I'd like to ask what kind of solution does TI have in the topic lo ultra-low shutdown/quiesent current voltage regulators/smps's?
My aim is to have 1A 15V/12V output power IC that normally is asleep/shutdown and drains current of nA range (it's supplied from 5s LiOn battery, hence, the requirement)
The power supply is 99% shutdown in their life cycle, only in case of error it should be turned on, and give 1A at 15A/12A tor some short period of time.
Thank you in advance,
Adam
