Other Parts Discussed in Thread: TPS54308
During testing the voltage between SW to GND, i found these had ringing at switch-node and cause a spike voltage. i hope to know how to reduce this ringing and spike voltage.
Dear all,
Since i already solve this problem for my customer. I summarized the cause issue and solution as follow:
Cause issue:
1: PCB Layout do not have good performance on paraitic inductance reduce. You may can find the following adress to know much about it.
http://www.ti.com/lit/an/slyt682/slyt682.pdf
2:the switching speed is too fast may cause this ringing too. dv/dt should be controlled in a reasonable range;
Solution:
1: Add Ron between Gate drivers to MOSFET can help reduce dv/dt;
this solution may not suitable for our TPS54308 because TPS54308 integrated MOSFET and Gate drivers inside;
2:Add 3.3ohm boot resistor in Bootstrap circuit
We can change our circuit as follow:
Here we have the result on this solution:
