Is UC2909MDWREP interchangeable with UC2909DW?
Hey Cole,
The UC2909MDWREP is interchangeable to a degree.
The difference is the UC2909MDWREP is an "EP" version of the device which is an enhanced version for larger temperature ranges along with higher process control. There are usually minor specification differences.
If you used to use the UC2909DW you will likely be able to use the UC2909MDWREP.
Daniel
