC01C2EE21F451CA940201CAF61500C8E950940205C802D4F65100C69E0020
    S3280010964100F4C9D211C030E8E18C0215C2F6619C3A200100E8E19415F8C09011F491C411C42029B2
    S3280010966400E9C087A63212C8980401C211C801C8A50C2F2E2D9A3D3E3FA706F616F627F4CF82F44C
    S32800109687CB8413C00580F671A630A614A61511C212C43A3901C602C89C45ACF653A670A618A6193B
    S328001096AA3C3B9C45ACED95F654A690A61AA61B9C4A03860488E923EA3413861488058001C0F65218
    S328001096CD9C4303C204C43C3B9C45ACED95F654A690A61AA61B9C4A038A048CE923EA34138A148C07
    S328001096F0F494801480F671F6429C480282E922128201C0F6429C480284E9221284AE2F2E2D9A3DEC
    S328001097133E3FA706F61512C0424652C2434753C3424852C4434953C542C2E012C3E012C4B312D290
    S32800109736009041014A024C9C52F616F62701C0F4C94211C0A630A614A6159C523A39F661F6729CE1
    S3280010975946ACF616F62742C243C344C445C59C523A39F661F6729C4CAC9D4BA2F42144980201442A
    S3280010977CAE2F2E2D9AA2A03EF616A64A2200809811BA8AA6A677EB64EE240100E9E28802F612E66F
    S3280010979F5A0087EAF6212EA00A9A773FF657F614F62531EB8380104200E0C2408406EC94ED95999D
    S328001097C2EFE5D333F6752F9A9C436610200080E82130E8329C4E9A3DA2C03FA702F61412C0A66C1F
    S328001097E50100F645980EF61201C09F909FF42142ED95ED95BC8CE65C0087EBAA2FA00C2D9A3D3EB4
    S32800109808F615F626F70000F700009C54ACDA00940EF7003FF70000F651F6629C40980CF7003FF781
    S3280010982B0000F651F6629C41AC9D4BA22E2D9A6610200080E82130E8329C4E9A3F9F6B899FE28E8F
    S3280010984E729FD39AFC60319F1D91249280725200249180520024908052009F57932F9A3FFC60D2C3
    S328001098710084039B1900739F1D9199FEEAC1B3608001319A9C446610200080E82130E8329C4E9A55
    S328001098943DF63590229C44BBB7BAE634EB21EC32F654359C4BA627A636B514D4008408A674A665D4
    S328001098B7F621980321FFFF2D9A3D3E3FF6244FCA4CCBF6158403319815E6AC409004F651980CE635
    S328001098DAAC08900542407398020140F8C68405E60CEF9814F94084066D016E01980D7D05C640405B
    S328001098FDE0500080026D017EA6CA7B220600ED02242000ED04200200EAC08419F9409002EBB3E6A5
    S32800109920AA07D0028406E9E38CA59843E9E3809F983DF9409002E903200400EAC0840A32E9C390E8
    S32800109943182201009813200600EAC09003329809F6319003210100F612E6AA01900A31F9208403EF
    S32800109966210100F612F920906004C84201A620BF009007E6EC0088569805E6EC008058E65D0090A0
    S328001099892EBFA3E6EC008808B30204C85201980EFC60BF1204C85201A630F000FC50E65E009031D6
    S328001099AC04C64200D2FF9029B2929823E6EC00800604C8A6F0F100E6AA10901F05C6E092409816C8
    S328001099CFE6EC008009BFA204C8E002005200E6AA1090057205C652402F2E2D9A3D3E3FA713F616FB
    S328001099F212CF3111CD630153CC3212CA98B00282230A00F422CAF6819C3F05C29021E060C080098F
    S32800109A15F681F6509E0000981140C1C0089009454055C27858C39804014011C202C4900F40C0C0AE
    S32800109A38409009F681F6209E000011C442C09FBD9AA626F8CF900942CC04CFE00200840F0284908C
    S32800109A5B11E52A46B5DB4040B300840642C1C2F852C1E064CC54CCD400840DF8CF9009F494CF14EF
    S32800109A7ECF690159CC40C1A200A23056D37252D4F461D3F421863900CC3803C802CC01CA9FC098C0
    S32800109AA1F492D312D301D0E6220AB3D311D0AE02CDF452808349A5132F2E2D9A6301A627C7079882
    S32800109AC402B363B7878BFAC23FE72820A6129A3F74D20090026401630FA6429FE88C2102FF9F2E34
    S32800109AE78B2100809F01922107079F1A8D2108079F1A8D2109009F1A8DA4C700210A009F1A8D2190
    S32800109B0A00809FD8912F9A3D3E3FA704A66D12C2A624A63512C0C21F6620E5C626982EA66CBD56EB
    S32800109B2D9402A6DCA6CA7BF65302C2215C039C3FA6C6225C0301C09C2701C0ED2111C001C2ED21B2
    S32800109B5011C2E5CDCD6620E65D0087CDAC2F2E2D9A3D0DDC204000E825014020C0FFE825E9A090C4
    S32800109B7314204200E825F4214020BEFFE825E9A0900331982E76F654204400E824204800E825013E
    S32800109B96400242F42100F43A02D2FE840CD3FF8408D4FF8404D5FF90026601E64601A6622D9A3DAE
    S32800109BB93FA7040CDC204400E824F4900010C030F4380210C2255C03232000F642E6241CB5D5F608
    S32800109BDC519C3FFC6009DCE62240B3D39C28FC506620F65209DCE62260B3D39F119B6604F682092E
    S32800109BFFDCE62244B3D39F119B21FEFF22FFFFF4C9C0F4D2C211C012C26604F68209DCE62248B382
    S32800109C22D39F119BAC2F2D9A3D3F255C03C2C01140E9A111426604F65209DCE62240B3D39F119BE9
    S32800109C450CDC204000E8240040F4C800840B9F619BD2009004620198049FB89B722F2D9A3D3F9F92
    S32800109C68619BD200903C0CDC204000E8240500F651E623C020FF1FE8518C20FC60F6519C28664090
    S32800109C8B0ADCF6519F119B66400ADCF6519FA997FC50FB900A72981972EDA0841498109FB89B72CF
    S32800109CAE0CDC204000E824F4A000840262012F2D9A3D3E3FA70EF61512C813CA9F659CD20090CEB5
    S32800109CD121C0FFED0111C3E60A3F98F06B40E5CBAB5BCC7353CD01CCF451CA8C045BC2980443CA0F
    S32800109CF453C25AC67454C746C202C801C3F421C69FA997FB90A409DC9C28A6A602C309DC9F119B0A
    S32800109D17A6A602C309DC9FA9970CDCFB900FA6A602C3F6419FE38F9F8B8F7298A246C202C801C665
    S32800109D3AEC219F119B46C202C809DCF421C69FA9970CDCFB900A46C202C801C6EC2199D1E0CBC22D
    S32800109D5D5BC544C201C6E52A24B3DB06C3ED2646C5F662F641ED219F119B46C5F66209DCED219F5B
    S32800109D80A997FB900A46C5F66209DCED21999C01C39F2A9CD20093969F659CD200840F0CDC664093
    S32800109DA3F642204000E8240100997D42C252C07353C101CAF4C9C011CA01C8F421C011C801C3E6EB
    S32800109DC62240B3D311C37AF8CA870C9F8B8F6201A50E2F2E2D9A3D3E3FA70311C0F62656C224E079
    S32800109DE95F4015D096905D255C03230C0022C05FF6519C3F01C0114C1650240045144E214045111E
    S32800109E0C5243C2535468FF58556616F65221E05F9F119B4AC2E65A4094026A40A6A6F66221404586
    S32800109E2F9F119BA6A602C02100459F119B245C03629652006601F64221F55F9F119B6003F3D0ABF3
    S32800109E522F2E2D9A38F690A200393A3B3C3D3E3FFC203F9FEC279B249238F690A200393A3B3C3DCA
    S32800109E753E3FFC203F2690804A80E00A824080C008900D60F750804082C00890039F1D2EA6A0C017
    S32800109E9804900760FB50809F019FA6A0C001900760FE50809FF19EA6A0C002900760FD50809FF92E
    S32800109EBB9E9B249238F690A200393A3B3C3D3E3FFC203F2690804A80E00A82C010900760EF50802E
    S32800109EDE9FEA01A6A0C020900760DF50809FE6019B249224928060FEF0009A24928060FDF0009AE3
    S32800109F0124928060FBF0009A38F690A200393A3B3C3D3E3FFC203F2690800580F40582C040900BDC
    S32800109F2460FEF08660BF50809F449FA6B0C00290039F9F9FA6B0C00190039F9C009B24929A3F2404
    S32800109F4792806080F1002100209F16922F9AF61433FC60FD217C03E954801B21B604E954881442A9
    S32800109F6A0073E5C242E5D333A680C0019003A62372E9235400EC94FD24B404F423001300FC50FD96
    S32800109F8D62019A9C43660F200040E82130E8329C4E9A24928060FDF0009AA2A0F61401C144C3479A
    S32800109FB0C4E060C3B7779090B7A0907DE6C77F8087D730940847C4CF808469986CE614807576D7A2
    S32800109FD3178C4B9018E5B700B4B4B3E3B2E2B6E6B78787F4B666B2D2B3D3B4D4767740C4C88084D1
    S32800109FF610F42100F43A02E03604E0370588349839F4C900F4D202E0D604E0D705881FE9B1B4F436
    S3280010A019B5F5B6F6B7F7981FA60A77E961B474B575B676B777BA8A87F299BD230000980323FFFF44
    S3280010A03CF631F6321100120256045705A00A9A3F3DB460B576840622803F3198B9D6869406B560CA
    S3280010A05F84AF98B2D66797ECE62618B464B560B6E5B4E49C5025B1002418729C4AA626A637F641D1
    S3280010A082F652BB60800EB686B7C7201872E82120B100E832A645A634A62372B5B5B4E4B3E3B2E230
    S3280010A0A5DF008402D67F8C68DFFF8402D682805BA70956C011C112C33111C552C7658055C876A692
    S3280010A0C8659FBCA1F4C9C1F4D2C3E9B1EAF2B560881111C112C3B69701C502C79F34A211C512C72C
    S3280010A0EBB696D61897D601C644C840C5E62080B2D2B3D3B4D445C0E6257FB464B5B5B4E4A5092D21
    S3280010A10E2F9A31322D2F9A727322807F99F63FB460B57690928890A70DE6C67F56CC669EB464B6D6
    S3280010A131B5B4E49C5111C012C2658074737211C412C611C811CA76B69701C402C69F34A28827E023
    S3280010A15455C3840DE054C28408E053C18403E052C08C1311C412C6A6659FBCA1F421C811C8F43A03
    S3280010A177CA12CAB696D61897C842CCE909A634A6359C5220187210C020313F10C29C4611C012C26A
    S3280010A19A01C802CA9C52B460B5769009E6C61FB464B6B5B4E49C40A50D2F9A72732280FF99F7D509
    S3280010A1BD09942324000172736410E6C50A9012B9B9B8E8B9B9B8E8B4B4B3E3B2E2B58587EEECC1C2
    S3280010A1E0B4C49AF674E758079EEEA1F6479A21D94722E6339A21C8F7228F1C9A21B78322130F9AEA
    S3280010A20321308C22C2079A21625322F0039A218B0A22FC019A21530122FF009A212BC0227F009A55
    S3280010A2262105F0223F009A2101FC221F009AF614F625900CBBBBBAEAB9E9B8E8B78787F4EC21ED25
    S3280010A249329A77980467809800B560B7E7D7C09050B460B576904AE6C67E80459043E61480A63227
    S3280010A26CA643E6F610802A9015D6088009A606A63273A6609008B3B3B2E2B68687F8CF409001FD47
    S3280010A28FB7608002E9B1E54073C0808401FD21FFFFB7608809E62080B043FD7372FD638099FAFF75
    S3280010A2B2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
    S3280010A2D5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
    S3280010A2F8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    S3280010A31BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C
    S3280010A33EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
    S3280010A361FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
    S3280010A384FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S3280010A3A7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S3280010A3CAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
    S3280010A3EDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
    S3280010A410FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36
    S3280010A433FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
    S3280010A456FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    S3280010A479FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280010A49CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280010A4BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S3280010A4E2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S3280010A505FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40
    S3280010A528FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D
    S3280010A54BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
    S3280010A56EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
    S3280010A591FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
    S3280010A5B4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    S3280010A5D7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
    S3280010A5FAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
    S3280010A61DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27
    S3280010A640FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
    S3280010A663FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
    S3280010A686FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
    S3280010A6A9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
    S3280010A6CCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
    S3280010A6EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
    S3280010A712FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31
    S3280010A735FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
    S3280010A758FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
    S3280010A77BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
    S3280010A79EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S3280010A7C1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
    S3280010A7E4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
    S3280010A807FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B
    S3280010A82AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
    S3280010A84DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5
    S3280010A870FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
    S3280010A893FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
    S3280010A8B6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
    S3280010A8D9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
    S3280010A8FCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
    S3280010A91FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22
    S3280010A942FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    S3280010A965FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
    S3280010A988FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9
    S3280010A9ABFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
    S3280010A9CEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
    S3280010A9F1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    S3280010AA14FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C
    S3280010AA37FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
    S3280010AA5AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
    S3280010AA7DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S3280010AAA0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S3280010AAC3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
    S3280010AAE6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
    S3280010AB09FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36
    S3280010AB2CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
    S3280010AB4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    S3280010AB72FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280010AB95FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280010ABB8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S3280010ABDBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S3280010ABFEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
    S3280010AC21FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D
    S3280010AC44FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
    S3280010AC67FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
    S3280010AC8AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
    S3280010ACADFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    S3280010ACD0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
    S3280010ACF3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
    S3280010AD16FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27
    S3280010AD39FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
    S3280010AD5CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
    S3280010AD7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
    S3280010ADA2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
    S3280010ADC5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
    S3280010ADE8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
    S3280010AE0BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31
    S3280010AE2EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
    S3280010AE51FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
    S3280010AE74FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
    S3280010AE97FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S3280010AEBAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
    S3280010AEDDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
    S3280010AF00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B
    S3280010AF23FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
    S3280010AF46FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5
    S3280010AF69FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
    S3280010AF8CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
    S3280010AFAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
    S3280010AFD2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
    S3280010AFF5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
    S3280010B018FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22
    S3280010B03BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    S3280010B05EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
    S3280010B081FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9
    S3280010B0A4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
    S3280010B0C7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
    S3280010B0EAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    S3280010B10DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C
    S3280010B130FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
    S3280010B153FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
    S3280010B176FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S3280010B199FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S3280010B1BCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
    S3280010B1DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
    S3280010B202FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36
    S3280010B225FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
    S3280010B248FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    S3280010B26BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280010B28EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280010B2B1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S3280010B2D4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S3280010B2F7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
    S3280010B31AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D
    S3280010B33DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
    S3280010B360FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
    S3280010B383FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
    S3280010B3A6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    S3280010B3C9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
    S3280010B3ECFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
    S3280010B40FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27
    S3280010B432FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
    S3280010B455FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
    S3280010B478FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
    S3280010B49BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
    S3280010B4BEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
    S3280010B4E1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
    S3280010B504FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31
    S3280010B527FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
    S3280010B54AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
    S3280010B56DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
    S3280010B590FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S3280010B5B3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
    S3280010B5D6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
    S3280010B5F9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C
    S3280010B61CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
    S3280010B63FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5
    S3280010B662FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
    S3280010B685FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
    S3280010B6A8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
    S3280010B6CBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
    S3280010B6EEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
    S3280010B711FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22
    S3280010B734FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    S3280010B757FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
    S3280010B77AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9
    S3280010B79DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
    S3280010B7C0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
    S3280010B7E3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    S3280010B806FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C
    S3280010B829FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
    S3280010B84CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
    S3280010B86FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S3280010B892FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S3280010B8B5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
    S3280010B8D8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
    S3280010B8FBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37
    S3280010B91EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
    S3280010B941FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    S3280010B964FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280010B987FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280010B9AAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S3280010B9CDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S3280010B9F0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
    S3280010BA13FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D
    S3280010BA36FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
    S3280010BA59FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
    S3280010BA7CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
    S3280010BA9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    S3280010BAC2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
    S3280010BAE5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
    S3280010BB08FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27
    S3280010BB2BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
    S3280010BB4EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
    S3280010BB71FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
    S3280010BB94FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
    S3280010BBB7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
    S3280010BBDAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
    S3280010BBFDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32
    S3280010BC20FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
    S3280010BC43FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
    S3280010BC66FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
    S3280010BC89FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S3280010BCACFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
    S3280010BCCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
    S3280010BCF2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C
    S3280010BD15FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
    S3280010BD38FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5
    S3280010BD5BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
    S3280010BD7EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
    S3280010BDA1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
    S3280010BDC4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
    S3280010BDE7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
    S3280010BE0AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22
    S3280010BE2DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    S3280010BE50FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
    S3280010BE73FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9
    S3280010BE96FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
    S3280010BEB9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
    S3280010BEDCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    S3280010BEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D
    S3280010BF22FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
    S3280010BF45FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
    S3280010BF68FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S3280010BF8BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S3280010BFAEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
    S3280010BFD1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
    S3280010BFF4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37
    S3280010C017FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
    S3280010C03AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    S3280010C05DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280010C080FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280010C0A3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S3280010C0C6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S3280010C0E9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
    S3280010C10CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D
    S3280010C12FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
    S3280010C152FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
    S3280010C175FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
    S3280010C198FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    S3280010C1BBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
    S3280010C1DEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
    S3280010C201FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27
    S3280010C224FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
    S3280010C247FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
    S3280010C26AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
    S3280010C28DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
    S3280010C2B0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
    S3280010C2D3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
    S3280010C2F6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32
    S3280010C319FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
    S3280010C33CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
    S3280010C35FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
    S3280010C382FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S3280010C3A5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
    S3280010C3C8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
    S3280010C3EBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C
    S3280010C40EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
    S3280010C431FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5
    S3280010C454FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
    S3280010C477FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
    S3280010C49AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
    S3280010C4BDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
    S3280010C4E0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
    S3280010C503FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22
    S3280010C526FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    S3280010C549FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
    S3280010C56CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9
    S3280010C58FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
    S3280010C5B2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
    S3280010C5D5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    S3280010C5F8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D
    S3280010C61BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
    S3280010C63EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
    S3280010C661FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S3280010C684FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S3280010C6A7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
    S3280010C6CAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
    S3280010C6EDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37
    S3280010C710FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
    S3280010C733FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    S3280010C756FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280010C779FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280010C79CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S3280010C7BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S3280010C7E2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
    S3280010C805FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D
    S3280010C828FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
    S3280010C84BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
    S3280010C86EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
    S3280010C891FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    S3280010C8B4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
    S3280010C8D7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
    S3280010C8FAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28
    S3280010C91DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
    S3280010C940FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
    S3280010C963FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
    S3280010C986FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
    S3280010C9A9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
    S3280010C9CCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
    S3280010C9EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32
    S3280010CA12FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
    S3280010CA35FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
    S3280010CA58FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
    S3280010CA7BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S3280010CA9EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
    S3280010CAC1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
    S3280010CAE4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C
    S3280010CB07FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
    S3280010CB2AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5
    S3280010CB4DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
    S3280010CB70FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
    S3280010CB93FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
    S3280010CBB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
    S3280010CBD9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
    S3280010CBFCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23
    S3280010CC1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    S3280010CC42FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
    S3280010CC65FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9
    S3280010CC88FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
    S3280010CCABFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
    S3280010CCCEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    S3280010CCF1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D
    S3280010CD14FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
    S3280010CD37FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
    S3280010CD5AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S3280010CD7DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S3280010CDA0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
    S3280010CDC3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
    S3280010CDE6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37
    S3280010CE09FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
    S3280010CE2CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    S3280010CE4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280010CE72FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280010CE95FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S3280010CEB8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S3280010CEDBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
    S3280010CEFEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E
    S3280010CF21FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
    S3280010CF44FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
    S3280010CF67FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
    S3280010CF8AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    S3280010CFADFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
    S3280010CFD0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
    S3280010CFF3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28
    S3280010D016FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
    S3280010D039FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
    S3280010D05CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
    S3280010D07FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
    S3280010D0A2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
    S3280010D0C5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
    S3280010D0E8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32
    S3280010D10BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
    S3280010D12EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
    S3280010D151FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
    S3280010D174FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S3280010D197FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
    S3280010D1BAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
    S3280010D1DDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C
    S3280010D200FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
    S3280010D223FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5
    S3280010D246FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
    S3280010D269FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
    S3280010D28CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
    S3280010D2AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
    S3280010D2D2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
    S3280010D2F5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23
    S3280010D318FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    S3280010D33BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
    S3280010D35EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9
    S3280010D381FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
    S3280010D3A4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
    S3280010D3C7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    S3280010D3EAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D
    S3280010D40DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
    S3280010D430FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
    S3280010D453FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S3280010D476FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S3280010D499FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
    S3280010D4BCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
    S3280010D4DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37
    S3280010D502FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
    S3280010D525FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    S3280010D548FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280010D56BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280010D58EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S3280010D5B1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S3280010D5D4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
    S3280010D5F7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E
    S3280010D61AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
    S3280010D63DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
    S3280010D660FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
    S3280010D683FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    S3280010D6A6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
    S3280010D6C9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
    S3280010D6ECFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28
    S3280010D70FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
    S3280010D732FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
    S3280010D755FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
    S3280010D778FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
    S3280010D79BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
    S3280010D7BEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
    S3280010D7E1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32
    S3280010D804FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
    S3280010D827FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
    S3280010D84AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
    S3280010D86DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S3280010D890FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
    S3280010D8B3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
    S3280010D8D6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C
    S3280010D8F9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19
    S3280010D91CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5
    S3280010D93FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
    S3280010D962FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
    S3280010D985FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
    S3280010D9A8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
    S3280010D9CBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
    S3280010D9EEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23
    S3280010DA11FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    S3280010DA34FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
    S3280010DA57FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9
    S3280010DA7AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
    S3280010DA9DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
    S3280010DAC0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    S3280010DAE3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D
    S3280010DB06FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
    S3280010DB29FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
    S3280010DB4CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S3280010DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S3280010DB92FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
    S3280010DBB5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
    S3280010DBD8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37
    S3280010DBFBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14
    S3280010DC1EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    S3280010DC41FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280010DC64FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280010DC87FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S3280010DCAAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S3280010DCCDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
    S3280010DCF0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E
    S3280010DD13FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
    S3280010DD36FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
    S3280010DD59FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
    S3280010DD7CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    S3280010DD9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
    S3280010DDC2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
    S3280010DDE5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28
    S3280010DE08FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
    S3280010DE2BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
    S3280010DE4EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
    S3280010DE71FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
    S3280010DE94FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
    S3280010DEB7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
    S3280010DEDAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32
    S3280010DEFDFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F
    S3280010DF20FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
    S3280010DF43FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
    S3280010DF66FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
    S3280010DF89FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
    S3280010DFACFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
    S3280010DFCFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C
    S3130010DFF2FFFFFFFFFFFFFFFFFFFFFFFFFFFF19
    S32800140000545495D5FFFF191000450001060024000385020A0000FFFF0000900003100040FFFFFFA8
    S32800140023FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
    S32800140046FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    S32800140069FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0123456789ABCDEFFEDCBA9885
    S3280014008C7654321014047236FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86
    S328001400AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37
    S328001400D2FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14
    S328001400F5FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1
    S32800140118FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
    S3280014013BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
    S3280014015EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
    S32800140181FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
    S328001401A4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
    S328001401C7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E
    S31B001401EAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB
    Thanks a lot, Batt.
    Best Regards.
    Matthieu
  • Hi Matthieu,
    Your assumptions are mostly acceptable. I'm unable to import the srec. However, I would advise you to perform GPCCHEM match and then proceed with your learning cycle after that. Many chem IDs match with cells of different capacity. All that matters is that the curve of your dsg fit the curve seen by it. You can mostly leave the settings at the defaults except for when the cell DS suggests otherwise. Once you set the basic gauging parameters like design capacity, design voltage, terminate voltage etc, the gauge can learn Qmax and Ra values during the learning cycle.
  • Hi Batt,
    Thanks for your answer.
    Can you help me one more time, as "Settings-->Configuration-->Charging Configuration" register is NOT documented in the DF section of the Tech Ref (version 4500_1_06 of bq40z50R1):
    What are the three bits in this register for? bit0: CRATE, bit1: CCC, bit2: SOC_CHARGE.
    I did as you told, checked the calibrations, set the Term Disch and Term Charge voltages, set pack and individual cells design capacity, etc.
     Then I discharged below the TERM voltage (2750mV/cell). The Flt (Filtered?) Rem Q got negative. When recharging, the RSOC stayed a loooong time to 0%, and accumulated charge to 0mAh. Then it started incrementing again, and when it reached around 17Ah (12.8V 20Ah LiFePO4 pack), RSOC was at 100%, charge accumulation stopped, but the battery voltage was 13.35V only, so obviously it wasn't fully charged (EOC=14.6V). Indeed it kept charging for quite a while, and I thought it would add the extra charge to the accumulation counter.
    But nope, it didn't, even after 5 hours of relax time : still only 17Ah of FCC!
    Where am I wrong?
    I browsed through the DF registers, set [RSOC_HOLD] to 0 as advised when [SMOOTH] is set (TechRef par. 6.6). I even set [LFP_RELAX] to 0, but this might be even worse.
    Got any idea ?
    I will perform GPCHEM match later: 5 hours of relax time after charge, then discharge at C/10 (10 hours), then another 5 hours of relax time. 20 hours total, I'll have to sleep in the office.
    Thank you.
    Best Regards.
    Matthieu
  • Hello again, Batt
    I forgot to ask: what is the reset command? What does it reset?
    Thanks.
    Regards.
    Matthieu
  • Hi Matthieu,
    The Charging Configuration[CRATE] flag provides an option to adjust the ChargingCurrent() based on
    FullChargeCapacity()/DesignCapacity().
    For example, with [CRATE] = 1, if FullChargeCapacity()/DesignCapacity() = 90% and Rec Temp
    Charging: Current Med is active per the charging algorithm, the ChargeCurrent() = Rec Temp
    Charging: Current Med × 90%.
    Please refer to the bq40z80 TRM as it has the definitions for the rest.
    The device can modify ChargingVoltage() and ChargingCurrent() to compensate losses caused
    by the FETs, the fuse, and the sense resistor by measuring the cell voltages directly and adjusting
    ChargingCurrent() and ChargingVoltage() accordingly.
    In CONSTANT CURRENT mode, the device can increase the ChargingVoltage() value to compensate the
    drop losses. This feature can be enabled by setting Configuration[CCC] = 1 and configuring the CCC
    Current Threshold.
    SOC_CHARGE (Bit 2)
    1 = Enables SOC threshold to replace voltage thresholds (CLV, CMV, and CHV) in Advanced
    Charging Algorithm
    0 = Uses voltage thresholds (CLV, CMV, and CHV) in Advanced Charging Algorithm
    Reset command is 0x41 sent to 0x00. It clears the RAM of the gauge and reinitializes it.
  • Hello Batt,
    Thanks a lot for all this precise info.
    Still struggling with the bq40z50R1 and bqStudio.
    1) I'd like to be sure, as TechRef is not enough documented for dummies:
    - When in "Sealed" mode, "Operation Status A" has bit 11 (SS) set to 1, bit 9 and bit 8 (SEC1 and SEC0) both set to 1. Correct?
    - When in "Unsealed" mode, Operation Status A" has bit 11 (SS) set to 0, bit 9 (SEC1) set to 1 and bit 8 (SEC0) set to 0. Correct?
    - When in "Full Access" mode, Operation Status A" has bit 11 (SS) set to 0, bit 9 (SEC1) set to 0 and bit 8 (SEC0) set to 1. Correct?
    I suppose so, otherwise bqStudio would prompt an error message when trying to download the .srec file while not in Full Access mode.
    This leads to question:
    2) The .srec the manufacturer sent me weighs 159KB : it took around 5 seconds to have it downloaded to bq40z50R1.
    The original bq40z50R1.srec file you kindly sent me wheighs 4.2MB, and when I download it to the chip, the progress bar stays on circa half a second, and then it's off. But no Error message. How come? It should take much more time to program the chip, due to its weight. Shouldn't it?
    Please let me know if I am doing something wrong.
    Thanks a lot.
    Best Regards.
    Matthieu
  • Hi Matthieu,
    Yes, bqstudio will prompt with error if you are not in full access mode for srec export.
    The original srec can't be that large. That file includes other files which are necessary for the gauge to function. You need to unzip it, run the installer, then program the srec into the gauge, then copy the bqz file to the bqstudio config directory and then power up the gauge.
  • Hello Batt,
    Once again, thank you.
    Regards.
    Matt
