I'm picking up a design that was designed and programmed by a former engineer and uses the BQ78350-R1 chip and I'd like to use a different part for the cell temperature thermistors (TS1, TS2)
The existing thermistor is a 10k NTC and I'd like to replace with another 10k NTC but they have slightly different beta values.
Is there a process to configure a new NTC for accurate temperature readings?
Will any 10k NTC be close enough, or will it require performing the entire CEDV learning process all over again with the new thermistor?
Ben
