Other Parts Discussed in Thread: TPS54260
Hello team,
For PMP4369 design, I have checked the operation of enable/disable circuit block:
Theoretically, this circuit should disable the device when the output voltage is greater than 13V, but I am not very sure of the circuit operation as Vout is a negative voltage. I have launched a simulation and for negative output voltages the enable pin will see a negative voltage as well, thus, the device will be disabled. Maybe I am making a wrong reasoning.
Please, I need further details about this circuit operation. Thanks in advance for your support.
